Question about Hotpoint Microwave Ovens
Having just taken delivery of hotpoint ultima wmd740 washing machine I find after programming in and confirming the language selection the programme selected works perfectly. The problem I cannot understand where I am going wrong is when I push on/off button the indicator panel goes blank as it should but after a period of time anywhere from 30 minutes to 4hours the machine will turn itself on again with a beep and be back at the language selector. What am I missing so as not to get this sorted
  • 3,083 Answers
Somehow in the process of selecting the language, the new selection isn't being "set", and that's usually by hitting some button to change it permanently. Refer to the manual and review your steps. It's entirely possible that the manual is erroneous, and an extra button will have to be pushed to seal it.
I found this blog on manualsonline.com:
i cannot change the language on my hotpoint i've tried everything in the manual any ideas
Add a comment | Get notified about comments
Comments
  • Same problem here
    When moving the machine into the house the language was accidentally changed to something I can only guess is Czech. Does anyone know how to reset the machine or change the language back to English?
    Many many thanks.
    -->Was this comment useful? new Starbox("rating4049513", 4.0, {identity: 4049513, stars: 5, buttons: 5, max: 5, total: 1, onRate: saveVote});
  • RE: language problems
    You need to press the bottons stated on the manaual for a few good seconds until it beeps. Once it beeps will turn off, once you turn it back on you can then change the language to English again.
Perhaps that will help.
Anyway, good luck, thanks for using FixYa, and hope this helps.
Posted on Sep 07, 2010
We have a Hotpoint RVM1435WJ01 above the range microwave. We lost our electricity one day due to an outside electric wire splitting - when the electric company fixed the wire, the power came back to...
A mains surge may have taken out the fuse. To find the fuse, remove it from the mains, remove the outer cover and follow where the power cable enters the case. There will be a PCBoard with a fuse on it.
Always replace the fuse with one of exactly the same type and value!
Mar 21, 2011 | Hotpoint RVM1435 Microwave Oven
DRUM MOTOR NOT WORKING TO TURN DRUM. PROGRAMMER OPERATING OK AND ALSO PUMP MOTOR. HOT AND COLD WATER FILLING MACHINE OK AND EMPTYING OK.IT WOULD SEEM TO BE THE MOTOR AT FAULT? THE MACHINE IS 6 YEARS...
Your question was head "microwave ovens" but I think you are talking about a washing machine.
Replacing the motor is a matter of judgement as to the reliability of the machine generally.
If this is the first time the machine has failed in 6 years, then I would have the motor replaced.
If there have been a series of faults, then replace then machine.
(Incidentally I assume that you checked the drive belt).
Jan 06, 2011 | Microwave Ovens
Hotpoint ultima sdw80 45cm door will not keep closed when in use still doing the wash cycle
Door catch needs replacing. Can be done yourself. Top 6 or so screws removes the top section of the door and the catch is held in by 2 screws and has two easy to remove / replace.
Oct 31, 2010 | Microwave Ovens
When i put it on i put the washing in then set it to programme then it fills up with water then makes a grinding noise it does not make the noise when it spins
The drum bearing is worn. A replacement will sort that out. They are not to bad to fit. Remove the back panel, put some thick cloth or cardboard on the floor and put the machine face down (after draining the filter and drum of water!). All will reveal itself when the belt is removed and the pulley is taken off with a tripod type puller. Remove the old bearing from the shaft and housing and replace with the replacement one. Bearings are readily available from online stockists are are fairly inexpensive.
Hope that helped.
Oct 20, 2010 | Microwave Ovens
Hotpoint washing machine smells
Here is a tip that I wrote about front load washers and the smells that seem to go along with them....
Stop Washing Machine Smell, Mold, and Mildew
http://www.fixya.com/support/r3993813-stop_washing_machine_smell_mold_mildew
heatman101
Aug 13, 2010 | Microwave Ovens
Neffcombination built in microwave and grill
The options for language selection will be detailed in the setup menu in the manual. German and English are similar enough to work out the steps to return it to English. A manual can usually be acquired from the manufacturers website, or from download sites. (Internet search your brand and model number).:::Spiceweasel.au.
Jan 28, 2008 | Neff H5642 Convection / Microwave Oven
Microwave Ovens Logo
273 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Jerry Greenberg
Jerry Greenberg
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
