Question about Brother XL3750 Mechanical Sewing Machine
I have just started to sew and just bought the Brother XL 3750. The problem that I keep having is my spool of thread keeps falling off the machine.
    Genius:
  • 1,788 Answers
Pull up your spool pin that holds the thread, it is in the down position.
Posted on Sep 08, 2010
  • kschultz1062 Sep 09, 2010
    Thank you so much! No where in the manual does it say anything about pulling up on the spool pin. My problem is solved...........
  • Mary Dunn Sep 09, 2010
    You are right, that is why I figured with you being new, how would you know? They should say it in the manual because everyone is afraid of breaking something. Good Luck and Happy sewing.
Please help! I have a Brother Innovis 4000 embroidery machine. My machine is skipping stitches then the needle falls out or bends/breaks. This happens even after I changed the needle and rethread the...
I would double check your Threading. Make sure the thread coming from the spool is not getting caught on something. Try keeping the presser foot up, and then pull out some thread from the back of the needle, does it seem tight to pull? Now lower the presser foot, is it more difficult to pull out? It should be but not so much that it is bending the needle.
If it is to tight, there could thread caught in the tension discs. Remove the left side panel above the needle on the machine. Check to see if you can see any threads. IF not, lower the thread tension and see if that helps. Good luck
Apr 24, 2014 | Brother XL-3500
I just bought a brand new Brother XL 2600I and it was working great for the first day , next morning i change the thread to actually sew not just test strips . I keep getting bunches of thread or if i
Most likely your top thread is not threaded correctly. Unthread and rethread. Check with your manual to make sure you have threaded correctly. Thread bunching up on bottom indicates top thread is threaded wrongly.
Mar 05, 2014 | Brother XL-2600I
Singer quantum XL-150 how do i thread this machine?
All Singer models would have arrows/numbers to guide your top threading from the spool pin to top thread guide, for most machine start from your thread spool pin, to a thread guide follow arrow down then up into the take up lever and down to the needle thread guide then into the needle hole. Assuming you have wind and install the bobbin thread into the bobbin case, turn your hand wheel towards you makes the needle bar goes down,keep on turning till the needle bar is fully up again, pull the end of the top thread to pick out the bobbin/bottom thread. With your material/fabric under the presser feet, apply the presser feet lever down, you are ready to sew.
Dec 24, 2013 | Singer Quantum XL-1000 Computerized Sewing...
Sewing machine design
It sounds like the spool cap is broken or defective. It should fit snugly on the spool pin. If it is constantly falling off, then try finding a replacement. The horizontal spool pin design helps the machine pull the thread off the spool because the thread spool does not need to spin. The added pressure of spinning a thread spool contributes to tension issues (especially if you are using large thread spools that are so common now days).
On new machines, frequently the thread cutter is on the back of the presser foot lifter.
The thread guide above the needle is usually threaded from the left side because the thread tends to be pulled toward the right.
Unfortunately, what you are experiencing are pretty much common functions with most newer sewing machines, so even changing machines may not result in any greater degree of satisfaction.
Mar 31, 2017 | Singer Sewing Machines
With my Brother 3750 sewing machine, it is hard to thread because the arm that goes up and down does not come out of the machine "case". I end up trying to almost blindly put the thread through...
Hello, Cwpetronio -
I hope I am correct in thinking your Brother sewing machine is in the XL series of sewing machines. If so . . .
I think you will find the instructive illustrations here helpful:
http://support.brother.com/g/b/faqend.aspx?prod=hf_xl3750eus&c=us_ot&lang=en&faqid=faqh00000467_000
I would think the instructions for threading the machine are in the owner's manual. If you do not have the manual, you can download on free here:
http://homeappliance.manualsonline.com/manuals/mfg/brother/xl3750.html
Note: The manual is in PDF format, meaning you will need Adobe Reader software (free). After you download the manual, I recommend you save it in your Documents folder using a file name you can find again easily - Brother XL-3750 Manual. You can print the manual for easy reference.
Best wishes.
Jan 19, 2018 | Brother XL3750 Mechanical Sewing Machine
The thread keeps breaking and i lost the manuel for brother xl 5130
try rethreading machine
thread tension is to tight -try 3-5-see if that works better
change needles
thread might be caught around spool pin -tension dial
needle & thread may not be compatable-try this & see if it works for you
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Oct 22, 2010 | Brother XL-5130 Mechanical Sewing Machine
HOW TO THREAD THE BOBBIN
Take the thread-end from the thread spool to the left, around the bottom of the "silver" "button"; across the top of the button and back to the right to the bobbin winder.
Run the thread-end through a hole in the side of the bobbin spool, hold onto the thread (pull through about 5" of thread) and place the bobbin spool onto the the bobbin winding pin.
You may have to turn a bit to the left or right to get the spool in place. Push the bobbin spool to the right; against the bobbin winding wheel.
Press on the power pedal - keeping hold of the thread-end.
As the bobbin fills, the thead end will twist.
When you can not longer hold on. Stop the machine and clip the thread end then continue to wind the bobbin.
You can view and download a manual here (free) - http://www.brother-usa.com/manuals/default.aspx?PGID=3&R3ModelID=XL2230
Mar 25, 2010 | Brother XL-2230 Mechanical Sewing Machine
I NEED BUY THE BOBBIN CASE XL 3750 BROTHER SEWING
No problem, go to a Brother repair shop and buy one.
Feb 11, 2010 | Brother XL3750 Mechanical Sewing Machine
The bobbin winder post is broken. I am in search of replacement parts.
Just hold the spool with a dowel or pencil and apply pressure on the thread coming off the spool with your fingers so the bobbin will wind tightly and shift the spool as needed to keep it winding evenly. I also do this all the time with Cone thread by just standing the cone thread on the table in front of the sewing machine and holding the thread with one hand so it comes straight up off the cone and the other hand and fingers controls the tension and the even winding of the bobbin.
Aug 08, 2009 | Brother XL-5130 Mechanical Sewing Machine
Open Questions:
See all Brother XL3750 Mechanical Sewing Machine Questions
Brother XL3750 Mechanical Sewing Machine Logo
100 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
