Question about Texas Instruments TI-34II Explorer Plus Calculator
Won't turn on
It won't turn on, and sometimes when its on i have to press really hard to get the keys to work. but since its solar powered i have no idea what the problem is
  • Texas Instru... Master
  • 7,993 Answers
Try pressing [ON] and [CLEAR] at the same time. This will reset the calculator.
Posted on Feb 03, 2010
2008 Mazda tribute won't start easily and normally anymore. Sometimes only starts when I turn the key all the way very hard while putting pressure on it . It's like pressing the key inward whi
It sounds like it is a linkage issue between the lock cylinder and the ignition switch. The ignition switch is located on the steering column and there is usually a rod that connects the lock to the switch. These switches have some adjustment, so you should be able to loosen the bolts and move the switch up the column. Just remove the panels below the steering column and look for a bunch of wires plugged in towards the bottom of the steering column.
Jan 06, 2013 | 2008 Mazda Tribute
Ignition stuck key won't turn to start car!
Gear shift is not totally in the park position - had the same problem with a 2011 Acura TL - a rubber band kept the gear shift lever from totally seating in the park position.
Oct 02, 2012 | 2003 Ford Focus
Virgin mobile venture won't start
Take the battery out. Then put it back in. I couldn't find anything that would work but doing a hard reset. Once I did that the phone worked again. I lost everything but my phone works again.
To hard reset the Virgin Venture please follow the instructions below:
Start with the phone turned off.
  1. Press power button until the phone turns on and vibrates.
  2. Press and hold the up volume button until you see the word hello.
  3. Release the up volume button.
    Note
    : You will see the word hello on the screen for about 5-7 seconds.
  4. The screen will display the android guy next to an exclamation point inside a triangle.
  5. Press the home button to access Android system recovery screen.
  6. Scroll to and select wipe data/factory reset.
    Note
    : The volume button scrolls and the enter/return key selects
  7. Scroll to and select Yes.
  8. The Venture will reset.
  9. Select reboot system now.
The Venture will reboot to the initial setup screen
Aug 10, 2012 | Virgin Mobile PCD Venture No Contract...
How to turn off calculator
Most calculators have a key sequence to turn off power. The key may be dedicated (one function) or it can be activated by pressing SHIFT or 2nd first. For a Casio scientific calculator, press SHIFT followed by AC (All clear). Some solar powered calculators do not have a key to power off but the calculator will turn itself OFF after a moment of inactivity.
Jun 03, 2012 | Office Equipment & Supplies
I haven't used my calculator in some time. Now when I go to use it, it won't turn on. I've pressed on and clear and reset. Nothing. It is solared powered and its not like I just change the...
If it is solar powered and hasn't been used in some time, the battery may have died, permanently. If there is no battery to replace then it is broken forever. Sorry.When batteries are left without juice for a long period of time they die, and cannot be recharged.
Sep 14, 2011 | Office Equipment & Supplies
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
Display / LCD issue
Try adjusting the brightness setting for the LCD screen by holding down the "on" key and pressing the "+" key at the same time to make your screen darker or the "-" key at the same time to make it darker.
Jan 18, 2009 | HP 48gx Calculator
Dvdnot recognising remote control
First check the remote's functionality. The easiest way to do this (if you're a little bit handy with electronics) is to get a small battery-powered amp and a small solar cell from somewhere like Radio Shack. Solder the solar cell to an 1/8" plug and plug it into the amp's input. Turn the amp on and point the remote at the solar cell. If the remote is working, the solar cell will pick up the infrared signals emitted by the remote's IR LED and you will hear a series of clicks and pops from the amp when you press a key on the remote. This is a very handy cheap test device. I always have one around the house.
Sep 03, 2008 | Toshiba RD-XS34 DVD Player/HDD Recorder
Texas Instruments TI-34II Explorer Plus Calculator Logo
78 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
