Question about Makita DCS34 Commercial Grade 14Inch 33cc 2Stroke Gas Powered Chain Saw
What should the compression be for the makita dcs34?
As far as i am aware it sould be between 60 - 80 PSI, 40 - 60 psi indicates ware any lower than 40 no hope
Posted on Mar 28, 2011
How do i check ignition coil on makita dcs34
Remove the plug leave it on the wire check for spark plug must be grounded.
Oct 05, 2014 | Makita 14" Chain Saw Dcs34
What size file do i use to sharpen the blade of a makita dcs34 chainsaw?
It has a 3/8" 050 low profile chain, so you need a 5/32" round file.
Jun 29, 2011 | Garden
Makita DCS34 chainsaw After a period of use ( this varies from 15 mins to 90 mins) the saw will tick over but will not rev ( just as if it is running out of fuel) also the priming bubble sticks in when...
This could well be an issue with the fuel tank breather, when the problem occurs try quikly losening the fuel cap, if it picks up again it needs the take breather replacing
Apr 03, 2011 | Makita DCS34 Commercial Grade 14Inch 33cc...
Chain keeps coming off my new 16" Makita chainsaw. Any suggestions?
Make sure that your chain is properly tightened and that the bar does not have any dents or dings in guide groove.I like to have my chains tightened to where you can pull them up at the mid-point of the bar about enough to fit the thickness of a nickle in between it and the bar.Do this when saw and chain are at operating temperature.If nothing else helps try a new chain if you have reached the end of tensioning adjustments. Thank you.
Mar 25, 2011 | Makita 33cc Chain Saw w/16" Bar DCS34-16A
How do you set up a carb on makita chain saw
You provide no manual, I chose a "DCS34" a link follows: http://www.makita.ca/data/upload/tools/DCS34%20F-E.pdf
It lists no starting point for the "H" and "L" needle valves, I recommend 1.5 CCW from lightly seated. then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter and spark arrestor; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run. If the saw cannot exhale it cannot inhale.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 02, 2010 | Makita 33cc 14-Inch Bar 1.9 HP Gas Powered...
I need an instruction manual for makita chain saw DCS34
you can purchase one from store.payloadz.com most manuals cost $ 8.99. hope this helps
Apr 23, 2009 | Garden
Makita DCS34 Commercial Grade 14Inch 33cc 2Stroke Gas Powered Chain Saw Logo
111 people viewed this question
Top Makita Garden Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you a Makita Garden Expert? Answer questions, earn points and help others
