Question about Refrigerators
Have a side by side 106.53334300. Circulating fan on back wall of freezer compartment not circulating. Freezer coils get frosted up. Bottom of freezer compartment cool no air circulating to Fridge. What part should be checked.
  • 2 more comments
  • mhandzlik Sep 07, 2010
    The reasons and solution have already been posted previously and tried. I have cleaned out the coils on bottom of compressor for better air flow. left unit unplugged for 24 hours. Still do not get the freezer fan moving. Will a deffective Bi-Metal defrost thermostat cause the fan to not rotate?
    Thanks, I will try this would the Bi_metal switch also effect the air flow to the Fridge? The vent into the fridge is near bottom and one near top. I get no cooling or airflow at all in fridge. Just want to see if Im dealing with more than one component. Compressor deffinately kicking on and cools (eventually frosts) freexer coils and bottom of frezzer gets cool.
    Thanks pulled out motor hooked my ac test wire to the two power terms, no rotation. One last question. I did not have ground term on my AC test should motor still engauge when just hooked to straight AC?
    Technician was responsive and helpful answering questions going back and forth. I look forward to getting the replacement part so I can complete the solution.
    President:
  • 1,796 Answers
Hi!! The mos common reasons for freezer ice build up are" Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem Here is a Air Flow Parts Diagram for your Kenmomre unit have a side by side - 23a66bd.png Click on the following link to order your part from Sears Direct and a larger image of the parts diagram
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10653084300/0582/0165000/K0404004/00005?blt=06&prst=&shdMod=
Posted on Sep 07, 2010
  • 1 more comment
  • Rene J Solis Sep 07, 2010
    If you leave the freezer door open for a couple of minutes, the fan should kick in, if not, apply 110v to the fan terminals directly, if it works, the problem could be the bi=metal switch. otherwise, replace the motor.
    There is only one evaporator and evaprator fan in your unit, this means that the only place where cold air comes from and into the fridge is the one that is not working. It is not unusual that this fan quits working, in fact, it is one of the most popular thngs you replace in a fridge.
    Your AC outlet has a hot wire and a neutral wire. That's all the motor needs to run. Just for your info, if you look at the outlet, out of the two contact holes, the small one is the hot one and the larger one is the neutral, the round one is the physical ground. Thank your for using FixYa. Don't forget to rate this post!!!
I have a Kenmore Elite side by side refrigerator, the problem is the unit is not cooling at the top area of both the freezer and refrierator? the bottom areas are OK, I notice there is no air flow in the...
Is your fan inside the freezer compartment back wall towards the bottom is working. (Evaporator fan motor) ?
No fan... No circulation.
Fan may have failed or another common thing is failed defrost system has clogged up the evaporator coil and fan blade with frost. In this latter case, you will see white frost build up in the freezer back wall towards the bottom in freezer compartment.
Better call a local service technician. Little bit technical and hands on job.
Oct 23, 2017 | Kenmore Refrigerators
Freezer cold and fan running. Refrigerator side not cold, no cold air circulation. Wife says sound of refrigerator is lower pitch like something that used to be running is no longer running. Is there...
Hello Otis,
Thier is only one fan in the freezer that circulates the air throughout both ref/freezer. I dont know if ya have a side by side or if freezer on top..but if side by side one possible cause would be the damper in the upper left corner of the refrig. compartment is stuck closed so no air can enter ref.compartment(no damper if freezer on top or even if older model side by side) on either model also even if freezer on the bottom, another possible thing is frost has built up in the freezer and the coil in freezer is a huge block of frost and no air can poass through it because its totally frozen.
Let me know which might be the problem and i will help ya check that EI..is the damper stuck..is it all frosted up and ya can see frost on back plate of freezer wall ect ect..
Gene
Aug 23, 2011 | Refrigerators
Jenn Air JCD2389GTB side-by-side refrigerator freezing & cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 13, 2010 | Jenn-Air JCD2389G Side by Side...
The upper portion of the freezer turns off, causing the ice to melt. And the cooler side bottom drawer turns into a freezer. I can't figure out what's going on.
You have a frost blocked evaporator. Translation: The cooling coils, located behind the back wall inside the freezer section, have plugged up with frost (usually caused by a burnt out defrost heater, located at the bottom of these coils) which prevents the cold air from circulating inside the freezer, and into the top of the fresh foods section. At the same time, this blocked air flow allows very cold air at the bottom of the freezer section to migrate back into the bottom of the fresh foods section, and thus freeze item in the bottom bins of the refrigerator. Unload the freezer, take the shelves out and remove the back panel. Melt the frost with a hair blower, and change out the heater at the bottom.
Jul 08, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Refrigerator warm freezer too cold
If you have already adjusted the controls for temperatures in both compartments and allowed 12 - 24 hours to stabilize and the trend is continuing, there may be a problem with the fans that move the cold air from the freezer to the fresh food compartment. The fridge may also start allowing temperatures to rise in the freezer soon, too.
All of these problems originate in the freezer compartment, where the cooling is done. Behind the back wall; inside the freezer - lies the cooling coils, defrost heater, circulating fan(s) and defrost terminator sensor. Unplug the fridge. Empty the contents of the freezer, remove the ice maker assembly and the back wall plate and you should see these components. If it looks like a large block of snow and ice, the problem is with the defrost circuit components. If clear with a minimal amount of frost, the warm fridge is the result of blocked or limited airflow from this area to the fresh food compartment - likely a failed circulating fan. Plug the fridge back in and check to see if the fan is running - since the fridge is warm, it should be running. The fan or the thermostat will probably need replacing if it is not.
If icing or frost is the problem, you'll need to isolate and replace one or more of the following: defrost heater, defrost terminator or defrost timer. The last two are the usual suspects for this type of failure - but the heating element can fail too. Many times, the defrost timer is accessible from the front of the fridge, behind the kick plate below the freezer door on the right side. Other times it is located in or near the temperature control area.
Jun 18, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Fridgedaire Elite frost proof fridge part not cooling, Freezer sems fine
If the frozen side is colder than normal and some extra frost is forming where the fan blows,and there is ice in the bottom of freezer compartment, and the cool side is not cool enough, their is a good possability the defrosting unit is not removing all the frost and ice . the defrosting unit has a timer (usually near thermostat) that turns off the cooling fan and compressor and turns on a small heater around the evaporator ( about 20 minutes every 2 days) (evaporaror is cold heat exchanger coil inside the back wall behind a cover near the recirculating fan0, the fan circulates air to both compartments through two small openings, if these openeing are closed by ice buildup cool air can not circulate to the cool side. cure 1. remove all food and leave fridge off for 24 hours with doors open (take precautions to ensure children can't get locked in side and suffocate, if you get a qt of water in bottom of unit (may leak on floor) ice buildup that the defrost heater can not remove melted and was your problem . turn frig on replace food on unit. cure 2. turn frig off, remove food from both sides, remove shelves that block access to evaporator, remove cover over evaporator if you see the evaporator coils free of ice look at openings (2) to other side, one may be blocked with ice the other with frost, carefully melt ice with hair dryer.
If the evaporator coil is solid ice heater or timer or fan has failed. good luck
Aug 09, 2008 | Zanussi Z57 / 3 Bottom Freezer...
Hotpoint freezer fza54 frost free, high temp light on
Power off the freezer.
Remove all freezer drawers.
Remove the four screws retaining the ducting at the back of the freezer compartment. Top at the top, two at the bottom
Carefully pull the ducting out - it's located in the guide slots for the freezer drawers, and should pull out without too much drama.
This exposes the air circulating fan, and the evaporator coil (the bit that gets chilled).
In my case, despite a defrost of the frost-free section, the evaporator section was one massive chunk of ice. If you have similar, carefully defrost this, and check the drain hole at the bottom of the cavity.
Re-assemble, as reverse of above.
Mine's been trouble-free since doing this.
Jun 28, 2008 | Refrigerators
WESTINGHOUSE FREEZER MATE
Check the back bottom freezer wall to see if there is frost on it. If so you have a defrost problem. If the coil dosent defrost it becomes an ice ball and no air can flow. Could be a defrost timer which switches the refrig into the defrost cycle. There is also a heater and thermostat in the system. Shut it off overnight with the doors open to defrost it and get it temporarily running . If it is not frosted up make sure your coil underneath is clean and your cooling motor is running in the back, bottom.
Jun 13, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerator cooling to 59 degrees in non freezer compartment
If the fan is running you more than likely have a defrost problem.
Look at the back wall of the freezer section if it is frosted up. it's not defrosting. This keeps the air from circulating through the refrigerator section.
May 21, 2008 | Estate Refrigerators
Kenmore Trio 596.75509400
Generally speaking if the refrigerator does not cool and you have frost on the back wall of the freezer it suggests a defrost problem.
However since the refrigerator started working by itself it would point to an air circulation problem from the fan in the freezer compartment failing to operate. The frost on the back wall without the fan operating would cause frost buildup because the heat is still trying to get to the coil through the back wall. If your refrigerator freezer has a door fan light switch something holding the door partly open would cause the fan not to operate. Look for a button or toggle and manually push it in. You should hear the fan turn on and the light will go off.
Mar 12, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
193 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
