Question about Xerox WorkCentre 220 All-In-One Laser Printer
Xerox PE 220
My workstation says document jam, I have opened all doors possible and also taken out cartridge etc. Fuji Xerox suk when it comes to support x phone jhave been given 4 seperate nos and still no help
I know this is an old problem but I thought I should add this for the archives. On a couple of Xerox copiers I serviced the paper jam error was caused by a tiny piece of paper blocking the optical sensor. On the inside walls of the "U" shaped optical sensor are tiny holes (about 1mm diameter) through which light passes from the LED to the sensor. A tiny piece of paper was actually stuck in one of the holes which the copier interpreted as the flag sitting inside the "U", thus the paper jam error.
Blowing through the "U" is usually sufficient to remove the tiny bit of paper.
These bits of paper end up inside the machine as a result of users trying to forcibly remove paper jams and end up tearing the paper sheet instead.
Posted on Apr 23, 2009
First with any jam message, identify if you have actually had any paper jam in it in the first place, especially if you are turning up to site and you're getting 2nd hand info. IE "oh no it just said that ...one day"
so assuming it actually had jammed paper in it that was removed at some point, find out where it was jammed...front or back. how it was removed...via front or back. note! many printers dont like having paper pulled out in the reverse direction to which the paper normally travels, this sometimes catches little flags and breaks them or pulls them out of position and the little photo sensor that is normally closed is then left 'electrically/optically' open so the printer sees this as a jam as soon as its finished booting up.
okay assuming you have gathered reliable info re the above.
check that area of the path for what looks like a small swinging flag, or maybe a little black 'U' shaped sensor that looks like it should have a flag in it.
remember the print will/can only say there is a jam if a sensor is stuck..open/closed or how it 'shouldnt be normally.
if you're out of luck you may find the pieces of a flag loose in the unit.
ideally they have a bit of flexability and just pop out.
BIG rule...dont force 'remove' jams. if it wont come out, contact someone with a bit of mechanical ability, even if they arent a printer tech, (like myself) then at least they have an 'intact' unit to work with so they can see how its supposed to work and just pull it apart to clear the prob area.
ok...so assuming you've found the area, if the flag is broken i wouldnt try making bits up to do the job, timing is critical, unless you can glue it back together exactly right then dont bother, you'll likely get timing related jam messages. just contact the manufacturer, see i you can get a part number. it may cost you a few bucks for a bit of plastic but its the best way trust me.
HP, lexmark, and fuji xerox i have found pretty good with parts down to a small level. some other brands i wouldnt touch with a barge pole.
after all this. most jams are in the fuser and most people are rough as guts and usually break something in the fuser by yanking it cos they're angry.
most fuser can be sort of pulled apart into sub components (although its not expected in my industry) so if you have an intact fuser but its got a heavily 'fanfold' paper in it so tight you dont even know its there, dont dig it out with a screwdriver, if you score or scratch the surface of the rollers then you done your money there. better to look at it for a bit, try to work out how to loosen it apart and remove the jam, inspect the rollers for scratchs or damage, andreassemble it.
(15 years repairing this gear, the methods are pretty much similar thinking for most printers when physical issues are the prob.) best of luck. - keith
Posted on Jul 01, 2008
Hi, thanks in advance for any solution suggestion. My xerox pe 220 prints blank page. Cartridge is new. Th poblem should be with the driver, installed it several times, but it doesn't help. Can anybod
Does it sound like it's trying to print or does it just quickly spit out a blank page. If you print something three pages long, do three blank pages come out??
I know this may sound silly, but did you remove the piece of tape that covers the contacts on the new print cartridge?
Nov 25, 2013 | Xerox Computers & Internet
Fuji Xerox cm205fw keep getting paper jam message
Just for any others with this question, I have been plagued with the same problem with my CP205 and CM205 printers, and discovered with the CM205 that it does still have a small scrap of paper left in the end of the paper path, near where it ejects. This can't be seen if you are looking inside the printer from the back door, hence anyone thinks it's clear, but if you open the main top door, by lifting up the control panel, and shine a torch down there, that's where you will probably find the small scrap of paper, which is stoping the printer from working. I managed to remove mine with a set of small tweezers. It would help if the machine could give you a more accurate error message, eg, lift the TOP door and remove paper jam.
Cheers, Vaughan
Jun 25, 2012 | Xerox Office Equipment & Supplies
We have a Fuji Xerox 7435 printer and it shows an error message saying A fault has occurred switch machine off and on. The message error number is 116 324. We have tried to turn it off and on unplug etc...
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Sep 02, 2011 | Office Equipment & Supplies
Keeps showing "document jam" even though the jam was cleared
Most likely one of the jam sensors was knocked out of its clip. You would have to take the document feeder off and apart to find and reseat it.
Mar 25, 2009 | Xerox WorkCenter PE120i All-In-One Laser...
XEROX 6110 coloer printers
Xerox 6110 Code Description A1-1 to A1-32 All indicate a paper path problem, etc. in the ADF A2 ADF exit problems A3 Irregular size documents A5 ADF interlock A6 ADF single sheet document reset A7 Platen interlock A8 ADF exit interlock C1 Tray 1 jam C2 Tray 2 jam C3 Tray 3 jam C6-1, C6-2 Jams related to duplex C6-3 Registration sensor, re tray 1 C7-1, C7-2 HCF feed problems C7-3 Tray 1 feed problem C8 Paper stays in tray or duplex or HCF C9 Bypass feed problem E1-10 to E1-25 Internal jam E1-6 Paper on registration sensor E2 Reset signal happened. Might read E-2 something else E3-30 to E4-14 Exit jam E3-6 Exit jam E4-10 to E4-14 Inverter sensor not actuated E4-15 Inverter sensor E4-40 to E4-45 Duplex entry sensor E4-6 Inverter sensor E5 Front door interlock E6-1 Tray 1 interlock E6-2 2 tray or duplex interlock E6-3 HCF interlock E7-2, E7-3 Duplex interlock E8-6 to E8-15 Duplex entry sensor F1-1 Sorter entry sensor F1-6 Sorter exit sensor F3 Paper size not available for sort/stack F5 Sorter interlock J1 Add toner J3 Replace copy cartridge J7 Replace copy cartridge J8-1 Wrong copy cartridge installed J8-2 Copy cartridge EEPROM L6 Auditron or other counter problem L8 Platen glass temperature is too high L9 Communication problem between interimage erase/edge lamps and main board U1-1 Main motor drive problem U2-1 to U2-4 Scan home sensor U3-1 Lens sensor U4-1 Open fuser thermistor U4-2 Fuser did not warm up properly U4-3 Fuser temperature too high U4-4 Fuser problem. Staying on too long U4-6 High fuser temperature U5-1 Sorter bin home switch not activated U5-2 Sorter bin home switch stayed actuated U5-3, U5-4 Sorter bin home switch U6-1 ROM problem U6-2 RAM problem U6-3 Low battery U6-4 Incorrect value in NVM. Reinitialize main board with code 20-96 U8-1 to U8-6 Problem with exposure lamp, lamp sensor, lamp board
Jan 03, 2009 | Office Equipment & Supplies
I can not scan in xerox pe 220
I found the solution today. First you go to Autralia Fuji Xerox website at http://www.fujixeroxprinters.com.au then select Driver - Xerox WorkCentre PE220. Download the Control Centre and Scan to PC together with WHQL_PE220_2K_Vista_SCAN (scan Driver) and WHQL_PE220_2K_Vista_GDI.zip (GDI Driver). Setup files are in Control Centre and Scan to PC folder. The rest will pop up new hardware found and browse to two other files dor perfect driver.
Hope this help because it's help me today. Thanks to Miss Chin from Pineaple Computer Store One Utama Malaysia.
Nov 01, 2008 | Office Equipment & Supplies
LSU ERROR DISPLAYED FOR XEROX WORKCENTRE PE220
Hi Dear
I am facing LSU Error on my Xerox workstation PE 220
I am not able to do anything, please let me wat to do
i have lot of work penindg
urs
mujahid
May 25, 2008 | Xerox Phaser 8500/DN Printer
Xerox WorkCentre 220 All-In-One Laser Printer Logo
855 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
