Question about WYSE Winterm 3125SE Network Terminal
Having screen resolution problems - WYSE Winterm 3125SE Network Terminal
  • 1,179 Answers
Good day,
I have compiled a published guide in this regard. I hope that I am able to assist you in this way. If you are still having troubles, please tell me what I can do. My guide is entitled How to set your Desktop Screen Resolution?
Thanking you
damnor01
Posted on Dec 20, 2010
I have a Samsung SuncMaster 940BW 19'' LCD Monitor. It's a geat Monitor in my humble opinion in everything, except that since i got it i have one problem with it, and it wasnt possible for me...
This is a common problem with monitors when changing resolution. What probably happened is you may have tried to change the resolution, or an application changed the resolution, to an incompatible resolution.
For example, if you have a tiny little screen it can't display that huge resolution that a 32 inch monitor has. So, your monitor is stuck in that wrong resolution.
To fix this problem, you need to boot into Safe Mode. Restart your computer, and as it is booting up tap F8 a bunch of times, and then select Boot into Safe Mode.
When it boots up, right click on the desktop, click Properties (Windows XP) or Screen Resolution (Windows 7). When the window pops up, click Settings (if on Windows XP, if on Windows 7 skip to next step). From this window, change the resolution back to the basic 800 x 600 screen resolution.
Now, reboot your computer normally. You should be able to see the desktop. Now, you can do the same thing that you did in safe mode and turn up your resolution. BUT, when you change it, if the screen goes BLANK again, DO NOT press anything. After 15 seconds it should go back, and you can try a lower resolution.
Hope this helps! Thanks for using FixYa.
Aug 27, 2011 | Samsung Syncmaster 940BW LCD Monitor
I have a problem with my screen resolution size.earlier i was using 1280 by 720.i installed a game and it asked me to change my screen resolution to 1024 by 768.i changed my screen resolution to 1024 by...
Click START then Control Panel then double click on the Display icon
Select the Settings tab and move the slider to the right for maximum supported resolution. Click Apply then OK. This should put the resolution back to normal.
Mar 09, 2011 | Computers & Internet
I have SAMSUNG LCD 943 MWX monitor which is 19"
This is not a monitor problem.This is a mother board problem, some mother boards are supporting this resolution.For this problem,you have to replace the mother board or put the graphics card on the same mother board.your problem will solve.
Feb 18, 2011 | Samsung 943NW Monitor
My system is workin properly but the screen resolution is very dim it seems to be very light ..... even we can't read any thing on that. i checked my monitor with another cpu its working properly can...
IT IS NOT HARDWARE PROBLEM
Change screen resolution
Screen resolution refers to the clarity of the text and images on your screen. At higher resolutions, items appear sharper. They also appear smaller, so more items fit on the screen. At lower resolutions, fewer items fit on the screen, but they are larger and easier to see. At very low resolutions, however, images might have jagged edges.
For example, 640 × 480 is a lower screen resolution, and 1600 × 1200 is a higher one. CRT monitors generally display a resolution of 800 × 600 or 1024 × 768. LCD monitors can better support the higher resolutions. Whether you can increase your screen resolution depends on the size and capability of your monitor and the type of video card you have.
21b7b862-a70d-43aa-a281-e00c38a8078d.pngText and images are sharper and smaller at high screen resolutions
2aca9658-0ee7-4b8d-a582-cac335550f26.pngText is larger and easier to read at low screen resolutions, but images are blocky and fewer items fit on the screen
  1. Open Display Settings by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
  2. Under Resolution, move the slider to the resolution you want, and then click Apply.
Nov 13, 2010 | Intel D945GCCR Motherboard
I have samsung syncmaster 740nw how can i increase screen resolution to 1024x768?
you cannot set the resolution to 1024x768 but instead try 1280x720 or if you have graphics card try to set the resolution using its custom resolution by setting 1280x768.
It will surely solve your problem.
-ravi
Dec 31, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Asus eee pc resolution vs. screen
Your computer does not support any resolution greater than 1024X600, anything other than that you will have issues.....
Display Screen Size: 10.0" Display Type: WSVGA Max. Resolution: 1024x600
Oct 12, 2009 | ASUS Eee PC 1000HA Netbook
Wobbly screen image
Are you connected to a PC (DIGITAL SIGNAL)or a video source?
If you are getting a jumpy screen from a digital source like a LATTOP/PC you many be feeding a signal that's not equal to the resolution of the projector itself.l There is circuitry in the projector to attempt to convert the resolution of the picture received into the screen resolution. It's an imperfect process, especially if you have a higher screen resolution going in than the 1024 x 768 native resolution of thie LX-1.
What you need to do is set the video output of the computer to that resolution.
The original LX-1 Infocus units had a less capable resolution resolving circuit than their later units.
In a portable, it's possible to setup two resolutions - one for the Laptops own screen resolution and another for the auxilliary (external) resolution of a secondary display or a projector attached there. Modern Laptops usually have a resolution of 1400 x 800 pixels or higher (mine are 1920x 1200), The LX1 can not handle that resolution well at all. If you set the external output to something slightly higher like 1200x800 it will handle it better, but you still will have problems, especially on the older units from Norway.
(I seem to remember some control over phasing in the LX-1 setup, too. but this might be more applicable to a video input rather than a digital one.)
Jun 05, 2008 | InFocus Proxima UltraLight LX1 Multimedia...
Screen resolution
The correct resolution is probably 1440x900. iF it is at that resolution, then tell me is the black part on all sides of the picture on just on side or the other of the picture???
Dec 26, 2007 | Gateway 6525GP Notebook
Problems with screen
try these options, follow their order, it goes from the easyest and on: 1. every screen has maximum resolution, maybe the resolution you pick is higher than screen possibilities. 2. this may also be a resault of computer not recognizing screen. check windows defenitions, make sure windows recognizes the exact model of your screen. 3. reinstall drivers, reboot. 4. if problem is in hardware, you have to find what part is causing the problems. try connecting the screen to a new computer, try another cable, etc.
Feb 22, 2006 | LG Flatron 995FT 19" CRT Monitor
WYSE Winterm 3125SE Network Terminal Logo
216 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Tim Hunt
Tim Hunt
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
