Question about Mantis 2-Cycle Tiller
I was tilling an area. It quit. There was still gas in it. When I tried to restart, the cord would not pull. I checked to see if anything was wrapped around the blades or stuck between the blades and there wasn't. I tried again and the cord still would not pull. What should I try next?
  • Brian Kirk
    Brian Kirk Sep 07, 2010
    Just plain gas or the proper gas/oil mix? Running a 2-stroke engine on straight gas without the oil mixed in will cause the motor to seize which would explain the starter cord not pulling.
  • 1,041 Answers
It doesn't sound good. I would say that it probably seized up on you. The best way to determine that without tearing it apart is to ask yourself how it was running right before it quit. If it was running extremely well right before it quit, then you probably blew it up (seized)!
Jim
Posted on Sep 09, 2010
  • Jim Parker
    Jim Parker Sep 13, 2010
    Did this help you to solve the problem. Please rate my answer if so.
    Thanks!
    Jim
My Toro mower won't start. The cord will not allow me to pull it out all the way. It seems to be caught on something.
Disassemble the starting mechanism and remove the snag in the line that is preventing you from pulling cord all the way out. Till you do that, you will be pounding salt.
Nov 01, 2015 | Toro Garden
Simpson 2700 won't start with pull cord after running for a while?
Release the high pressure in the hose by triggering the wand as you try to restart the engine.
Jul 08, 2014 | Simpson Garden
I put reg gas in it & it ran rthen quit now the cord will not pull
Could have scored the rings, broken ring, or just cooked the piston to the sleeve, maybe melted the connecting rod to crank, damaged needle bearings. Most likely needs to be taken apart.
Mar 20, 2014 | Weedeater 25cc Gas Blower ()
Yardman blower jut quit running like it was out of gas, restarted then did the same thing, now its difficult to pull the cord to strt
I'll guess and say that the carb flooded the engine and you have hydro lock.Pull the sparkie and clear the extra fuel.
The carb is at fault,IMO.
if the needle get a little dirt in there it will hold the float open and flood the motor.
Dirt.
Nov 16, 2012 | Yard Man Mulchinator QuickShift BlowerVac...
Has run fine. used for hour to hour and a half and all was good. quit for an hour. added fuel and ran again. but, within 10 minutes, it died and a little smoke came from area around the pull cord. ...
Do you have the correct Resistor plug in the saw? If the plug is correct and muffler is clear, air filter clean, my thoughts would be a clogged carburetor.
Jun 09, 2017 | Husqvarna Operator's Manual 365 372xp ...
We started the snowblower 2 weeks ago now it will not even turn over, the cord wont budge either
Have you tried pulling the spark plug out? If it still will not turn over, then quite possibly if it is a 2 cycle the gas mixture wqas not right & it got to hot. Try putting some Marvel Mystery oil in spark plug hole 7 let it set for a while then try pulling the cord. I have gotten them to loosen up with this process. Make sure gas mixture is correct before trying to restart.
Dec 27, 2010 | Garden
My Craftsman Series 550 Lawnmower was working fine and I decided to check and clean the airfilter and carburetor. When I tried to restart the pull cord is stuck and won't allow me to pull it. I have...
i suggest you pull the housing off for the pull cord and see if it pulling fine if it does see if the brake is of on the motor i would bet the brake is not releasing
Jul 17, 2017 | Craftsman Garden
Cant start ryobi 890r brushcutter
My Ryobi 890r brush cutter will start and then die
May 16, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Poulan 18' model 2000 chain saw, quit running , will not start.
If you have a compression gauge, check the compression. Anything under 90psi is too low.
Check your flywheel key. If it is broken the flywheel will move and not fire at the correct time.
Note: if it does not sputter with carb cleaner then it's not your carb.
Next:
Remove your exhaust manifold. Look into the cylinder with a flash light. You are looking for scratches. Anything larger then a light fingernail is definite proof you need a new cylinder/piston assy.
If it passes that test do the following:
Pour mixed fuel straight into your cylinder until 1/4 full. Slowly pull your saw over while looking into the cylinder. If you see bubbles after the ring/rings go by then you need a new cylinder/piston assy. On rare occasions if no scratches are present on the cylinder wall or piston, you may be able to change just the rings.
Mar 31, 2009 | Poulan Pro Chain Saw 46cc 20"
Mantis 2-Cycle Tiller Logo
202 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
