Question about Jabra BT350 Bluetooth Headset Headset
Bluetooth i had my bluetooth connected to my phone for a long time and now my phone can't find the device. HELP!
    Genius:
  • 1,689 Answers
Try another Bluetooth device with your phone. You want to know if the phone or the earphone is defective. The process of elimination is the only way.
Jerry G.
Posted on Jun 06, 2008
Customer help line
Here are the steps:
1. Make the partnership between the phone and the pc with the cable first and let it sync once.
2. Unplug the cable, turn on the bluetooth and make the pc and phone connect through bluetooth and save the device in the device list so it can connect everytime you want to sync without adding the device again.
3. Once they are connected to each other run active sync (with bluetooth still active) and press Menu-Connect via bluetooth. Here's the tricky part, it wont always connect. You have to do this a couple of times until you get a connection. For me its like 4-5 times and i get connected.
Thats it.
May 20, 2014 | Cell Phones
Tip
How to connect Bluetooth GPS using mobile phone
<p>Once I explain how Bluetooth GPS receiver to connect from a mobile phone. Bluetooth GPS Receiver is a device that continuously transmits its position (longitude, latitude and speed) using the Bluetooth protocol. If your phone is Bluetooth-enabled phone, you can connect to a Bluetooth GPS receiver to determine its position. To locate, connect to Bluetooth GPS and mobile phone to get the NMEA sentences for location tracking, you can also program a Java (J2ME) for your phone. Your program should do the following tasks: <br /> <p><br /> <p>1. Bluetooth device within the search area. Each time a Bluetooth device is discovered, discovery listener device Discovered trigger procedure. In the search is completed, the trigger listener discovery process inquiry Completed. <br /> <p><br /> <p>2. Get the name Bluetooth. We have a choice to a group list of Bluetooth-friendly name of the devices found to store. We also need a vector to devices found to store. <br /> <p><br /> <p>3. Select Bluetooth GPS receiver from the list of found devices. <br /> <p>4. Find service by the GPS device. Bluetooth GPS Receiver provides an L2CAP service so that the program needs to find this service for GPS url connection string for. <br /> <p><br /> <p>5. Get connection string from the GPS device. Connection string to the URL will have this format Url = "btspp: Address / bluetooth /:" + + L2CAP_UUID "permission = false; encrypt = false"; <br /> <p><br /> <p>6. Sign up and receive sentences from the GPS device. After plugging in the url in step 5, you can open the connection and extract sentences from the connection string. <br />
on Jun 26, 2011 | Cell Phones
Tip
How do I automatically start Bluetooth?
<p>Bluetooth is a wireless connection method used for two different devices together, like a computer, cell phone, headset or sync. You are required to enter code synchronization when connecting two devices, but most likely you do not want to enter this information each time you want to sync the hardware. Instead, you can automatically start the Bluetooth devices in sync with each other. <br /> <p><br /> <p>1. Turn on the Bluetooth device (such as a headset) and the hardware you want to synchronize with the equipment (such as your computer or mobile phone). <br /> <p><br /> <p>2. Click the "Start" button when using a computer, select "Control Panel" and finally "Hardware and Sound". Select "Bluetooth Devices" and click "Add" and wait for the computer to search for Bluetooth devices. Press "Setup" when using a mobile phone, select "Bluetooth" and activate the configuration. This allows the phone to search for the Bluetooth device. <br /> <p><br /> <p>3. Select the Bluetooth device, once it is detected (both computers and mobile phones) and enter your pair of four-digit code (listed in the user manual of Bluetooth device). <br /> <p><br /> <p>4. Press "OK" on your computer or mobile phone connects to Bluetooth. Now each time the devices are enabled on the phone and the computer automatically detect and connect to Bluetooth devices. <br />
on Jun 26, 2011 | Computers & Internet
Pairing with a motorola bluetooth device
Hello, Barb.
Here are some instructions from the manual:
To set up a Bluetooth connection, do the following:
1. Select Menu > Settings >
Connectivity > Bluetooth.
2. To activate or deactivate the Bluetooth function, select
Bluetooth > On or Off.
Indicates an active Bluetooth connection.
3. To search for compatible Bluetooth audio devices, select
Search for audio enhancements and the device that you want to connect to the phone.
To search for any Bluetooth device in range, select Paired
devices. Select New to list any Bluetooth device in range.
Scroll to a device, and select Pair.
4. Enter the Bluetooth passcode of the device to associate (pair)
the device to your phone. You must only give this passcode when you connect to the device for the first time. Your phone connects to the device, and you can start data transfer.
Hope this helps.
Apr 19, 2010 | Nokia 6085 Cellular Phone
Have blackberry flip phone, blue tooth worked fine,now shows bluetooth:disabled, can't get it to work HELP gene
Hi to enable Bluetooth follow the steps given below: 1. Click on OPTIONSfrom the main Menu 2. Click on Bluetooth then 3. Click on the Menu key (which is next to track ball) 4. click on Enable Bluetooth If you find any problem please contact the Service Provider of your SIM Thank you for using Fixya
Nov 13, 2009 | Cell Phones
How do you connect bluetooth to a sony ericsson k610
let phone in menu /settings searts for bluthooth device and the device like for earpusch on buton the same time device phone wil see it select connect and put code in 0000 and device are connect
if you want connect to pc you need first bluethooth device on pc like usb blue thooth stick and on pc you need software this are for free from itv bluesoleil google for it and also syngr software from microsoft.
Nov 08, 2009 | Sony Ericsson K610i Cellular Phone
My bluetooth doesnt work on my CU720 either. Can anyone help?
Bluetooth on the LG Shine is almost impossible to recieve connections from. First try listing the steps you tried to take to get your bluetooth working, then ill look back on FixYa and I'll try to help you depending on what level of tech spec problems you are in. Reply
  1. First go to your setting module
  2. Choose bluetooth in the menu
  3. Turn bluetooth on
  4. Choose a device (exp. headset, laptop, desktop, cell phone with bluetooth etc.)
  5. Switch device on
  6. Search for compatable devices on both things you are trying to connect
  7. If headset, only search on phone
  8. The model number or set name for the device should appear
  9. Choose name or model ( If first time using device apply 0000 or 00000 for access code)
  10. Test device connectivity and enjoy if works
  11. If this does'nt work, consult an LG technical assitance line
Jun 18, 2009 | LG Shine KE970 Cellular Phone
How to connect a sonyerricson bluetooth device with my k800i
From the Menu screen, select Settings. Scroll across to the Connectivity tab and select Bluetooth. Select Turn On. To connect your Sony Ericsson K800i to a handsfree device, enter the Bluetooth menu screen and select Handsfree. Your phone will then look for a handsfree device to connect to. Press and hold the 'call' (big) button on your bluetooth device. First it will blinks once, keep holding, then it will turn to steady blue. This is the 'pairing' status. When the phone found your device, select the device and enter the passcode (usualy 0000 (4 times zero))if required. The steady blue light on the device should go off and blinks every couple of seconds. Next time you switch on the bluetooth device it will be automaticaly recognized by the phone.
Jun 14, 2009 | Sony Ericsson Bluetooth handset pink...
Mazda bluetooth connection
delete all bt devices in your phone then try again
Oct 01, 2008 | Motorola Mobility RAZR V3
Plantronics bluetooth
you have to first put bluetooth headset in pairing mode by holding the phone hook button down until blue indicator on headset goes solid blue not flashing then set your phone to find bluetooth device by looking under your phones menu and look under bluetooth or connections make sure to turn on bluetooth function and choose find or add device phone will detect bluetooth device and will display the type of device on your phones display tell it to bond or connect once you select yes thats it the bluetooth headset will start to flash and its ready to go.
Jan 14, 2008 | Plantronics 510 Voyager Headset - PLN-510...
Jabra BT350 Bluetooth Headset Headset Logo
42 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
