Question about Sharp AL-1655CS Copier
AL1655CS Paper jammed in Fusing Unit. How to get it out?
  • 1,110 Answers
If you can not remove it by flipping open the gate with all the teeth on it then you may have to remove the fusing unit. This is easily done by removing the 2 silver screws, one at each end of the fusing unit. Then the unit will just wiggle right out. This will give you better access to the top and bottom areas where the paper enters and exits. Then just re-install.
Good Luck and Thank You for using Fixya.
Posted on Sep 07, 2010
Sir ,ir 2020 paper jam at fusing unit.some times half of paper will come out,sometimes jams at the entrance of fusing unit.i changed every sensors,then changed new fusing unit,then feeding assembly...
Sometimes you can vlear a fuser jam with a manilla folder. Open the copier let it coll a bit and slide a manilla folder through the fusing unit. If it is just pieces of stuck paper the folder can sometimes push them out of yhe wsy ad you gorce it through and pull it out the other side. The fuser has two rolls one heat and one pressure both of these rolls have small fingers which are supposed to kerp paper from sticking to them. Sometimes these fingers get bent or damaged and this causes the actual jam. There is also an exit sensor that detects jams in this area it can have a damaged part as well
Jan 20, 2018 | Canon iR 2020i Laser Printer
HI. My Sharp AL-1655CS Laser Printer is making an extremely loud noise when printing and when the paper comes out its all jammed like an acordion. Can u please help me?
It's going to be the fusing unit that needs to be replaced. It's also a good idea to replace the gear in the machine that drives the fuser at the same time. Both are available here: http://olsonbros.com/sharp/specs/al1655cs.html
Sep 02, 2011 | Sharp AL-1655CS Laser Printer
Paper to thick for printer and has jammed, have attempted all manual methods to locate the paper, take out the toner and check the back but still cant locate paper
if there is no paper inside then one of the sensors are broken thats why it is indicating the paper jam sign. check the fusing unit. the paper must be inside that unit and its hard to see. fusing unit is the unit before the paper exit unit or from where the paper comes out.
Oct 01, 2010 | Kyocera Fs-1100 Printer
Error code H5-01 how to fix on a sharp arm350u
That is a repeated uncleared jam in the paper transport. You may have a piece of paper wrapted in the fuser that you cant see, or one of the sensors on the transport between the paper feed and fuser are dirty.
You can try entering doagnostics, you press P * C * or # * C*, that will put the machine in diagnostics. Then press 14, then enter 1 then press enter. That will reset the machine, If the 14 routene doesnt work look for an uncleared jam or clean sensors.
Here is what it says.
H5 01 Content 5-time continuous POD1 not-reaching
jam detection
Detail 5-time continuous POD1 not-reaching
jam detection
Cause A fusing section jam is not properly
removed. (Jam paper remains.)
POD1 sensor trouble, or harness
disconnection
Improper installation of fusing unit
Check and
remedy
Check jam paper in the fusing section.
(winding, etc.)
Check POD1 sensor harness, and
check the fusing unit installation.
Use SIM14 to cancel the trouble
Aug 09, 2010 | Sharp AR-M350U Copier
Paper jams at fusing unit. It appears there is a
That sounds like part of the pressure roller. What color is the rubbery type obstruction? What brand of copier do you have? Which model number?
Nov 02, 2009 | Office Equipment & Supplies
Call for service
Cause The fusing JAM is not completely
Fusing unit installation failure
Check and remedy:
Check for jam paper in the fusing section.
(paper winding, etc.)
Check fusing unit installation.
Check the jam sensors in the fuser.
Aug 24, 2009 | Sharp AR-M237 Copier
Remove a paper jam under the fuser unit on a canon image runner 5070
Hello sir; I believe You have to detacth finisher unit then open the side door to reach the fusing unit see is there have jamming paper over there ,the paper under the fusing unit just open front door turn the knob clockwise on the fusing unit paper will coming out.
Aug 17, 2009 | Canon imageRUNNER 5000 Copier
Help
H5-01 indicates tha the paper sensor is defective in the fusing unit. The only way you can try to reset that one is buy turning the power off, wait 30 seconds and turn the power back on.
If the error code returns the fusing unit will have to be fixed to take care of the paper sensor.
Jul 20, 2008 | Sharp AR-M237 Digital Copier
Re: Paper Jam
I'am sorry to say that you have to replace the fusing unit on that machine, when it jams inthe fuser like that the fusing unit is going bad. the fusing units range from: $200.00 to $295.00 plus service call. You may think about replacing it, sorry for the bad news. I've worked on about 5 of those machines with the same problem and it always comes down to replacing the fusing unit, even if you get the paper out it will jam again.
Nov 16, 2007 | Canon imageCLASS D761 Copier
Sharp AL-1655CS Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
