FixYa.com
Tags:
Maytag Neptune MAH5500B Front Load Washer
Water in tub
posted by wildtime on May 14, 2008
water in tub ,is seal gone ,smells ,what should be changed
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 14, 2008
Not Rated (0)
IFIXALL
Rank:Wiz Wiz
Rating: 84%, 359 votes
Well first of all if you remove the water your second problem(smells) will go away.You have a clogged water pump plain and simple.To fix it cheap you have to unclog it by taking the two hoses off it and you'll see the problem stuck inside the pump.So, remove what you find and you now saved a lot of money!
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Washing Machines problems?
my machine has a code and is...
I did a load of laundry today... Answer This...
very loud final spin cycle with...
Model #MAH3000AWW During wash... Answer This...
cannot get the lid to unlock
washing a backpack and now the... Answer This...
Maytag Neptune
LR, Locked Rotor error code.... Answer This...
installing washer door boot
step by step on how to install... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
