Question about Vizio VA370M 37 in. TV
I have a Vizio VA370M 37" LCD TV and the screen has a horizontal band that is about 1/2 the way across on the bottom on the right side that has different color and look to the rest of the screen.
  • Vizio Master
  • 11,800 Answers
If the band is always there, looking the same, whatever the source of the image then the lcd panel is defective - this can't be fixed and a replacement panel will cost you as much as a new tv = just junk this one and get a new tv.
If the band is in the same position but its aspect changes then the fault is in the image processor and it, along with the mainboard on which it's soldered, must be replaced.
Posted on Sep 07, 2010
Have a dark band horizontally across vizio tv. Appears to be a backlight, but not sure how to fix
Could be a bad CCFL lamp, if the set usess CCFL back-light system. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 08, 2017 | Vizio Televison & Video
My tv picture is real skippy like a bad scratched dvd. It also restarts itself every so often?? can u help?
If its a new TV then bring it back,it is defective and if not then the TV is going bad.
Oct 22, 2013 | Vizio VA370M 37 in. TV
Samsung ln52a650a1fxza LCD has horizontal band of dark lines across screen
check connections on top of screen this is becoming a stockfault on samsung tvs
Dec 01, 2012 | Televison & Video
Panasonic 37 inch lcd tv
Check its back light CCFL lam of that side, which look darker. Replace it.
Jul 15, 2012 | Panasonic Viera TC-37LZ85 LCD TV
My vizio 37" plasma tv has a green line running down the right side of the screen
Vizio does not make 37" plasma TV. for the green line problem, does it happen on all inputs or just when you what TV (cable or satellite)? That line should only be present on some channels due to signal processing compatibility. To get rid of it, you can use the horizontal size adjustment and expand the picture side way.
Jul 03, 2009 | Vizio L37 Television
Flickering white line across top of vizio 47" tv screen
I had that problem on my Vizio 37" and my new Vizio 55" and now after reading the solution of adjusting the HV position in the setup menu, the problem is fixed! Thank you!!
Jun 30, 2009 | Vizio 42 in. LCD TV
We also have a Vizio with red horizontal lines and our TV is new
It's possible that the motherboard or the controller board for the screen is defective. At this point, I would use the warranty from Vizio. It should be no doubt that it covered. Here's the info you will need from the Vizio web site.
http://www.vizio.com/support.aspx?id=1588
Jun 13, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
I have a 37in LCD Emerson tv and there is a division line in the tv. Top is normal bottom is dark. How do i fix it
sounds like a failed backlight or inverter.
larger LCD sets use multiple lamps horizontally across the screen.
Dec 03, 2008 | Emerson EWL3706 37 in. LCD Television
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Vizio VA370M 37 in. TV Logo
166 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
