Question about GE Vacuums
I need a thermostat for a GE toaster oven sold by Walmart. The model listed on the back is 106632 Series B2810AT. The thermostat has stamped on the frame ABUND No. 228. Apparently Abundance Co. in HK makes thermostats for these and sells them under the name ABUND. However I find no source for these in the USA and do not want to buy a large quantity which is usually the requirement when dealing with these Chinese companies.
  • 17,970 Answers
If you have a warranty claim or need spare parts or accessories, please call our Customer Assistance number. 1-877-207-0923 (U.S.) or 1-877-556-0973 (Canada)
For faster service, please have the model number and product name ready for the operator to assist you. The model number can be found on the front page of your manual and on the bottom of your appliance.
Hope helps.
Posted on Sep 07, 2010
I need the broiler rack for my Euro-Pro extra-capacity toaster oven
Not sure where you live, down here in Texas we have a store called Lone Star Hardware. If you bring them the broken version of what you need replaced or the oven, they will find the handle and right sized screw to fit it at a very reasonable price. If you don't have a store like this locally, I've also gone to Walmart with the broken version of what I need replaced and spent some time looking for something that will work
Aug 29, 2014 | Vacuums
Delonghi toaster elements are losing their heat
There are three likely problems:
1. The toaster and/or heater elements need to be cleaned. If they get coated with food material they will not function correctly.
2. The heater element could just be going bad. You would need to search the web with your model number to find the appropriate replacement part then open up the unit sufficiently to disconnect the old elements and replace the new elements. You need to ensure that the connections are correct because loose connections would not permit sufficient electricity to enable the elements to heat up.
3. The thermostat could be going or gone. This controls the amount of power provided to the elements and thus determines how much they heat up. Again, you would need to search for replacement part.
Aug 11, 2011 | Vacuums
My toaster oven elements heat up pretty quickly and then go out for a few minutes and them come back on and keep doing that....toast doesn't get done because of it and tonight I tried to cook some hot...
You trouble is intermittent operation. Fix it by checking the thermostat and power button switch also the cord. Check it use a analog tester set to Rx1. All of that is test through continuity, so if there no fluctuation in the meter reading, there is defective parts. An intermittent part(s) operate sometimes good and sometimes bad. Check those parts carefully.
Good luck.
Jul 17, 2011 | Vacuums
I have bought a shark cordless vacuum sv779z 14 from walmart, at first it worked well, but lately the suction is ok when i switch it on, and them immediately decrease until there is almost no suction. I...
If it's been less than 30 days take it back to Walmart and tell them to give you another one. If it's been past 30 days they won't. Shark doesn't have it listed because they don't make parts. The warranty should cover it though so stay persistent .
Jun 06, 2017 | Vacuums
I cannot find the link to register my new convection toaster oven.
I would like to see if I could help you but, maybe I'm missing it, but I don't know what kind of toaster oven you have.
<a href="toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 15, 2011 | Vacuums
Manual for GE microwave spacemaker oven GE proffile
here is a website that can help you obtain a manual
Of course they will need the model number of yours
http://www.google.com/search?client=ubuntu&channel=fs&q=manual+for+GE+microwave+spacemaker+oven+GE+proffile&ie=utf-8&oe=utf-8
Sep 03, 2010 | Vacuums
My front spin brush stopped working but everything else works
You will need to replace the belt. Remove the screws from the bottom of the unit. Then remove the brush roller. You should be able to see the belt, if not you'll need to look on the upright part of the unit and ge tthe belt's "code" usually a letter. You can usually find the belt at walmart or wherever vacuums are sold.
Sep 30, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Change belt
Turn the vacuum upside down so you can see the bottom of the head (the part that comes in contact with the floor). There are screws that need to be removed so the plate can be taken off, remove those screws. Now the brush is accessible, lift the brush out just enough to slip the belt on then after making sure the belt is still on the motor, push the bruch back into its place. Then replace the plate and screw it back together and you are done.
You are probably going to have to get a new belt, if you do you can usually get a replacement at WalMart for cheap or you can go here: http://www.dealtime.com/xPO-Eureka_Vacuum_Belt_Style_U_Extended_Life
If you decide to go to WalMart, look for the belt that says "Fits Eureka 5800 series...", it will list others too but as long as 5800 series is on the package it will work. Hope this helps!
Sep 25, 2009 | Eureka Whirlwind Litespeed 5840 Bagless...
Hello . The beater bar is not spinning on my Hoover bagless upright rewind. Can I fix this?
very simple to repair its a broken belt read owners manual or somtimes they print instructions on the head of vaccum belts are sold at walmart you must know make and model or get number of old belt. before buying one check the back where the attachments are some cleaners have spare belts
Jul 20, 2008 | Hoover Vacuums
Vacuums Logo
489 people viewed this question
Top GE Vacuums Experts
Gerry Harvey
Gerry Harvey
ray gallant
Are you a GE Vacuum Expert? Answer questions, earn points and help others
