Question about West Bend 33600 Coffee Maker
On plugging in the Urn I blew contact breaker in the church! I repeated this at home with same result. SHOULD I REPLACE THE POWER CABLE?
  • peter_voss Sep 07, 2010
    Thanks clay58, I'll follow your suggestion and let you know
  • 2,841 Answers
There is a short in the unit somewhere. It can be the power cord or it can be internally in the coffee maker. You can test the power cord before replacing it with a multimeter. Set the multimeter to OHMS. Take the power cord and connect the red probe to one connector on one end of the cord. Touch the black probe to both connections at the other end. You should only get a reading on one of the connections. Repeat this with the other connector. If you get a reading on both connections then the power cord is shorted out and must be replaced. In other words you should only have continuity on one of the 2 wires in the power cord. If it shows continuity on one connection on one end of the cord and 2 connections on the other end you have a short.
Posted on Sep 07, 2010
My 4H.P. 25 gal. air compressor doesn't work, when i plugged it in it blew the beaker and the outlet. Now it's dead?
Check motor reset on end of motor. Check cord for damage, insure insulation isn't cut. If you've reset your breaker for receptacle , make sure switch for compressor is off, plug in , then flip switch. See if motor attempts to run. If the problem repeats, motor could be shorted if cord is ok.
Sep 29, 2015 | Air Tools & Compressors
Blowing fuses when power is applied on my Toshiba VHS M-754
you might have to change the entire power cord as well as the plug
Apr 13, 2014 | Toshiba Six Head Vcr Deck M-752 W/ Remote...
TV will not turn on
Check the wall outlet, make sure there is power at the wall. If not, check the breaker panel. If there is power at the wall, check the TV for a manual on/off switch. If you have a power switch on the TV, turn it off, wait 10 seconds, then turn it on. If no power switch on the TV, unplug the TV for 10 seconds, then plug in again. Use the remote to turn the TV on. Check for a fuse or circuit breaker on the TV, usually near where the power cord enters the TV.
Make sure you have good batteries in the remote. If all this fails, then something may be damaged inside your TV, as a result of a power spike before the power went out, or when it came back on.
Take it to a repair shop.
Apr 07, 2014 | Magnavox 19me601b/f7 19-inch 720p Lcd Tv
Life Fitness 4000 repeatedly blows outlet circuit breaker
If there was a fuse in the treadmill it certainly wouldn't cause your main circuit breaker to blow. It sounds like the motor burnt out and shorted- which is causing your house circuit breaker to blow. There is a chance that the ball caused some other damage that is creating the short but my bet is on a burnt out motor. You would need to disassemble the unit and test for short circuits to verify.
Mar 04, 2014 | Life Fitness Lifefitness 4000 Treadmill...
Where can I locate Coffee Urn replacementThermostat?
Abtec seems to be the only place.
Search Results
DeLonghi DCU72 Coffee Urn Parts - eReplacement Parts
https://www.ereplacementparts.com/delonghi-dcu72-coffee-urn-parts-c-122345_1223... Need to fix your DCU72 Coffee Urn? We have parts, diagrams, accessories and repair advice to make your tool repairs easy.
Amazon.com ' Delonghi DCU72 Ultimate Coffee Urn: Coffee Urns
https://amazon.com/Delonghi-DCU72-Ultimate-Coffee-Urn/dp/B00064XTDK Enter your model number to make sure this fits. 20-60 Cup Capacity; Keep Warm Function - Once it's finished brewing it automatically switches to the warming cycle and keeps your coffee at the perfect temperature. Freshness Indicator is activated by the keep warm function and tells you how long the coffee has been ...
Delonghi coffee urns - Abtec Parts
abtecparts.com/Delonghi_coffee_urns.htm Large glass knob with nut for lid holes measuring 1.1/2 to 2.1/2 inches. ... Glass knob for models DCU50T, DCU60, DCU60T, DCU61, DCU62, DCU62B, DCU70, DCU70T, DCU72 manufactured before 2001. ... Glass knob (fits 2 inch diameter hole) for models DCU50T, DCU60, DCU60T, DCU61, DCU62, DCU62B ...
delonghi model dcu72 coffee urn thermostat Google Search
Mar 06, 2018 | Coffee Makers & Espresso Machines
Computer/Motherboard Issues
buy a circuit protector for just ur computer and call a electrition
May 12, 2010 | Gateway 507GR PC Desktop
Bulb blew on cooker hood and I replaced both. Light still won't work and neither will fan - both working fine until bulb blew.
hello. I can assist you. begin by going to the electrical panel for your home. You will be looking for the circuit breaker or fuse that controls this hood. Chances are the actual problem is that the fuse blew, or the circuit breaker kicked off. To reset, replace the fuse with a new one of the same amperage, or turn the breaker on and then off and then back on again.
Nov 18, 2009 | Televison & Video
My daewoo microwave/toaster blew my breaker upon resetting it and plugging in the microwave it blew again then it tripped my GFI what could be the problem?
Probably a short inside the microwave circuitry.  I had a Daewoo and had nothing but trouble with it.  Main board went out in a year, then again in another year.  Finally went to Home Depot where I bought it and was told that they had nothing but trouble with them and quit selling them.  Now I have a GE Spacemaker.
Apr 22, 2009 | Microwave Ovens
PS3 vs Toshiba 65" 65hm117
Sorry to here about your problem. I have a 65HM167 Toshiba tv which is the same as your model, and I have my PS3 connected HDMI with no problems. Try using a different brand HDMI cable and a different HDMI input on the tv if you have not already done so. Hope this does it for you, good luck.
Mar 26, 2008 | Sony Playstation 3 (PS3) Console
West Bend 33600 Coffee Maker Logo
101 people viewed this question
Top West Bend Coffee Makers & Espresso Machines Experts
Douglas Dinnebeil
Douglas Dinnebeil
Are you a West Bend Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
