Question about LG Washing Machines
I have had my WM2677HSM Washer for a few years and I love it! However, some black mold and musty smell is evident on the Rubber sealer on the inside opening of the machine. I try to wipe it dry as often as I can, also leave the door open overnight to let it dry....but the unpleasant moldy smell persists. What can I do?? Kind Regards, Cathy
  • LG Master
  • 8,220 Answers
You could give it a good wash out using Tide washing machine cleaner. Directions HERE
Posted on Sep 07, 2010
Samsung wf410 musty smell clothas
you ahve to treat this with bleach first and try some cleaner they have a few on the market for this, then spray inside of door with bleach or window cleaner it molding inside, most people leave the door cracked open and the soap dispensor open to let the washer dry out during washes, inst this the Pitts, Matt
Jun 12, 2012 | Samsung WF410ANR Washer
It has a musty smell
Step one: Identify the source. Try switching to a high efficiency powder detergent instead of liquid. (Suds collect in nooks and crannies.)
Step two: Clean. First wipe the inside of the washer, especially the area where the door seals to the inside. Mold can collect around the insides and folds of the rubber seals. Get in there and make sure you cleaned it all. You could use bleach or Pinesol.
Step three: Use a quarter cup of dish washing detergent (powder is best, liquid if you must), along with a towel. Put the machine on the "sanitary" (hottest water) setting. Let it finish its cycle. This should get rid of the mold completely.
Step four: Leave the door open between wash loads. This will decrease the mold build-up as it allows the tub to dry completely
NOTE: IT WILL TAKE 2-3 WASHINGS TO TOTALLY RID THE CLOTHES OF THE MUSTY SMELL.
Hope it helps!
Aug 22, 2011 | Whirlpool Washing Machines
Washer smells even after cleaning cycle
It sounds like an air vent is either missing or clogged. That gurgling usually indicates some sy phoning action going on which is drawing water out of a gas trap. Hence you are getting sewer smell into the washer.
Thank you !!
Jun 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
There is mold around the rubber and in the inside of the rubber on my Front Load. How can I get rid of this? Is there a product to clean front load washers?
Hi.
The mold is an enzime from the washing detergent or softener. It attacks certain rubbers and causes them to turn black. Eventually it will cause a musty smell which will go on the clothes.
The only way to remove is by replacing the door seal.
If you try bleach etc then it will cause the mold to get worse.
Hope this helps
Aardvark Repairs
Nov 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Musty smell in washer and clothes.water remains in rubber gasket
Two thing that you might try: Add two or three cups of bleach and have the machine run a cycle (with no clothes!!!). Second, always leave the door open after use to let it air out. Also, it wouldn't hurt to use straight bleach as a wipe to the entire rubber tub seal.
Jun 05, 2009 | Frigidaire ATF6000ES Front Load Washer
MY FRONT LOAD WASHER STINKS! THERE IS A MUSTY ODOR COMING FROM INSIDE.
Switch from liquid to powder detergent, no fabric softner (I know...I love it too), clean the gasket and run a cycle with bleach only. Leave the door open whenever possible. This fixed my smelly washer, now if it would only spin!
Jun 02, 2009 | Frigidaire ATF6000ES Front Load Washer
Smell
One downfall of the front load machine that it holds moisture causing musty smell in drum. Try leaving door agar between washes and use a cleaner specific for front load smells 1 every month.
May 29, 2009 | Frigidaire ATF6000ES Front Load Washer
Mould on Rubber Seal and Musty Smell
bleaching hte rubber will help, you need to check your detergent, you MUST be using an HE detergent, specifically designed for frontloading machines, leaving the door open as well between usage, and running more than just cold washes, HOT water definalty helps.as far as efficincy this machine uses abouit 1/3 of hte water the top loaders do. 13-16 gal, versus 45-50 gal. so an extra rinse is not going to amount ot much. there are also products such as www.AFFRESH tabs, or even "dishwasher magic" has been known to reduced the smells/odors in oyour washer
Dec 22, 2008 | Washing Machines
The bin stinks like mold
Have had machine for 6 years.  Mold is an issue.  Occatioinally I clean out the drawer and behind the grey rubber seal with vinegar.  After a load is washed, I dry off seal and leave door slightly open.  Occationally I also wash a load of nothing but bleach.   Hope this helps.
Dec 30, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
125 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
