Question about 2wire 1800HG Router (RG1800HG00)
Distance problems with internet.
Hey my internet works fine when i'm close to the internet plug.
& it work fine when i plug the internet plug too.
but when like i go downstairs or something; it just stops.
For your signal to be stronger,you need to change your power settings on you router.by default it is set to 4. try a higher number.this will allow your signal to reach further.
my router power is set to 4 right now(this keeps my signal in the house only), but if if i want to take my notebook outside of the house, i have to set a higher power setting.
Posted on Jun 15, 2008
I have 2 Thermostat's in my home. My heat works well upstairs but not downstairs. My thermostat downstairs won't come on but I unhooked the thermostat from downstairs and tried it upstairs and it worked...
Hi, sounds like you determined the problem is not with the thermostat. That leaves the furnace that serves downstairs. What type heating system do you have?
Jan 13, 2010 | Honeywell Programmable Thermostat Heater
Hi, I have a digital tv plugged into an extension cable in an upstairs (Toshiba) bedroom; it works perfectly - receiving all channels. I have a digital tv downstairs (Samsung) where it seems the wall...
Hi Fiona
Somewhere along the line from the aerial there must be a signal splitter that feeds the upstair and downstair terminals.
Try to find that splitter and switch the output to see if the problem goes from up to downstair.
If it does switch then you know the problem is with the splitter block, and if it stays the same then the problem is with the cable and/or the connectors that run downstairs.
Also the reason you get a pixellated(snowy) picture is because of signal loss during the length of the cable you ran downstair.
If running a cable downstair becomes the best option to fix your problem , then you could buy a cheap 10db signal booster/r.f amplifier to correct the signal loss and a cable splitter to feed both tv`s
That booster would be installed upstair in your case(near the source of the signal to be amplified).
I could send you a small diagram if need be. Hope this will help and Merry Chrismas
Dec 14, 2009 | Televison & Video
Internet not working; Router not connecting with Internet or Wireless Adapter
try changing the wireless channel that the router is on. it sounds like something is causing interference.
May 16, 2009 | Dynex Enhanced-G Wireless Broadband Router
I have to unplug the router power/turn back on, 4 laptop to work.
Try using 128 bit hex code. You put in a passphrase and it will scramble it into 13 pairs of letters and numbers. Use that instead of WEP. (192.168.2.1 in the address to get into settings for router, default password is blank)
Dec 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My belkin light is on but the internet connection to my laptop keeps breaking up consistently
This sounds like it is probably the networking cables as your PC is directly connected so shouldnt have problems with net access. Get new cables as a first step :0)
Jun 07, 2008 | Belkin (F5D7230-4) Router (587009)
Internet works - except web-based email
What is your router? Try changing the MTU value of the router. You can see it in the configuration page.
The default is 1500. try lowering it to like 1490 first then 1450 if it still didn't work. You can use up to 1400.
May 28, 2008 | D-Link AirPlus DI-524 Wireless Router
2wire 1800HG Router (RG1800HG00) Logo
102 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
