Question about Bose Companion® 5 2.1 Speakers
Hello After 5 or 10 mins of inactivity, my Bose companion 5 speakers go automatically into mute. Is there any way to disable this setting ? Thx a lot Sam
SOURCE: bose companion speaker stopped working!?
What happened to you is probably mere coincidence with your cousin's use of the headphones and this is throwing you off. I own the Bose Companions also and they stopped working as well. However, I traced the problem to the "wall wart" power supply. Not sure why but Bose is now using an interchangable plug on them. If you look at the power supply you will see a "PUSH" button. If you depress it the plug can slide out. When it is slid back in and locked in place the connection between the plug plate and the power supply is not a good one. Try fiddling with it. But even if the connection is not the culprit, something in the power supply is. I swapped another power supply with the same connector and spec's ( amps must be the same ) from another item and the speakers worked perfectly.
Posted on Dec 14, 2008
Benimur
  • 6966 Answers
SOURCE: bose companion 3 series 2 multi media speaker system
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Initially, the 14 seconds interval is significant. This is indicative that whatever fault it is, it is coupled to a time-based circuitry. The time-based circuitry need not be complicated. it can actually be a simple resistor/capacitor network. The capacitor takes a certain amount of time to charge and then discharge (14 seconds, 'whoomp'). Having said this, then the foremost suspect would be an electrolytic capacitor, probably low value (1~4.7uF), probably a coupler/decoupler. Of course the capacitor serving other functions could very well be the culprit as well.
Corrective measure would entail, identifying/determining which capacitor and replacement. Tedious as it may sound, each capacitor would then have to be tested for capacitance and leakage out of circuit or at least 1 leg un-soldered.
Good luck and Thank you for using FixYa.
Pls be informed that due to my current rank and rating, even a Helpful would be detrimental to my status. Should this solution not address your concern, it would be appreciated if you could just not rate it at all. Cheers.
Posted on Dec 27, 2008
SOURCE: Bose 3 Companion Voltage
http://laptopsforless.stores.yahoo.net/volconforeur.html?wwparam=1239619507
Please chk the above Convertor it will sove your problem
Posted on Apr 13, 2009
SOURCE: Bose Companion II Computer Speaker: The AC power adapter burnt
My puppy chewed through the cord for my a/c adapter, I just took the speakers into Circuit City, and they found me a workable replacement (the replacement isn't BOSE, but it works just fine).  Hope that helps!
Posted on May 07, 2009
  • 10 Answers
SOURCE: Where Can I purchase a bose companion 5 control pod?
you have to call customer service at 1-800-367-4008.Run about $35.
For the broken cable, have you tried to fabricate a new cable for it?
Posted on May 25, 2009
How do I unmute my bose companion 3 speakers
The volume circle has a mute in the center of where the Orange light is . Injure turns it green these other people are over thinking it like my mother did.
May 05, 2015 | Bose Companion 3 Computer Speakers
No audio on Windows 7 with Bose companion 3 speaker system
Is it muted in the mixer options for your audio card? Is anything on your computer muted? Is it plugged in? Do you have a faulty cable?
Aug 20, 2011 | Bose Companion 3 Computer Speakers
My Bose Companion III Computer Speakers have stopped working.All connections are fine but no sound is produced
This may sound obvious and you might have checked this already, but check all of your mute keys. If the speaker's volume control is down, that's one. If there's one on your keyboard you could accidentally hit, that's one. If the sound properties on your computer insist sound is coming out, try a different set of speakers, or try the speakers on a different device like an iPod. Get back to us if you still have problems. Hope this helps =]
Mar 03, 2011 | Bose Companion III Computer Speakers
I have the Bose Companion 3 Series II speakers. I ordered them through the Bose website. However, I continuously hear static. Mute, low volume, with music, etc. I hear static noise. The only way to...
I have had totally the same problem before, and I have discovered that it is actually because of the electric current running through the speakers when the volume is low or muted.
I am afraid to tell you that the only solution to this problem is to raise the volume, as it is not a malfunction in the speakers but in the electric current running through them.
Good luck.
Dec 16, 2010 | Bose Companion 3 Series II Multimedia...
My speakers keep muting themselves at random
I am having the exact same problem. Has this been resolved yet?
Feb 12, 2010 | Bose Companion 3 Computer Speakers
Samsung TV and Bose Campanion 3 speakers
Are these PC speakers? OF so you need a stereo RCA to min-jack cable, assuming the TV has a set of RCA audio outputs.
Jul 25, 2009 | Bose Companion 2 Computer Speakers
Sound drivers are not working
Hello there
If you got warranty, use it, of not, try to see if inside contact are not broke or loose.
check inputs, and cables . verify is not in mute on control panel, or bad wire.
good luck
Mar 20, 2009 | Bose Companion 3 Computer Speakers
Sound from 1 speaker bose companion II
you must check the connection with the other speaker.
Feb 13, 2009 | Bose Companion 2 Computer Speakers
Bose Companion® 5 2.1 Speakers Logo
319 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
