Question about Kenmore 700 6972 Dryer
Drier had a high shrieking noise. Noise stop now it's a knocking sound
  • Kenmore Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console will stay with it.
Remove the screws holding the lint filter housing in place, and remove the lint filter.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Posted on Sep 07, 2010
2007 Cadillac escalade makes loud noise when starting the car. Sounds like the air suspension on a navigator when it adjusts, but louder. Lasts maybe 20 seconds. Happened 3-4 times within the year. Any...
Try to better describe the noise.
Is it a
scraping of metal
grinding / rubbing
high pitched shriek like a drive belt slipping
Is it
underneath the body
under the hood
in the aircon
when you pull into gear
when you pull away
etc
Do a bit of detective work and come back.
Sep 28, 2013 | Cars & Trucks
Shrieking noise from under bonnet
If the noise is under the bonnet and it occurs with the car stationary, use an old length of fuel hose as a stethoscope. Place one end up near to your ear and move the other end towards where you think the noise is coming from - it'll be much easier to pick its source this way. But remember to watch out for whirling fans and drivebelts when you're waving the hose around!
First Checks If something that is supposed to be lubricated makes a noise, check that it actually is lubricated! So with a noisy gearbox check the oil level, with noisy suspension check that ball-joints are greased, and with a noisy power steering pump make sure that the fluid is up to the right level. At the same time make a visual check - are there any leaks, obvious broken parts, loose nuts or bolts?
Engine Noises here are often pretty serious. But that makes identifying the cause of them even more important, before there's a chance for major, major damage to occur.
107750_3lo.jpg If there's a high-pitched 'ting, ting' sound at high loads or in a high gear at low speeds, the engine is detonating (knocking). It's a sound that is a bit like coins rattling together, and it indicates that there's unstable combustion occurring. Either the fuel octane is too low, the ignition timing is too advanced, the mixture is lean, or (in a forced aspiration car) the boost pressure is too high.
Change them! Don't rely on the (pictured) knock sensor to save your engine - assuming it even has one, that is!
A strong, dull noise that increases when the engine is revved may be caused by the crank's main bearings knocking. Cause a misfire one by one in each cylinder (take off a plug or fuel injector lead) and see if the noise stops when the cylinder is unloaded. If it does, the un-powered cylinder is the one causing the noise. The big end bearings knocking make a similar noise, but a little higher in pitch. Again disable the cylinder to see which one is causing it. The final bearing which can cause problems in the reciprocating assembly is the small end around the piston pin. This noise is heard when the piston is at the highest and lowest ends of its travel. Find out which cylinder it's coming from using the cylinder disable technique.
Each of the above noises sounds from deep inside the engine, and so is a muffled 'banging' type of sound, not really mechanical but more like a cloth-wrapped hammer blow. Piston slap, however, is heard as an overlapping series of metallic-sounding noises. It is usually louder when the engine is cold, but gets quieter with increasing engine temp. Often when this noise is present there will also be heavy oil consumption.
Each of the noises is very serious - the car should not be driven and - if it has to be - not revved hard. A full engine pull-down and overhaul is normally indicated by any of these noises: unfortunately, it's bad news!
A high-pitched loud squealing that increases in pitch as engine revs climb is probably a slipping drive belt. This will happen more often when the engine is cold, and simply requires tightening of the belt. Noise from the water pump area normally means that the pump is stuffed and needs replacement.
If you car has manual tappet adjustment then there may be a rapid 'tap-tap-tap' noise, easily heard at idle and increasing with engine revs. This means that a tappet adjustment is required - easy stuff.
If your car has hydraulic tappets and it still makes this noise, one or more of the hydraulic lifters has died and needs replacing. Note that in an EFI car the injectors can make a very similar noise - use the rubber tube stethoscope to listen to one and then confirm that they all make the same noise.
Clutch 107750_4lo.jpg Clutch noises happen when the clutch is being used - unlike gearbox noises which can happen in neutral as well! A clutch which is noisy whenever the pedal is pushed down may have a worn-out or unlubricated release bearing. Note that this isn't just a squeak from the pedal (just lubricate the pedal if it is!) but instead is a noise that is continuous with the pedal down.
Noises that come as the clutch is released are all caused by the clutch assembly having worn or broken bits in it. If the noise is accompanied by a grabbing or chattering clutch then it'll have to come out. Note that a squealing clutch can sometimes occur if you've had a 'paddle' high-performance unit fitted. This doesn't mean that anything's wrong - it's just the noise that the friction material makes.
Gearbox In an auto box signs of distress are normally shown by poor gear changing behaviour - flares on shifts, slippage and so on. But in a manual trans, noises are often very important first signs of problems. If the noise is present in neutral, push in the clutch. If the noise doesn't stop, check out the engine and clutch.
If the noise stops, it's the tranny - but the first step is still to adjust the engine idle speed to make sure that it's not high.
107750_5lo.jpg A roaring noise that occurs with the gear lever in all positions and which gets loudest at a certain engine rpm may mean that the gear teeth are worn. A rhythmic knocking sound from the trans indicates that there are broken gears or bearings - a trans pull-down will be necessary. Noises that occur during gear changing indicate that the synchros are having trouble. The first step is to check the clutch operation, and then after that a gearbox pull-down will again be necessary.
As you can see, noises from the gearbox are always bad news! However, a box that very gradually becomes noisier over time will often continue for a good many kays without problems. It's a sudden change that warrants close attention.
Tailshaft Noise from the tailshaft will usually occur during throttle-off coasting - with a tailshaft problem, vibration is the more common symptom when accelerating! A knocking sound when driving off or coasting can be traced to worn universals (most often) or worn mainshaft splines. Both times they'll need replacement to cure the problem. Others to look out for include a damaged centre bearing (on two-piece shafts) or loose bolts on any of the tailshaft fastenings.
Suspension 107750_6lo.jpg Noises from the suspension are usually of the 'clunk, clunk' type. If your car suddenly develops a suspension noise after you've been working on it, immediately pull over to the side of the road!! The first step is to make sure that you remembered to tighten the wheel nuts - loose nuts will make the wheel clunk as you drive along. [In 15 years of playing with cars I've forgotten to tighten the wheel-nuts twice. Both times there was enough noise to let me know of it.] In fact loose nuts on any of the suspension components can cause noises, and so check that they are all tight and that split pins (where fitted) remain in place.
Wheels can literally fall right off if a split-pin is missing and a nut becomes loose....
Make sure that all ball-joints are greased and that rubber suspension bushes (especially in older cars) haven't worn away. Pushing the corner of the car up and down will let you hear noises caused by broken shocks, springs and so on.
Grinding noises that vary with speed and cornering loads often come from wheel-bearings. One quick check of the bearings is to grab the wheel and try to shake it - it should have near-zero free-play.
However a high-kay car (150,000+) is likely to have wheel bearings well on the way out.
Brakes 107750_7lo.jpg The cause of brake squeals and shrieks can often be fairly minor, but it can also indicate that drums are distorted or the friction surfaces scored or contaminated. If the noise occurs all of the time that the car is moving but disappears when you put your foot very gently on the brake pedal, the brakes may be dragging. 'Donk-donk' noises during braking can indicate that the discs are warped - but you'll usually feel that through a juddering brake pedal as well.
Thanks for contacting Fixya
Jun 24, 2009 | 2002 Daewoo Nubira
The bike makes a shrieking noise wen i pull away and a meshing noise is it the clutch
You should go back and review your work. Shrieking noises are not friendly. Oil ok? Proper adjustments? Proper parts in the proper order? All fasteners properly installed? All parts accounted for?
Feb 24, 2013 | 1998 Yamaha XVS 650 Dragstar
My 2002 Audi just recently started making a shrieking noise after I start it and put it in reverse...is this a malfunction with the back up sensor?
There is no back up sensor its sound like a belt noise, and it probalbe will make the noise foward also.
May 08, 2011 | Audi A6 Cars & Trucks
Noise after the motor starts
Is this a clicking or a knock/pop sound? The knock knock sound can sometimes be helped a little bit by tilting the refrigerant filter drier (located in the compressor compartment) to a horizontal position. Ask your technician to do this for you.
May 29, 2010 | Amana DRS2462B Side by Side Refrigerator
Dell Studio 1737's power pack makes a shrieking, humming noise
I would stop using the adapter immediately. It could be about to blow. When one of these blows, you can get smoke, sparks and fire. You don't want that to happen when you are not around. Further you don't want to have a voltage spike from the adapter to *********** board. You can buy a new adapter at Walmart or whereever. Just be sure that it supports Dell computers. Dell uses a third pin frequently. Check the voltage and amperage of your current adapter. You should see something like 19V and 3 Amps. Make sure that your replacement adapter works within those rages.
You can also buy an exact match from Dell or ebay.
Expect a good Universal adapter that you buy at Walmart to be in the range of 50-100.
The good thing about a universal adapter is that you can use it on another notebook later.
May 22, 2010 | Dell Studio 1737 Laptop
Knocking noise from engine 1995 honda prelude
This may also be a warped flywheel.
Jun 15, 2009 | 1995 Honda Prelude
Constant buzzing noise
it sounds like your fan may be hitting on something
Jan 04, 2009 | Dacor Epicure EF42BNDB Side by Side...
No picture ,No sound except high pitch shriek from transformer/JW14140
check your power supply board,higher voltage than the normal voltage coming out to your power supply,replace the oscillator that control your regulator.
Sep 25, 2008 | GE 31GT740 31" TV
Kenmore 700 6972 Dryer Logo
66 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
