Question about Intel Pentium D 915, 2.8 GHz (BX80553915) Boxed Processor
When computer Switch On button press computer will not be start and processor fan aslo not start so which problem accured on mother board or cpu? But Motherboard light is always on board provide power to all components on board but when on button press computer not start and also fan off. plz help me
  • Intel Master
  • 27,725 Answers
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty because a computer has to have an end to the circuit any fulty leads will lead to no boot up
good luck
Posted on Sep 07, 2010
As i press the start button, fan works for just only 1 or 2 seconds and stops. System does not starts. what may be the problem
Sounds like a bad connection between a processor (GPU/CPU) and the board. You can remove the components and reattach with Arctic Silver ($7 at RadioShack).
May 05, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Intel mother board power light is on... but processor not working.. when switch on my cpu. the mother board powerlight displayed.mother fan is only one time run for sec.. processor not on
This is was with me too. I know how to fix it. Remove all cables from your cabinet, i mean like keyboard, mouse, moniter etc. Remove your ram too. Then press your power button from 30 seconds. wait for 10 mins plugin all cables and turn it on. Hope it works for you.
Best of luck.
Jul 22, 2010 | Intel D945GCCR Motherboard
Hi. my CPU (system) does not start. When i press the power button, the light turns on for a second then nothing happens.
Does the power supply fan spin when you switch it on ??
Do you hear a"posting" beep??
Does the CPU fan start to spin??
If no to all of these probably dud mobo.
Dec 21, 2009 | Intel CPU
START UP PROBLEM
You need to reset bios.
Open cpu cabinet and pull cmos cell from motherbord chipset for 15 minutes then all settings are factory defaults.
Aslo you can reset settings with jumper settings .
Refix your RAM memory. Refix processor.
Reattch ATX power supply to motherbord.
Thanks for using fixya.
Please rate solution if it helps.
Jul 20, 2009 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
I have asus board p5 -mv1 it was working good and after a period it's stop working .. when i checked the computer mother board and cpu and every thing could be the reason even cpu fan & power supply i...
If nothing has changed I would suspect the power on button has failed. You could order one online to test this theory and replace the defective unit. They don't last forever.
http://www.directron.com/atxswitch.html
Jun 12, 2009 | ASUS (S370L) Processor Board
Starting problem.
Check whether the mother board support that processor. Check whether the processor is changed correctly.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Apr 01, 2009 | Computers & Internet
My cooling fan on my mother board start making noise now as soon as you power up the pc it shuts down could it over heat that quickly or did it ruin mother board?
It is possible to burn out a processor in a matter of seconds without cooling. Please do not attempt to restart the unit, until you replace the colling fan on the processor. If it's not the processor fan/heatsink, you may have lucked out, but don't restart it till you replace the fans.The fan that sits on your cpu is the main concern, if it's one of the others the board should shut down automatically in order to stop this scenario from occuring.
Mar 09, 2009 | Computers & Internet
Power supply Ok.But CPU fans started with seconds It's stop.
sounds to me like your mainboard is bad, i bet if you closely inspect the capacitors around the cpu one or more is bulged out or leaking
Feb 15, 2009 | Asrock P4S61 Motherboard
Curly one
Hi
there is way to find out
First ,disconnect all power cable and data cable from hdd,fdd,and remove all pci devices.
Now you have to check your pc mother board not touch to your pc case.
Second, check heat sink on cpu is mount properly check ram also.
now check on button if it is ok push it to on.
if now occouring same problem.
change cpu and check
if the problem is not solved you mother board is faulty.
Jul 30, 2008 | Dell OptiPlex GX520 PC Desktop
Intel Pentium  D 915, 2.8 GHz (BX80553915) Boxed Processor Logo
41 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
