Question about Tools & Hardware - Others
I have a challenge 4 in 1 stapler that is refusing to staple, the staples are the correct size and I have tried adjusting the tension knob on top of the handle,,,any suggestions please,Thanxs
  • 10,865 Answers
Hi Linda. Get a can of penetrating lubricant called WD-40. Two squirts into the stapling mechanism, let it sit for 30 minutes and try again. Repeat if necessary. J.
Posted on Sep 07, 2010
Replace a staple unit in a di 3510 minolta copier
Sattle stich stapler or the corner stapler.
Corner is inside the machine open the front door turn green knob to bring stapler out then remove the blue/green cart. do not throw a way you will be replace the staple not the whole cart.. Sattle stich is the stapler that make you booklet with to staples in the middle. will be up on top of the finisher but under it same deal do not cast away replace staples only and make sure that you pull out the top section and reseat so the copier knows you replace those staples
May 27, 2014 | Minolta bizhub 250 Black and White Copier
Help please! I have a Paper Pro high capacity stapler that will not staple. I can open it up and put staples inside, but no staple will come out when pushed down. Oddly enough, if I put ONE staple inside...
are you using the correct size of staple?? (thickness wise) secondly check the spring is pushing as it should, also a fix to get it working is as you put the staple stack into the stapler, seperate them and see if will staple. other than that it's defective and you should purchase a new one.
Oct 30, 2013 | Staples PaperPro 1200: Heavy Duty Stapler
What kind staples p300 stapler brad nailer
Staple Size 3/8 in. Crown Width, 1/4, 5/16, 3/8, 1/2, 17/32, 9/16 in. length
Brad Size 18 gauge, 3/4, 1, 1-1/4 in. length
Magazine capacity 100 staple/brad
These are sold at Lowes and other lumber centers.
Oct 14, 2011 | Ryobi P300 One+ Stapler Brad Nailer
Problem with the Stanley Tools TRE550 Electric Staple/Brad Nail Gun Cannot get the staple drive flush help me please
First, try holding the stapler very firm to your project and make sure that the piece that you staple in to is backed solid with no give or springiness.
second, you might try shorter staples,or . . try dialing in more tension by turning the big knob on the back end that has the "+" "-"
Sep 11, 2011 | Stanley Tools TRE550 Electric Staple/Brad...
I have tried to reload the stapler but it will NOT staple What am I doing wrong?
1. Make sure you have the correct staples for the machine. This machine requires "standard" staples, which are 1/4" staples.
2. Check the staple cartridge to make sure there are no visible jams.
3. Check the power connection to the stapler. Is it plugged in? Is the plug working?
4. If you continue to experience problems, contact the manufacturer at
1-800-STAPLES. They will replace the stapler if it continues to malfunction.
Apr 18, 2011 | Staples One Touch High Capacity Stapler
I can't seem to reload staples into this stapler. I used the staples that came with it and it worked fine. I try reloading and it doesn't staple.
With the stapler sitting a solid surface, turn it 180 degrees so it is pointed away from you, and you are looking at the back. Press down on the plastic extension that you see (about mid-height on the stapler). This releases the staple-holding compartment (it shoots out the front of the stapler). Reload it with standard staples, push the compartment back in place until you hear a click. Voila!
Apr 15, 2011 | Staples One-Touch DX-3 Desktop Flat Stack...
WHERE do I open it to refill it??
Located on the end opposite of where the staples come out, there is a spring loaded cap. Push it in toward the base of the stapler and slightly down to release the retaining hook. then let the spring release the pressure rod and pull it out. Connedted to the end of the rod you will see a plunger that is shaped like a short run of staples. Make a mental note of how and where this plunger slides into the base of the stapler. Place a run of staples into the stapler in the same manner that the plunger fits then replace the plunger into the same place following the run of staples. Compress the spring into the stapler and attach the hook as it was. Now you are ready to work.
NOTE: If you cannot compress the spring enough into the stapler you have inserted too many staples, just remove some of the run of staples and try again.
Nov 12, 2010 | Arrow T50P ARROW STAPLE GUN
Problem loading gun..Where do we put in the staples and change the dial to accomodate it? fred
The staples should load in through the end of the hammer stapler. The end is spring loaded to push the staples forward, so push the end - usually a crome square - into the handle end then move that part up approximately 1/4 inch and pull back. The spring mechanism should slide out so you can add new staples. These staplers take a specific size of staple and a certain number to allow you to put the spring mechanism back into the stapler. If you do not know the correct size for your stapler someone at your local hardware store can help you find the correct size and they will probably even show you how to load it. Good luck!
Jul 07, 2009 | Ace Hardware Ace Heavy Duty Staple Gun...
Swingline Stapler Staples Only After You Open It Up....
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Dec 14, 2008 | Staples Swingline® 36115 Staple Guns Tools...
Stanley TR70 Manual Stapler won't accept Arrow 1/4" staples
It sounds like you have a light duty stapler and are trying to use heavy duty staples. 1/4" refers to the length of the legs not the thickness of the actual staple. You probably just need light duty staples.
Oct 06, 2008 | Stanley Heavy Duty Stapler, Cast Aluminum...
Tools & Hardware - Others Logo
80 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
