Question about LG 37LC7D 37 in. LCD HDTV
There is a constant buzzing sound coming from the back of my lg 37" lcd i returned the last one for the same fault and the replacement is the same any clues?
  • LG Master
  • 11,800 Answers
The sound is generated by the power source - it doesn't run smoothly because either it's defective (but 2 tv with the exact same defect one after the other is quite improbable) or you have a very bad mains power line, filled with interferences. Plug the tv thru a mains filter then check the voltage - if it's at 120 volts as it should and the sound is still there then return this tv also - you are really one of the unluckiest men alive.
Posted on Sep 07, 2010
Speakers in TV making a buzzing noise.
Try a reset to default settings. If that does not clear it I would suggest that it is either a hardware fault or interference
A constant buzzing might be interference from the power control card. What happens if you move the set elsewhere. Also, try it on another aerial, maybe there is a problem there....perhaps
Apr 25, 2015 | Polaroid FLM-3734B 37 in. LCD HDTV
Speakers had a buzzing/vibrating noise. had them replaced. still making same noise. happens on very low and loud volume. any idea what it could be? possibly the sound board?
maybe just poor speakers.....had a similar problem with an old sony. Replaced the speakers twice and always had a noticeable buzzing. Try running external speakers (computer speakers will work) at low volume to see if you hear it in those. If so, you may have sound board issue.
Jan 03, 2011 | LG 37LG30 37 in. LCD HDTV
The TV has red and green lines, I touched the
you willl need an LCD panel replaced the buzzing sound you hear is the broken floresent bulbs arching
Nov 30, 2009 | Vizio VW37L 37 in. LCD TV
LG DU-37LZ30
probably a power supply problem,modern tvs use switching power supplies. these power supplies sometimes fail after a long period of use due to the constant charging and discharging of the capacitors
Jun 07, 2009 | Sony QUALIA 005 46 in. LCD Television
Buzzing sound coming from TV Speakers and any external speakers
change your pre-amp ic sure it will work. or maybe cold solder from the board.
May 05, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
LG 37LG30 HDMI no sound problem
This is more probably a software fault within the TV. They need instructions for HDMI inputs & a no sound is a related fault. I would get in touch with your dealer to arrange the TV to be updated to cure this problem. Hope this helps.
Apr 11, 2009 | LG 37LG30 37 in. LCD HDTV
37" lg television
sounds like u have a dead solder joint or loose connector. poor workmanship LG (formerly known as GOLDSTAR is known for)
Dec 05, 2008 | LG 37LC7D 37 in. LCD HDTV
LG RZ 37LZ55 37 in HDTV LCD Screen Dead
This is likely due to a failed power supply. Replacing the power supply board should solve the problem.
http://www.reviewcentre.com/reviews110919.html
Cr1spy
Jan 10, 2008 | LG RZ-37LZ55 37 in. HD-Ready LCD...
LG LC55 humming/buzzing
Have you tried adjusting the contrast? , have a similar problem with a 42'' lcd and it appears to be related to the contrast setting .If is set my contrast below 90% the buzzing sound stops.
This buzzing sound seems to be a common problem with LG TV's
Nov 24, 2007 | LG 42PC5D Television
LG 37LC7D 37 in. LCD HDTV Logo
281 people viewed this question
Computer Repairing
Computer Repairing
