Question about Amana ATB2135HR Top Freezer Refrigerator
My refrigerator runs almost constantly. Do I need a repairman or is there a simple maintenance that I can do?
  • Amana Master
  • 8,220 Answers
Get behind it and clean out the cobwebs. A clean coil is a more efficient coil. You don't need to call anybody to clean it up.
Posted on Sep 07, 2010
Freezer runs constantly and food never freezes solid
no doubt the unit need a recharge of refrigerant and only a certified repairman can do it .
Aug 21, 2015 | Refrigerators
It is a double door. freezer fan runs constantly
call a repairman might need coolant added
Mar 15, 2015 | LG Refrigerators
I have an admiral refrigerator admiral designer series 21.1 cu ft.the motor is constanly running 8 to9 hrs at a time the left side of the door is always hot and the top of the refrigerator a repairman came...
yes compressor runs and shuts off every 8 - 10 hours for a half hour for defrost system mode. but ur hot left side may be a sign of issues needing to be addressed>
FRIDGE COILS or door walls SEEM VERY HOT:
The condenser coils do get hot. They can even be to hot to comfortably touch and this is normal.
The refrigerator should not run constantly but shut off with each defrost cycle.
Running constantly and never cycling off can indicate a cooling problem.
One thing to try is to wait till it has been running a few minutes then open the door and turn your cycling thermostat towards the off position. It should cycle off before getting to the off position on the dial.
If it does not cycle off then it's not getting cold enough to satisfy the thermostat. This is likely the reason the refrigerator runs all the time.
A thermometer in a glass of water can be used to check the temperatures in the refrigerator section.
You can check that all fans are running.
Feb 26, 2015 | Admiral Refrigerators
My figidaire freezer fans runs almost all the time
Your problem could be as simple as dirty condenser coils or a burned out condenser fan. These components are on the bottom of the refrigerator and removing a couple of panels should give you access to them. Clean dust and dirt off the coils and check to see if the bottom fan is running when the refrigerator is running.
You'd be surprised how often this simple fix will get you back up and running. Dirty coils make the refrigerant system VERY inefficient, sometimes to the point that the refrigerator has to run almost constantly to acheive the desire temperatures inside the refrigerator.
Mar 16, 2013 | Refrigerators
The refrigerator is running but will not cool eitherr side, a repairman changed a fan motor and bladebut is still wont cool. Is it worth spending any more money into it
Sounds like you may have a leak... can you tell if the compressor (black can in the back, bottom) is running also or not...if compressor is running and not cooling you may as well junk it....if the compressor is not running it maybe something more simple to fix...
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 15, 2010 | Samsung RS2630SH Side by Side Refrigerator
The freezer fan runs on and off constantly while its cooling making a hummmmmmmm hum hummmmmmmm hum hummmmmmm hum hummmmmmmm sound. its been doing this for some time now, but still seems to stay cold...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
Oct 24, 2010 | GE CleanSteel GSL25JFTBS
My refrigerator is almost constantly running. It stops for about 15 minutes and then turns back on. I have cleaned the coils, but this has not helped at all. Can this problem be fixed or is it time to...
Your cooling coils are completely clogged with dust and I'd check your refrigerant level. Clean first then keep an eye on it for two days then if no improvement in lowered temp call in a repairman for a refrigerant top off. $$$$ Expect over $150.00 plus!
Try an air tank with a long blow off tip to clean the dust off the coils. No simple task!
Jul 07, 2009 | Refrigerators
Amana bottom freezer refrig runs at maximum coolness
Thanks for your inquiry. I think I may have fixed it. I unpluged it and took everything out of the refrigerator and freezer, cleaned it thoroughly inside and out and unscrewed the back wall inside the freezer. There was a huge ice buildup on the coils so I let it sit for 12 hours like a defrost. I turned it back on and it seems to be working fine. It is not running constantly and is maintaining about 5 degrees below. If this doesn't stay working, I guess I have to call a repairman.
Feb 14, 2009 | Amana ABB1927DE Bottom Freezer...
Model 550
If its as warm as you say and the refrigerant is R134A his estimate of the pressure (4# is low for 38'F) is correct.
As for the leak I can only assume he sees something to make him believe its the evaporator.
As to the warranty (if its under 1 year it should all be covered. If its 2-5th year just the compressor is covered on some manufacturers others its the sealed system meaning leaks also).
And as far as $400.00? That's not out of line from my experience (limited by 30 years of doing this) I believe from what you have said about this fellow he knows his stuff and what it costs him to do business and that he will be around to perform your next service you need also. A rare thing to see these days. Even with hard times everywhere a business still has to make a profit and cover over head. Unless your AIG, GM, or Chrysler.
Jun 27, 2008 | Sub-Zero Bottom Freezer Refrigerator
Amana ATB2135HR Top Freezer Refrigerator Logo
208 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
