Question about Hoover Vacuums
HOOVER TELIOS 2000W . VACUUM CLEANER HOW DO I GET ACCESS TO RENEW THE ON OFF PUSH SWITCH ?
2 Suggested Answers
  • 11 Answers
SOURCE: Hoover 1800 telios vacuum cleaner - fuse good but does not switch
there is a button left beside of vaccuum cleaner tube to pull it up & bag will open.
Posted on Mar 04, 2010
How do i open/dismantle a hoover telios vacuum cleaner ?
Hi there! Disassembling the cleaner beyond detaching the nozzle, wand and hose is not recommended. If you need further assistance we recommend taking your cleaner in to a Hoover authorized service center for inspection. Follow the link to locate the nearest service center to you. Service Center Locator
Thanks!
Jun 22, 2014 | Hoover Vacuums
Telios 2000
This is normally caused by restricted airflow, causing the heat sensor switch to trip. Please make sure the hose and bag are not clogged, verifying you have good suction and airflow to the hose end when you initially turn it on. The heat sensor switch is intended to shut off the motor if sufficient cooling air is not present.
Mar 09, 2010 | Hoover Vacuums
Mar 03, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
The hoover keeps switching on and off automatically.
Sounds to me like there is either a loose wiring in the pedal or mains power cord. Check that the plug is secure. Check both filters though - one behind the bag (usually square and slides out) as well as the main exhaust filter at the back between the power on and cord rewind button. I used to own many Telios models but they are known to have cheap shearing cords which can only be replaced by a Hoover repairer. Sometimes the On pedal can be affected as well particularly if it has been stamped on heavily.
Dont forget to rate, ty.
Mar 28, 2009 | Hoover S3330 / S3332 Straight Suction...
Hoover Alyx 2000w, no power. Help!??
Its a possibility then that if the fuse has been replaced that the cable inside has either come apart or you have a broken switch. If its only a year then you should be covered automatically with Hoover's guarantee.
Mar 05, 2009 | Hoover F5411 SteamVac Jr. Canister Vacuum
Telios 1700
if you care to join my premium plan,I will tell you how I fixed it.
Sep 04, 2008 | Hoover Telios Canister Vac Vacuum
Vacuum won't stay on
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618732&thid=562398
posted by trobinson66 on May 01, 2008
I think the switch is broken--it will come on, but the switch does not stay engaged. I'd like to try to fix myself, if possible. Any thoughts?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Hoover Telios Canister Vacuum Powerteam
When you uninstalled the switch did you mark the wires to duplicate the procedure in re- installing the part, it is possible that you have a bad switch, please check your owner’s manual for the trouble shooting guide to see what you might have done wrong. If the switch is wired correctly it should work, but one wire could be off and not connected correctly then the switch will not work. Feel free to contact your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don – The Vac Man
Go Ahead. Use Us.
May 01, 2008 | Hoover Telios Canister Vac Vacuum
My Hoover is picking dust , very poorly
The Telios has a bad design on the handle and it sounds like something has definately got stuck. Unfortunately the nature of the cheap European design means the handle can only be removed by someone who owns a vice in their garage without breaking the removal points. Alternatively find a long bamboo stick or pole to put inside the hose mount which connects normally from the main bin of the Telios (not the other way around up the handle) which has no sharp edges and push up and down vigourously to dislodge any clogged dirt which may have inadverntely got stuck either by the handle or in the hose itself.
Another thing to do is to check the suction from the Telios itself by removing the hose. If there is suction coming from the main dirt bag/bin door with the hose removed then there is no problem other than a clogged hose and handle. Hoover updated the handle and hose in 1999 and spares can be found by looking on Ebay.co.uk for cheaper prices.
Aug 12, 2007 | Hoover S3330 / S3332 Straight Suction...
Vacuums Logo
188 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
