Question about Frigidaire Dryers
My dryer won't heat, is there a fuse in it? - Frigidaire Dryers
  • 15,935 Answers
Yes - on the back should be a round disc. That is a high temp limit fuse.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 07, 2010
Dryer not drying
another user's Q&A for the same issue try that or call may tag, they are supper helpful
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
8574d88.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
d5b5af3.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
77d6bd4.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
    Oct 08, 2012 | Whirlpool LGQ9858P Gas Dryer
    Admiral heavy duty super capacity dryer won't heat up.
    see this causes , fix it. God bless you, use the common sense
    Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
    Door Switch
    If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
    Thermal Fuse / Thermal Cut out
    On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
    If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
    Wiring
    Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
    Sep 28, 2012 | Admiral Dryers
    WON'T HEAT AT ALL
    check fuse, may need a thermostat,motor switch or a heating element. Check the heating element first. You need a voltage meter to do this. And hopefully the dryer is plugged into 240 electric
    Sep 28, 2012 | Dryers
    Hoover VHW654D-80 not heating
    see the causes, and proceed. God bless you
    Heating Element
    hermal Fuse
    Thermostat
    Timer motor
    A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
    Sep 22, 2012 | Washing Machines
    Where is the fuse located ?
    The fuse is located on the blower housing next to the thermister (heat control). You won't see it till you get filter housing off there:
    The 3 vid down shows how to get into it HERE on my blog
    Jul 07, 2012 | Kenmore Elite HE4 Electric Dryer
    Maytag gas dryer model D6606 won't heat
    Most likely it's either a bad fuse, thermal cut-off or heating element.
    May 06, 2012 | Maytag Dryers
    Kenmore 80 series dryer won't start.
    If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. To determine if the door switch has failed, watch this part testing video.
    On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
    If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
    Aug 21, 2011 | Dryers
    2005 Whirlpool Gas Dryer. It won't heat. The coils won't glow. Had the fuses, ignitor, and coils checked and are ok. Could it be the timer? How do I check it?o
    Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
    heatman101-
    Jul 22, 2011 | Whirlpool LGQ9858P Gas Dryer
    I have a kenmore gas dryer that won`t heat, just blows air. model#97573220 75732. can u help?
    some gas dryers have a fuse on the back vent line. after you take back cover off you will see a small white heat fuse with 2 small connectors if this is ok you probably need new gas control coils.
    Aug 04, 2009 | Dryers
    Dryer won,t heat, put in new element and still won,t heat.
    check you thermal fuse for continuity if none change it and the high-imit safety shut-off fuse(closest to heat element)
    Apr 08, 2009 | Dryers
    Dryers Logo
    29 people viewed this question
    Top Frigidaire Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
