Question about Kuppersbusch K EGS 304.0 J Stainless SteelCooktop
We have a GC2227DEDB fridge freezer it has a waterleak any ideas
Geohgh -- GC2227DEDB Kuppersbusch/Maytag Refrigerator/Freezer - If in high humidity area then water condenses between the outer skin and inner skin. Builds up and then releases once surface tension limit is reached. Releases about 250ml to 500ml or more in some cases, directly onto the floor. Solution is to make or have made a Stainless steel tray to fit under the refrigerator. Motor heat then evaporates the water.
Posted on Oct 18, 2010
How do I remove based grill
You should be able to get your fingers behind it, either on both ends or underneath. You MAY POSSIBLY need to open the freezer door a little and hook your fingers behind the top of the grille.
Jul 31, 2014 | KitchenAid KFXS25RYMS
G E Select ice maker has stopped making ice
First, check the filter and make sure it isn't clogged. Second, check the water line and more importantly, the valve that feeds the water to the fridge. It should be 1/4'' line and usually has a saddle valve installed off another larger cold water line. Saddle valves have a tendency to rust and clog. these are simple fixes, generally. IF all these check out OK, Check the water valve inside of the fridge, where water line comes in..Hope this solves your problem.Good luck DW
May 11, 2014 | GE Ribbon Module for Select-Top Modular...
I have had the KFIS29PBMS french door refrigerator for 2 days and the freezer drawer on the bottom right side if full of ice/frost on the outside of the drawer. What is wrong? What can I do to fix...
The seal on the door is not making contact with the fridge. Take a hair dryer on moderate heat setting close the door and heat up the seal where the frost is until it gets flexible and makes contact with the fridge for a good seal. Should happen in about 30-45 seconds. I had the same problem, waited around all day for a service tech to come and he did this in a minute. I was not happy and was like why did you not just tell me to do that over the phone.
Jun 15, 2013 | KitchenAid KFIS29PBMS
Temp alarm chimes can't find control pad to turn it off
look on the internet they might help you , type in the info you have about it.
Nov 10, 2012 | Maytag MBF1958XES - 30% E-Star, 19 Cu....
I have bleach stains on my stainless steel fridge. How do I remove them?
Here is a product that truckers use to get their stainless all bright and shiney... :-)
Mirror X
heatman101
Sep 24, 2010 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Does not make ice
there a lot of could be's / so look for a frozen inlet tube wher it dumps into tray / a bad water valve./ freezer tempt must be below 15 deg. for ice maker to cycle . and most common the ice maker itself may be bad . mm . if more info is needed and thes didn't help nee model & brand .. mm
Dec 12, 2009 | Cooktops
I have a magic chef refrig mod#RB21KW4AF. The fridge door is leaking cold air from the handle side of the door. I changed the door gasket, but it didn't help. The door doesn't have the same suction seal as...
rerack the door ( loosen screws and adjust door / also ck door hing cams if bad replace / this lifts the door and aids in the close .. mm
Nov 22, 2009 | Cooktops
Caple gas hob igniter
If you have an idea of what you are doing, it is pretty simple.  Just make sure the stove is unplugged.  If you have no idea what to do, it is better left to a professional or someone you know that is a jack of all trades.
Mar 03, 2009 | Cooktops
Kuppersbusch K EGS 304.0 J Stainless SteelCooktop Logo
211 people viewed this question
Top Kuppersbusch Cooktops Experts
Colin Stickland
Colin Stickland
Gil Shultz
Bill Boyd
Are you a Kuppersbusch Cooktop Expert? Answer questions, earn points and help others
