Question about Vacuums
Kenmore Central Vac - Where to connect the low voltage wires
Ok, I see the spot I need to plug the wires into - but....I just have bare wires. Is there an adaptor I can buy? What is it called and any idea's where I can find one?
Thanks for your help:)
    President:
  • 1,673 Answers
You need female spade connectors and most hardware stores should have them.
Posted on May 14, 2008
When i put hose in port it will not turn on...all the other ports work except one
Open the door on the inlet port and look inside. You should see 2 small pins. These pins are spring loaded to make contact with the metal end of your hose when you plug it in. Two low voltage wires are screwed to the underside of these pins. The low voltage wires go all the way back to the low voltage switch/relay on your central vac power unit.
Sometimes one or both of these pins will just break so that they don't make contact with the end of your hose. If you see no pins or just one then you will have to replace the inlet cover.
If both pins are present; push down on them with your finger. If you feel resistance then your inlet is probably OK.
CAUTION: IF YOUR CENTRAL VAC INLETS HAVE A 110 VOLT CONNECTION, REMOVAL/REPLACEMENT OF YOUR INLET SHOULD ONLY BE DONE BY A QUALIFIED ELECTRICIAN.
Remove the two screws in the faceplate. Carefully slide the inlet cover out. Check the two screw on wiring connections. Make sure both wires are securely attached and that there are no breaks.
If neither of the above fixed your problem, you may have a broken or disconnected wire somewhere between this inlet and the low voltage witch at your power unit.
May 04, 2010 | Broan-NuTone CV353 Central Vacuum
WIRING IN 24 VOLT INLET VALVE FOR CENTRAL VAC. I GET A CONSTANT ON. I HAVE TRIED MAY DIFFERENT COMBINATIONS BUT I CONTINUE TO HAVE MY CENTRAL VAC AS A CONSTANT ON? COULD IT BE THE 24V WIRE?
No, there is only two possibilities. One, the low voltage wires are touching somewhere in the system or two, the relay is stuck in the on position. To find out which it is disconnect the low voltage wire from the unit (theres two clips on the side) and then plug the canister in. If the it still runs with the wire disconnected then it is the relay board. If it doesn't then it is the low voltage wiring in the system. Good luck!
Jan 09, 2010 | Beam Industries Wet/Dry Auto Central...
I have a Nutone central vacuum model number CV450W that was working great until I recently removed the hose and it now runs continuously until I pull the plug....any suggestions please
Disconnect the thin low voltage wiring between the vac and the rest of the house. If the vac continues to run you have a defective relay in the vac motor housing.
If the vac stops you have a short in the wiring in the house, likely behind an inlet in the wall.
If any inlets have been disturbed for painting or renos lately that would be the first spot to look in the house for a problem. Look for wires behind the inlet valve which are touching against each other or a mounting screw or against a metal mounting plate behind the inlet. Start at the last inlet used. Be careful not to loose the spring under the screws where the wiring attaches to the inlets
Oct 08, 2009 | Broan-NuTone CV450 Central Bagged Central...
We just installed a Hoover central vacuum system. As soon as we plug it in the system starts even if the switch is off. If we disconnect the wire the system goes off. What did we do wrong?
You have either left the manual switch at the vac in the on position, or you have a low voltage short at one of your inlets in the house, or at the vac itself or where a pair of wires are connected together at a pipe junction.
Carefully go back inlet to inlet, remove the plates and be sure your mounting screw is not shorting two wires together. Trim any excess bare wire away and look for nicks in the insulation as well unless you see an obvious short. If you are using telephone type multi colored wire it is easy to bare an inside piece of wire while stripping the outer insulation.
Also be sure sure wires are paired the same color pattern at each inlet.
It is common to see a stripped wire touching another inside the wall or if you have metal backing plates in the wall a wire may be touching the plate and triggering the vac to turn on. Post back to advise,
the other possibility is you have a nail or screw in a wall piercing the wire but this is seldom ...
take your time,its an easy fix but it might be hard to spot
Oct 04, 2009 | Vacuums
Nutone CV556 Vaccuum Cleaner -Continuously running
Start with this. Unplug the vac to shut off, then disconnect the low voltage wiring at the vac.Plug the vac back in. If the vac still runs you have an internal short on the relay or wiring inside the vac.
If the vac stops then the vac and final wiring is OK and the problem is in the wiring in the house.
Have you removed any inlets for painting or had any renos done or pictures hung. If so undo what you did last. If inlets were disturbed remove them and look for low voltage vac wires touching metal backing plates in the wall or touching the inlet mounting screws.
If you have done a reno or hung pictures you may have pierece the wire for the vac creating a low voltage short which will keep the vac running until removed. I have seen this happen with freshly installed 1/4 round molding along a baseboard
Sep 07, 2009 | Broan-NuTone CV556 Cyclonic Bagless...
Central vac won't turn off unless we unplug
Some units have an on/off switch on the power unit itself. Check to make sure that is not turned on. Unplug your power unit and remove the 2 low voltage wires (not the power cord itself) . The low voltage wires start at the unit and run throught your home and attach to each hose inlet. They are usually attached to the unit by simple wire terminals or wire capped to small wires coming out. Just unlug the terminals or unscrew the wire caps and pull the connections apart. Plug your machine back in. If it still comes on the problem is the relay or circuit board/switch/ relay assembly inside the unit. If it doesn't come on with the low voltage wires unattached then you may have two wires touching somewhere in the low voltage wiring.
Jul 18, 2009 | Broan-NuTone CV350 Central Vacuum
NuTone Central vac won't turn off
If the central vacuum tank will not turn OFF even with the switch in the “OFF” position, then the low-voltage wires should be disconnected from the tank. If the tank continues to run and still will not turn off, then most likely the relay inside is defective (but it could be a defective and/or shorted ON/OFF switch). If with the low-voltage wires disconnected the tank is able to then be turned off with the switch, then there is a short in the low-voltage wires or a hose is plugged into an inlet somewhere. ~ TTURAMBAR
Mar 11, 2009 | Broan-NuTone VX475 Bagged Central System...
NuTone CV353 Central Vac does not start when hose is plugged into
Try to plug the hose in sideways. So the top of the hose is rotated 90 degrees. If the unit turns on then there is something wrong with the hose. It might be a short or it could be a bad switch on the handle. If the unit still wont turn on I would think that maybe the low voltage wire got disconnected from the unit or there is a break in the low voltage wire somewhere along the way. Let me know if you plugging the hose in sideways works.
Feb 22, 2009 | Broan-NuTone CV353 Central Vacuum
Central vac
It is possible that the low voltage wiring that controls your central vacuum has been damaged during the cable work. You can check to see if the low voltage relay is working by shorting the two terminals together at the unit. Just disconnect the two small (18-22 gauge) wires from the unit and short across the terminals where the wires connect. If the unit comes on, the vacuum is fine, and it is most likely the low voltage control wires that have been damaged. It should be a pretty easy fix, if you can get to where the wires are located. They are probably just pulled apart at a joint. Good Luck!!
Jul 10, 2008 | M&S Systems AirVac AVP1200 Platinum Series...
Kenmore central Vac - where to connect low voltage wires?
Mosy central vacs have 2 spades close together that stick out on the side, usually where the circuit breaker and auto/manual switch is. This is where you plug the low voltage wires into.
May 13, 2008 | Vacuums
Vacuums Logo
53 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
