Question about Element Electronics FLX3220F 32 in. LCD TV
I have an element lcd tv when i plug it up just get a red light but does not power on please help
I Have an element tv and it just stopped working, please help
Posted on Sep 19, 2010
SOURCE: INSIGNIA LCD won't turn on
Call Electronics Direct to fix it in One day, Call Now 905 565 6595
Posted on Feb 17, 2008
SOURCE: my element 19 inch flx-1910 tv will not power up
Element FLX-1910
Problem: When the TV is turned on a picture appears for a few seconds and then the picture turns off. Audio is still heard.
Solution: Not a simple fix! This TV has 4 small florescent looking bulbs that act like a back light to light the image on the liquid crystal display (LCD). At least one of these bulbs is burned out or broken. The wires powering the broken bulb need to be cut and spiced together. Basically you’re bypassing the bulb and completing the circuit when cutting the wires going to the bulb on each end and splicing them together.
WARNING: This worked for me but no guarantee for anyone who tries it. This is a very involved procedure and involves completely dismantling your television. To be honest I don’t recommend anyone trying to fix it unless you are very technically minded and have a couple of hours to waste carefully tearing apart your TV. If anyone is willing to attempt this repair I am willing answer questions.
Cause of problem: It is my guess that this problem occurs when the TV is left on for extended periods of time. Like leaving the TV on when you fall asleep at night. My TV was left on a lot. I noticed that the plastic was melted and discolored where the bulb had burned out. (This can only be seen internally and is no way visible from the exterior)
Posted on Feb 14, 2009
SOURCE: Element LCD tv with no power. I replaced fuse,
You probably need a new power source. Take it to you repair shop. That's what I had to do and it was relatively inexpensive.
Posted on Mar 23, 2009
  • 43 Answers
SOURCE: Samsung LCD 40" While LInes, Clicking Noise, Red light blinks
Your LCD has gone bad or their is a high voltage problem that powers the LCD. Usually a inverter board.
Posted on Jul 04, 2009
  • 4 Answers
SOURCE: green to red blinking light when plug in rca lcd
It is the capacitors on the power supply...They blew on ours...took it in a they replaced 7 for less than 100.00. Common problem with this tv because it gets hot. Hope that helps.
Posted on Nov 25, 2009
Why won't my 40"flat screen tv come on?
Power on of key problem is main reason behind this problem. After plug in TV with power. Wait for 6 second and try from remote power on button. If full fail to power on please contact the expert lab engineer.
May 31, 2014 | Element ELCHW402 40 in. LCD HDTV
I have an element 40" hdtv model ELCHW402 it powers up, red light comes on but i cant turn tv on, light stays red
hi you may have a power supply fault, could be capacitors look for a tech in your area hope it helps
regards
shaun
Jan 25, 2014 | Element ELCHW402 40 in. LCD HDTV
FLX3211b when plugged in the red power light comes. Then when the TV is turned the red light turns blue and stays on. The Element logo appears for a couple seconds then the screen goes black. There is a...
the transformer for the backlight is usually what fails on the elements especially if the logo comes up briefly then the screen goes out. I would check the transformers.
Apr 04, 2012 | Element Electronics FLX-3211B 32 in. LCD...
Replaced 3 capcitors today and tv still wont power up, element flx3711b lcd tv
check D7 and small cap to the right(forgot # returned tv) in the power supply area.i found diode leaky and cap dry.Thats how i fixed the blinking red light.hope it works.
Mar 07, 2011 | Element Electronics FLX3711B 37 in. LCD TV
Any ideas on what to do for an element tv that won't turn back on..the red/blue light is not on either. It was working fine and when I shut it off the red/blue light went out also now I can't get it back...
Tries tv unplug,replug it back like about an hour.By letting the tv resetting itself back to the tv factory setting.Now,the tv should be working again.If it still have the same result.Mean the tv power supply board,that the board where the power a/c plug into it.The causes and the problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jan 24, 2011 | Element Electronics FLX-3211B 32 in. LCD...
Element elchs321----tv cuts off on its own. when tv is plugged up, the light at the bottom is red and you can hear a crackle, the light turns blue but no picture or sound. Help
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors. That crackling sound is the capacitors burning out.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Sep 15, 2010 | Element ELC-HS321 32 in. LCD TV
My 32" Element LCD tv is broken. One night I was watching tv and all teh sudden there was blue, red and yellow lines running horizontally across teh screen, audio was fine. I turned it off and unplugged...
Yes!
It has suffered a breakdown in the power supply and the damage has also spread as far as the sustain boards that control video and convergence. This is not a DIY and the repair for parts is $300 + labour. However, get a few quotes. At least a 32 in is a little more transportable than a 6' model
Please rate my help++++Thanks for using FIXYA
Jun 28, 2010 | Element ELC-HS321 32 in. LCD TV
TV red "on" light not coming on. Cannot get power to TV
The power supply board is dead.That the board where the power a/c plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power suply board for the replacement.
Jun 10, 2010 | Element Electronics 26 in. LCD TV
Element 32" TV. Power only for a few seconds, no audio.
Yes, look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc. http://en.wikipedia.org/wiki/Capacitor_plague
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=FLX3220F+
Please post back what you find.
Dec 22, 2009 | Element Electronics FLX3220F 32 in. LCD TV
HOOKED ELEMENTS FLX3210 TO LAPTOP TV DIED ONLY RED LIGHT WILL COME ON
Sounds like you need a new main board the light in the front comes on when you push the power button right?
Oct 07, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Element Electronics FLX3220F 32 in. LCD TV Logo
310 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
