Question about SeaLife DC500 Digital Camera
Were can I get the camera only for dc500 Sealife .seals leaked and need new or used camera
    Brigadier General:
  • 3,006 Answers
Unfortunately, the camera is a generic, very outdated and cheap Chinese model which may have been supplied under a variety of brand names that nobody has ever heard of, or which is more likely to be exclusive to SeaLife (at least in North and South America, Australia/NZ and Europe). Despite what at least one website claims, it definitely is NOT a rebadged Canon model and as it's only a 5MP, 3x optical zoom model with a poor battery life it's likely that even budget brands no longer sell this model. From experience with previous SeaLife digital models I know that the company will supply the camera alone, subject to stock, but as the housing doesn't cost them very much to have manufactured the discount isn't that attractive. Considering the very basic image and build quality of the camera it feels like being robbed but the company has you over a barrel...
If you can, buy a different model altogether as the DC500 casing does appear to be poorly designed and leak prone. I've known one dive buddy who discovered that the catch for the casing was easy to accidentally unlatch underwater and a couple of other friends have found that the seals around the buttons are leaky. Almost any decent modern compact with a suitable housing is going to be far superior and better value. One good example is the Olympus PT-048 housing which fits their "µ TOUGH-8010/6020" models. The basic camera is already waterproofed to some extent, so you have a degree of double protection if there are any leaks.
If you cannot afford to invest from scratch again then there are plenty of good Sea and Sea 35mm models which can be obtained very cheaply and if you use slide film and scan the results you can get far better pictures.
Posted on Sep 07, 2010
Picturess are too green
there are advanced color correction modes,
Blue or dark pictures/videos
Keep your shooting distance inside of 2ft to 3ft, depending on
visibility and ambient light.
If you are using only one light, considering adding another light
(dual lights) or/and external flash accessory. The ideal
set-up is a combination of a light plus flash.
Consider purchasing the SeaLife Wide Angle Lens (SL975). The
fisheye lens allows you to get closer to the subject and fit more
into to picture frame.
For SeaLife camera with external light accessory (No external flash):
1) Set the camera's scene mode to Sea mode or Snorkel mode
2) Change camera's PHOTO and VIDEO White Balance
settings to DAYLIGHT.
For SeaLife camera with external light and flash accessories:
1) Set the scene mode to Ext. Flash mode
2) Change the VIDEO White Balance setting to DAYLIGHT.
For other underwater camera brands:
1) Set the Scene mode to "Auto" or "Underwater" scene
mode, as recommended by the camera manufacturer.
2) You may also need to change the White Balance setting to
DAYLIGHT depending on the camera's underwater color
correction or if pictures/video turns out red.
Mar 05, 2014 | SeaLife DC1200 Digital Camera
Where can I buy a replacement screen for my camera?
It is available wholesale from several resellers.
But eBay would probably be the best place to buy single units.
Apr 17, 2008 | Cameras
Sealife DC1200, I have 2 brand new and after I put in a SD card it gives a card error?
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 17, 2010 | SeaLife DC1200 Digital Camera
I have misplaced my user's manual. Can I get a replacement?
You can download one from:-
http://www.sealife-cameras.com/service/manuals.html
Checkout the technical support page on this site, there appear to be updates for your camera.
Mar 07, 2010 | SeaLife DC800 SL180 8 MP Camera Underwater...
Vivicam 5340s camera dock
You can't charge the camera with the USB cord because the camera dosn't have a charger built inside. You need to use an external charger. Here is a link showing several sites that have battery chargers for this camera.
Dec 26, 2008 | Vivitar ViviCam 5340s Digital Camera
Sealive ecoshot
Havent been able to find any software, but you can try the following workaround:
1. Plug in the camera to the PC and ensure it is detected by the PC.
2. Right click START button and select Explore.
3. From the left panel, scroll to the drive corresponding to your camera. (It will usually be located after the last DVD/CD ROM Drive letter.
4. Click on that drive to expand the folders in the right pane.
5. Search for the relevant pictures from a folder within that drive.
6. Copy the required pics (Press CTRL and click on pics in case you want to select more than one pic.
7. Once you copied all the needed pics, select a folder on your computer (or create a new one) and paste the pics into this folder.
8. You're done :)
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 03, 2008 | SeaLife DC500 Digital Camera
Batteries for a 5340s camera
have discovered www. batterypowerplus.com They list all cameras with the appropriate batteries. from their list i got the information that np900 batteries fit not only my vivitar5340s camera but about 30 other cameras as well
Apr 06, 2008 | Vivitar ViviCam 5340s Digital Camera
SeaLife DC500 Digital Camera Logo
111 people viewed this question
Top SeaLife Cameras Experts
Steve
Are you a SeaLife Camera Expert? Answer questions, earn points and help others
