Question about Kirby Heritage II Vacuum
KIRBY HERITAGE II
The foot controlled switch on my Heritage II has packed in. Do you know where I can obtain a new part - we live in New Zealand.
    President:
  • 1,673 Answers
Here are some Kirby phone numbers, they should be able to tell who does Kirby in your area. You could try calling a local repair shop to see if they can help.
US----------------(1)-800-437-7170
Europe------------(1)-800-547-9272
Africa------------(1)-800-203-222
Posted on Jun 21, 2008
Do the Gsix and Ultimate G Kerby bags fit on the heritage II
yes this fits, kirby now have a universal bag to fit all models see kirby.com
Feb 19, 2013 | Kirby Heritage II Vacuum
Can I use the kirby heriatge II shampoo attachments with the kirby heritage vaccuum?
You should be able to. There's not enough difference in the Heritage models to make them incompatible.
Nov 07, 2010 | Kirby Heritage II Vacuum
I have inherited a Kirby Heritage II vacuum. I need a manual to sort out all the options and parts.
The only source other than E-Bay that I am aware of is Kirby.
This is from their FAQ's:
Q. How can I obtain a replacement copy of an owner's manual?
A.
For a copy of a manual, call 1-800-437-7170 or visit your nearest authorized Kirby distributorship.
I have tried personally to locate this same manual on line and ended up calling Kirby.
Thanks for choosing FixYa.
Kelly
Aug 13, 2010 | Kirby Heritage II Vacuum
Kirby heritage vacuum front light
yes there is should get a vacuum store to take a look at it.
Jun 05, 2009 | Kirby Heritage II Vacuum
I need to install a mini emptor on a Heritage II Kirby
I actually figured this out on my own. Just removed the rubber out seal between the bad and em-tor, then used a screw driver to gently pry the bag out of it's grove. The wire part of the hose actually unscrews from the em-tor. Reverse the process to install the new one. Gotta love Kirby engineering.
Jun 02, 2009 | Kirby Heritage II Vacuum
Wiring foot pedal switch legend II
If I remember correctly,on the switch itself,each connector is letter coded.'W' for white,'R' for red,and so forth.The manual mostly talks about how to change attachments and basic operating,but not repairs.
Dec 20, 2008 | Kirby Heritage II Vacuum
Using accessories on a Kirby Heritage 84
my guess with your kirby is the safety switch on the right side of your vacuum is not being pressed down, are you sure you have the right model of hose? any Heritage 1 2 or Legend 2 can work with it since they all have the same switch. your carpet head is working from the sound of it so either it's just that the high speed switch (being pressed fully down) doesn't work or you are not using the right type of hose (or the piece that engages the switch could be broken off
Oct 09, 2008 | Kirby Heritage II Vacuum
Kirby heritage II
As long as it is Kirby belt - you should be fine. Make sure that the shaft is clean and that you do not vacuum something greasy or wet (grease or oil will lubricate the belt and shaft will loose the grip -heat up and burn). Make sure that brush roll spins freely.
I am assuming you know how to put the nozzle on properly (if you not sure - go here)
Good Luck
Rocky
Aug 22, 2008 | Kirby Heritage II Vacuum
Vacuums Logo
114 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
