Question about JVC Televison & Video
ANSWER TO JVC LT-42X579 blinking blue light, no picture and clicking noise When I cut on my TV it would not come on. Instead the blue light was blinking and after a while I heard a ticking/clicking sound I contact JVC and was told to first make sure your cable box or whatever you use to normally watch TV is powered on and is ready to work He told me to unplug TV for 10 seconds at least. Then he had me press and hold down the "MENU and VOLUME DOWN (-)" buttons, at the same time for about 10 seconds. Then after 10 seconds of holding the 2 buttons down, he had me continue to hold the 2 buttons and press and let go of the power button. In other words after 10 seconds of holding down the volume down (-) and menu buttons, add the third button (power) and immediately let go of all 3 buttons, at the same time. It worked for me instantlynd hopefully it works for you!!!
SOURCE: Blue light
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first.
Posted on Feb 20, 2009
SOURCE: AKAI PDP4273M1 - Unit powers up then shuts down.
I just repaired one for the same trouble. The input to the main processor from the standy switch had shorted to groung. This was probably caused by static inserted when pushing the power button. The processor is not a replaceable part. The part number for the main board is E3761-058010-2. It costs between $140 and $150. I found it on-line at Shopjimmy.com.
Good Luck!
Posted on Feb 25, 2009
  • 257 Answers
SOURCE: I have a JVC LT-42X579 TV. I got home tonight and
This is common problem of the failure of power supply board inside TV. You need technician to figure out this problem.
Posted on Aug 13, 2009
  • 8457 Answers
SOURCE: On/Off blue light blinking, TV won't come on.
Ur power ic inverter board is dead.
U need new one.
Posted on Aug 19, 2009
Testimonial: "Thanks for the advice. Will try it."
rylee_smith
  • 8619 Answers
SOURCE: We have a Sharp LCD
Hi
Thanks for using FixYa. Blinking light means that the power is getting to the unit however, as its not working which means that the power board should be checked. To start with open the back of the unit and then check the power supply board for any bad (bulged/swollen) capacitors. Power supply board is the board where all the power cords/plugs goes into. After you have checked that also check the main board and if you can use a multimeter to test the components on these boards. However, from your earlier posts it seems to be the main board that is bad and should be replaced. All this should only be done if you have knowledge of internal circuitry of the unit as the components consists high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 02, 2010
Blinking blue power light
These blinks are fault indications. Count the number of blinks occur at one time switch ON. From the number of these blinks, you can get an idea about the faulty circuit side in the TV. You must have some knowledge in electronics to follow. If you have confidence, check the link. It has details about the blinking codes to JVC TVs. http://electronicshelponline.blogspot.com/ Make sure about the number of blinks, before you proceed. Switch the TV On and OFF for at least two times to make it confirm. Pull up older posts by that site, by its left sidebar.
Jun 14, 2013 | JVC LT-42X579 42 in. LCD TV
Blinking blu light on JVC LT-4TG30J
Its not making it out of standby, you could if can safely get it apart (ask if in doubt) inspect the power supply board for damage or puffed up filter caps, then consider having a shop look it over--All makers only sell circuit boards and no individual parts.
Dec 11, 2012 | JVC LT-42X579 42 in. LCD TV
If it has more than 1 port try another---If it has component try connection there.
Mar 22, 2012 | JVC LT-42X579 42 in. LCD TV
My JVC LT-47X579 is not "turning on" since we
hmm i had the same problem the saturday before on my lt-42x579but i didnt have anything hooked up to it blue light came on then flashed ..no pic this happend one week after it was pd off from a rental store we should investigate
Dec 22, 2010 | JVC LT-42X579 42 in. LCD TV
Tv won't come on blue light at bottom is blinking.
Most likely you have a bad main module. Communication between the main module and the rest of the set is being lost.
Oct 14, 2009 | JVC LT-42X579 42 in. LCD TV
Aug 13, 2009 | Televison & Video
My tv won"t turn on.
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Apr 07, 2009 | JVC LT-42X579 42 in. LCD TV
JVC 42 inch LCD HD TV has no picture or sound
utencilio posted this fix. It worked for my JVC LT-42X579.
2)wait 10 sec
4)wait 30 sec
Jan 28, 2009 | JVC LT-42X579 42 in. LCD TV
Televison & Video Logo
289 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
