Question about Acer Aspire 4315 Notebook
My DVD drive is not coming out. Whenever i restart the computer, it has some light blinking ,but when i push the button, it is not doing anything. My cd is insdie, I am new to electronics, please help. god bless.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 146 Answers
I think your DVD rom tray is stuck in the mechanism.
You can try this. Search for some sefti pi or some long but very thin rigid wire. look at the dvd drive. you wil find a small hole at the front of the body. insert the wire or the seftipin inside like 10 cm. you will feel like pressing a button by the seftipin or wire, i hope it will pop the CD tray out. Once it is out, remove your cd from the tray. open and close the empty tray few times, do not use lubricants as they will damage the belts inside..
It should work.
Cheers!
Posted on Sep 07, 2010
Testimonial: "Thank you son/ you said it true. this thing has started working. god bless. you know how to write dvds?please tell me how to do it. "
Problem stating up pc
check to see if your vga cable is properly connected at both ends i.e. at the monitors end as well as the computers end. In case it doesn't solve the issue then your vga port is damaged.
Aug 15, 2012 | HP Pavilion a1310n PC Desktop
Aux power led light is amber on dimension E521
I think your problem is your memory or video card.
Below are some steps that I recommend.
When you plug in the power cord is there any lights whatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the computer and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Maybe your power supply is bad. Sometimes there is enough power to make the power light or some other lights come on but not enough power to make the fan turn on or hard drive spin.
Below are links and info I found from Dell's Website based on your model.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/specs.htm
Controls and Lights Front of computer:
Power button - push button
Power light
green light - Blinking green in sleep state; solid green for power-on state.
amber light - Blinking amber indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this indicates a problem with the system board (see "Power Problems" in your Owner's Manual).
Diagnostic lights
four lights on the front panel (see Diagnostic Lights.)
Standby power light
AUX_PWR_LED on the system board
Hard-drive activity light
green light - When the computer is reading data from or writing data to the hard drive.
LAN indicator light
green light - Solid green indicates that a LAN (local area network) connection is established.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/adtshoot.htm#wp1056411
Jun 03, 2012 | Dell Dimension E521 (D10E16) PC Desktop
I defragged my computer, restarted, and now my monitor won't come on. When on button pushed, get a green power light but the monitor stays black - cannot get anything on screen :( Helllllpppp!
Please try booting with your windows DVD and see if you screen loads, on that boot DVD you should see an option to repair install, try that. But if after booting to your DVD you see your screen come up, just try a regular restart again before doing a system repair.
Feb 28, 2011 | Impression Products 7LSP Monitor
My DVD drive will not open and when I manually open it and insert a disc it will not play. The yellow light blinks when I press the eject button and when I reinsert to drive, but that is the only response...
The only thing that you can do is to take the notebook to a qualified computer technician, to disassemble your computer, remove the "dead" DVD drive, install a new drive, reassemble your computer, and test it.
Nov 18, 2010 | Toshiba Satellite A305D-S6835 Notebook
The DVD tray doesnt eject
either it is the ribbon wire, the motor that ejects the tray or the belt that connect the tray and motor is the problem. In case the above three are fine, replace the drive as the sparking might kill your moterboard.
Jul 08, 2009 | Compaq (CDD480172) CD-RW Burner
1998 Expedition Blinking Overdrive Light on shift handle
When the o/d light is blinking that means there is a trany issue.My suggestion would be to have the computer scaned for codes and then get back to me and I will try to be of further assistance.
Mar 06, 2009 | 1998 Ford Expedition
There is a DVD in the player that wont eject or play.
Instead of a pinhole, there is a slot on the bottom of the DVD player that will force the disc out. There's a plastic lever visible on one side of the slot. I used a butter knife to push into the slot.
Nov 29, 2008 | Philips DVP642 DVD Player
Power light blinking yellow after sitting a while
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS or something), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on).
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS or something), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Oct 11, 2008 | Dell XPS 200 PC Desktop
Led light will not light
dvd citizen i need a code please
Jan 08, 2008 | One For All URC4220 Remote Control
Acer Aspire 4315 Notebook Logo
128 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
