Question about Grohe 28.275.AV0 Relexa Plus Top 4 Spray Shower Head - Infinity Satin Nicke
The shower head has a leak around the ball area
    Sergeant:
    Novelist:
  • 193 Answers
Take the showerhead off above the ball. You may need to hold the pipe with one wrench and turn the showerhead with the other. Put teflon tape on the threads that are exposed on the pipe and then put the showerhead back on as tight as you can get it.
Posted on Sep 07, 2010
Leaking at the ball joint..how can i fix the shower head
undo the nut that holds the shower head on ( bit behind the ball) and inside there is either a rubber washer or a fiber washer
replace that and do it up
Aug 19, 2016 | Hansgrohe Home
How do I fix a dripping shower head in a stand-alone shower? We have already tried to replace the valve assembly but it still leaks.
Obviously this is a leak in the valve. They are no fun to work on. Some of the higher end models of valve have seats that you can change and along with the ball and other hardware, that should stop the leak. If not you will have to replace the whole valve assembly.
Dec 16, 2015 | Home
The water coming out the shower jets is not powerful, help?
follow this steps and fix it. God bless you
If a faucet leaks, replace seals and gaskets .
If a shower head leaks, create a better seal or replace seals .
If a sillcock wears out, replace the washers .
If a compression faucet drips from the spout, replace the washer and/or the seat .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type .
If a ball or cartridge faucet leaks from the collar, replace worn O-rings .
If a disk faucet leaks around the base or has reduced flow, replace cracked or pitted disk assembly or worn inlet seals .
If there is water under the sink, tighten the faucet-set locknuts under the sink. You also can replace putty or a gasket, replace a worn faucet, or replace leaky supply tubes .
If the aerator leaks around the edge, replace the washer in the aerator .
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head .
Nov 25, 2013 | Home
I have a delta in2ition shower head. The shower arm has a water outlet head that is screwed down onto it (the water outlet head is round like a ball and has a hole in the middle of it from which the water...
Take the gasket to your local hardware store and have them match it up.The answer is no, the gasket is not supposed to be split. It was probably tightened too much.
Jul 24, 2011 | Delta & Single Handle Shower Faucet
I have a Moen shower faucet that is six years old(copper sweated plumbing). My wife noticed water dripping profusely from the downstairs ceiling during my shower. The screws holding the face plate were...
Try removing the handle, then the face plate. With a flashlight handy, check inside the wall around the valve to see if you see any leaks. Then, try the valve by pulling the stem (may need a plier to grab this). Keep checking inside the wall. Next, try the shower, and again watch in the hole you have. You may find that the connection(s) to the valve is/are leaking, particularly at the top of the valve where the shower pipe heads up the wall. Or, it may be that the shower head's arm is leaking somewhere above. If you only see water dripping down from above, try the flashlight with a small make-up mirror to see if you can see where it's coming from. Sometimes the pressure in the shower head builds up from the flow restrictor, or the head's spray holes may need cleaning out (try soaking the head in a solution of CLR [stands for Calcium, Lime, Rust] available at most home improvement/ hardware stores). Sometimes the shower arm (the bent 1/2" diameter pipe that the shower head mounts to) isn't fastened in tightly enough. A good trick to help here is to wrap the threads with teflon tape, then apply teflon paste also. Wrap the tape clockwise around the threads so that it doesn't unwrap when you screw the pipe back into the fitting in the wall. Also, make sure the threads in the fitting in the wall are cleaned out, and don't let any debris contaminate the new teflon paste as you slip it back through the hole in the wall. If you find that the pipe out of the top of the valve is leaking, I recommend you call the plumber. He/she can likely fix it without taking the wall apart.
Aug 27, 2010 | Moen & One Handle Tub & Shower Faucet
Leaky shower head
If you replaced the seats and springs and the problem continued you may need to get a whole rebuild kit including the ball and replace that one as well
Jun 27, 2010 | Delta & Single Handle Shower Faucet
Its having some leaking how can i stop that?
If Leaking from the hose connection you can replace the washer, which you can get at any plumbing/hardware store. If leaking around the head area depending on the make and model, most always in the cheaper ones you just have to replace the whole head. Thank You for using FIXYA, good luck. Jeff
Mar 21, 2010 | Alsons Delta Seven-Spray Massage Hand...
The shower head was in place for over a year. Then when my daughter was taking a shower the whole ''T'' head flew off at her. I've tried to reinstall a couple of different times but it keeps flying off...
just replace your shower arm that is what the shower head is connected to make sure you use teflon tape around the threads on each end of the shower arm that should do the trick
Mar 07, 2010 | Culligan & Hand Held Filtered Showerhead
Water leaks from the shower head. I have a delta
You may want to replace the ball or cartridge whichever the case may be. Also be sure to use Genuine Delta parts as they will hold up much better than the aftermarket parts. I hope this helps.
Oct 28, 2009 | Delta T13420 Chrome Classic Single Handle...
The shower hose leaks from the connection between shower hose and
have you tried teflon tape? wrap it around about 7 times and you will be fine.
Jun 24, 2009 | Grohe Movario 59" Metal Shower Hose -...
Grohe 28.275.AV0 Relexa Plus Top 4 Spray Shower Head - Infinity Satin Nicke Logo
259 people viewed this question
Top Grohe Home Experts
Mike
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
