Question about Sharp AR-5316 Advanced Digital Imager Copier
What toner cartridge do i use in my Ar-5316 - Sharp AR-5316 Advanced Digital Imager Copier
  • 61 Answers
AR-016TD
Posted on Sep 07, 2010
I want to know the solution to a sharp ar-5316 i refilled the toner after the toner was empty and the red triangle is still blinking, what should i do?
Does the toner cartridge have a electronic chip on it? if so you could refill it all day long it would not change once the chip say the i am done the cartridge is done. Sorry.
Try this site as a start and get a new OEM cartridge
http://olsonbros.com/sharp/parts/list.htm
Jan 28, 2016 | Sharp Ar 5316
How to solve an U2 error on sharp 5316
http://olsonbros.com/sharp/support/sim.html
U2 04 EEPROM read/write error (serial communication
error)
11 Counter check sum error (EEPROM)
12 Adjustment value check sum error (EEPROM)
40 CRUM chip communication error
Jul 27, 2014 | Sharp AR-5316 Laser Copier Black OEM Toner...
Sharp AR 5316 Maching Toner LED Light 3 Min. Blinking, and them start. Please Toner Curm reseting code.
Have you tried to replace the toner???? Are you sure the light that is blinking for the toner?????
Jan 13, 2013 | Sharp AR-5316 Advanced Digital Imager...
AFTER REPLACEMENT OF TONER CARTRIDGE LED IS BLINKING MODEL AR-5316
hi,
blinking led after replacement of toner cartridge is normal , you have to wait till it gone .
how ever if you feel it take along time then you must check the toner cartridge and reinstall it properly if the machine still blinking you may have to change the developer.
thank you for using fixya
Feb 01, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316
The toner cartridge comes with on-chip sensor that counts the toner life. If you allow it to go empty completely that is it gives red triangle which is steady to warn that toner is near empty. You should replenish toner at this time but if you allow it to blink red triangle, that means its completely over and can't be refilled. REPLACE A NEW TONER CARTRIDGE.
May 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
How i can install developer in sharp copier AR-5316
The steps to take are
  1. Open the toner door.
  2. Remove the toner cartridge.
  3. Unscrew and pull out the compartment housing the toner cartridge.
  4. View to see three screws on the compartment undo them.
  5. Next you see an enclosure with spiral, rigth there you pour in your developer. Then couple.
I hope it worked.
Thanks
Engr. Kachi.
Nov 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Add toner still blinking of sharp AR-5316
the best you can do is to replace the toner cartridge itself. It won't work if you just refill it.
Oct 31, 2008 | Sharp AR-5316 Advanced Digital Imager...
What's U2 code and method for solution
U2 can have several indications.
The most likely one is that the chip that is on the back of the toner cartridge is not seated properly or has failed.
Try with the machine off, removing and inserting the toner cartridge several times to clean the contacts, next step is to try a new toner cartridge.
There is also a connector on the back frame of the machine that may be dirty or going bad.
Jan 16, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp COPIERS - AR-5316
The cleaning blade is in the drum cartridge.
There is no developrer change in that product.
There are 2 cartridges.
The toner and drum.
Toner contains all you need as far as ink. And also the waste sump is on the toner cartridge.
The Drum is a self containted unit that has the cleaning blade and auger built in.
Jan 10, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
19 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
