Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Water won't come out when you press handle to shampoo carpet.
    Problem Solver:
  • 9 Answers
I Had the same problem with my model 79011...take the upright handle apart & you will see a pot-metal rectangular box midway down the lower section of the handle with wires on it & 2 hoses attached. This is the water heater unit. LET IT COOL IF YOU JUST HAD THE UNIT ON AS IT WILL BE HOT!!! Take the hoses off & carefully **** the inlets out ( do NOT probe more than about an inch in) with a piece of coathanger wire. Flush heater unit out by hooking a peice of hose up to the heater unit & blow into it to flush the loosened crud out. Hook it all back up & it should work like new! What happens, is the alkalis in the cleaning solutions react with the pot-metal & cause corrosion to build up, eventually clogging the unit, thus not allowing waterflow thru it. Built to fail just like all modern junk! ;) Hope this helps! Ross
Posted on Sep 13, 2010
4 Suggested Answers
  • 37 Answers
SOURCE: shampoo won't **** up water on carpet
try seeing if your lint filter is clogged. you will find this in the upper section of the water tank.
Posted on Sep 24, 2008
SOURCE: vax carpet shampooer wont release shampoo
if you unscrew a bit on the base that allows you to take off the brush, you will see a black plastic strip with very small holes in it. These are where your shampoo comes out of. Take a needle and re-pierce these holes and it should work again. I have just sorted mine out. good luck .
Posted on Mar 08, 2009
  • 84 Answers
SOURCE: NO WATER COMING OUT FOR SHAMPOOING /DUMPS WATER WHEN UPRIGHT
there is a belt inside that runs the pump to spray the water. I would take it in a have it replaced. Mine did the same exact thing.
Posted on May 25, 2009
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
SYSTEM:
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
Shampoo:
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
800-775-6586
GoodVac com
Feb 14, 2015 | Kirby Ultimate G Bagged Upright Vacuum
Don't know how to use with shampoo
Best to not put shampoo in machine. Put traffic lane cleaner in sprayer with hot water, spray onto carpet after thorough vacuuming, allow cleaner to dwell 5 to 10 minutes and clean and rinse with fresh clean water in machine. For best results do NOT put shampoo in he machine even though it was designed for it. Most of the machines brought in for repairs are clogged with soap gunk. Carpets will be cleaner and stay clean longer because the soap has been rinsed out of carpet
Sep 26, 2013 | Vacuums
Carpet cleaning
Carpet shampoo is popular way to clean your carpets. There are many different brands of carpet shampoo, so make sure that you follow the guidance on the label.
  1. Make up the solution as directed on the packaging. In many cases, the product will need to be diluted with water.
  2. Use just enough carpet shampoo to cover the area.
  3. Do not make the carpet too wet - not only is this a waste of detergent, but it's also going to increase drying time.
  4. Scrub on the particularly stubborn areas using a hard-bristled brush.
  5. Let the carpet dry.
  6. Vacuum the shampoo once it has dried.
Carpets and floor cleaning
May 17, 2013 | Vacuums
It is not dispensing the shampoo on to the carpet.
Firstly, please ensure that there is shampoo in the tank and the tank is correctly and fully inserted. There are 2 ways to dispense shampoo on to the carpet:
1. Use the solution trigger on the underside of the handle (numbered 2 in the picture below)
2. For tough stains use the "Clean Surge" button to dispense extra shampoo (numbered 3 in the picture below
Dec 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
I cant figure out how to **** up water with my kirby dimond
Vacuuming a wet carpet with your Kirby or any other vacuum not designed for wet pickup could do serious damage to your machine and there is a real danger of electrical shock to the operator.
Your Kirby Diamond and every other Kirby for that matter is NOT designed to pick up water!! Even with the shampoo system attached it will NOT pick up water or the shampoo foam. Your Kirby spreads the shampoo foam around on the carpet to clean it. You then only vacuum a shampooed carpet after it has completely dried.
May 20, 2010 | Kirby Ultimate G Bagged Upright Vacuum
SteamVac Carpet/Upholstery Deep Cleaner Vacuum: how do i add the solution to the steam vac? how mu...
You didn't give a model number so I'll tell you both methods. The F5xxx and F6xxx models have a cap at the top of the clean water tank that doubles as a measuring cup. The cap is about 3 inches in diameter. Fill the cap to the fill line with shampoo and dump it in the tank. Then fill the tank with hot (Not Boiling) water.
The F7xxx series has a 2 section tank. The large section is for hot (Not Boiling) water. The smaller section is for shampoo. Fill the smaller section with shampoo and the Steam Vac will mix the water and shampoo for you in the proper proportion.
May 16, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Having trouble shampooing
I found this on a website. Hope it helps others...
by Mainelyvacs in: Kirby
  • First a short explanation of how the Kirby shampoo system works: Kirby uses a “Dry Foam” type of shampoo. Basically, it spreads a shampoo foam solution on the surface of your carpet. This foam needs to stay on the surface of the carpet until it is completely dry (usually 1 to 2 hours depending on temperature and humidity) As the foam dries, it soaks up grease and dirt. You then vacuum the carpet and up comes the shampoo residue along with the absorbed dirt and grease. It does a very good job on the surface but will not extract stains from the bottom of the carpet or carpet pad. Several other brands such as Electrolux, Hoover and Koblenz make Carpet Cleaning machines that use the same system.
    So, you’ve read your manual, you’ve removed the carpet cleaning nozzle and the bag assembly from your Kirby, you’ve installed your shampoo tank and carpet shampooing nozzle tray and you start to shampoo but all you get on your carpet is a puddle of soapy water and no foam. Here’s a few things to look for:
  • Make sure you are using a Dry Foam Shampoo(preferably Kirby) and NOT an extraction shampoo, the Rug Doctor shampoo you had left over from your last rental will not work.
  • Make sure you have the correct mixture. If you are using Kirby Dry foam shampoo you simply fill the tank with water and put a tank cap full of shampoo in with the water. You can use other brands of “Dry Foam” shampoo, but the mixture ratio may be different, so read the label first.
  • Don’t reuse last year’s leftover mixture, it’s probably no good.
  • Make sure a family member didn’t pour any leftover mixture back into the empty shampoo bottle - further diluting a mixture will not produce any foam.
  • Don’t use shampoo that’s seen extreme temperatures.
  • Check the tank and make sure that the sponge filter is in place and if it is in place that it is not deteriorated. The sponge filter is located under the tank at the point where you attach the tank to the hole that you removed the bag assembly from.
  • Check the hose that runs from the tank to the nozzle. It should have a screen in the end that attaches to the tank (older models had a cloth screen with a metal retainer, models after 1989 have a 1 piece metal and plastic screen.
Apr 13, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Instructions or manuel was not included.
i downloaded the manual for your machine, but not sure how to access it for you,but i do know about the problem, the tank that sits down on the front of the steamer and it has 2 clips that you push in to lock the tank is where your dirty water is put in when you are cleaning your carpets. the tank above ,the one where you put your solution and water in is what is used to shampoo your carpet. on the handle is a trigger (black) button ,this is the button you push in to release your solution onto your carpet. release the button to extract the water from your carpet,moving your steamer in a back and forth motion. the trigger button is the only button on the machine and is only used to put the water /cleaner located in the upper tank on your carpet, releasing this button and moving your steamer back and forth over the shampooed part with extract your dirty water into the tank that sits below the solution tank. go on www.hoover.com and click on carpet cleaners ,scroll down to find yours and click on manual. and the owner manual will download and you can print it out for future reference, i hope this will solve your problem, sandy
Nov 29, 2008 | Hoover F5810 SteamVac Upright Vacuum
How do i put together my kirby carpet shampoo system?
Vacuum thoroughly before shampooing for maximum cleaning. Then, remove the bag and the Power Nozzle to prepare for shampooing. Turn the Carpet Shampoo System Nozzle Belt Lifter to the right of the center position (fully clockwise) until the green arrows line up. a4bbc62.jpg Slide the slots on the side of the Carpet shampoo system over the outer shoulders of the Carpet Shampoo System Tray. e14fe2e.jpg While pushing up on the Belt with your finger, turn the Belt Lifter left (counter- clockwise looking at it from the front) until the red arrows line up. (The Belt Lifter Hook will catch and stretch the belt.)
Press the bottom Toe Touch Pedal all the way down to raise the front of the Kirby.
While sliding the carpet shampoo system Nozzle/Tray Assembly toward the Kirby and over the Motor shaft, connect the hooks on the bottom rear of the nozzle to the Attaching Bar.
Push the nozzle up against the Kirby and turn the Accessory Lock to the
right (clockwise) to lock the nozzle in place. To engage the belt, turn the Belt Lifter
all the way to the right (clockwise) until the green arrows line up. Then lower the Headlight Hood
Apr 18, 2008 | Vacuums
Kirby Vacuum Shampoo Attachment
If your trying to shampoo your carpets but the water flow is to weak and it trickles through the spout to the carpet leaving small puddles
This problem often occurs when the foam filter is not replaced after rinsing or ends up in the shampoo hose at an angle preventing foaming. If you take the small shampoo hose of the shampoo tank the filter should be on the tank, if not, it may have come off and be in the hose. If it’s not there locate it, likely in the area where you last cleaned the shampooer or in the box, and put it back on the tank. While this should be cleaned after each use, care should be taken to replace it and not lose it.
The problem may also occur if you don’t actually add the Kirby Dry Foam Shampoo to the water or if you use some thin else.
Take care to also clean and replace the air filter after rinsing. It is located under the shampoo tank where the tank fits onto the vacuum.
Phil-T
Sep 07, 2007 | Vacuums
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
509 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
