Question about Dell Optiplex GX150 Tower Computer - 1GHz - 512MB Ram 40GB Hard Drive CDRW - DVD - 17" Trinitron Mon... (GX150TWR1G51240CDRWD) PC Desktop
Finding ram i added 128 of ram to my computer but for some reason my pc dosent recognize it..can you help me plz
Take a eraser on the end of a pencil and stick it in the floppy while holding down the start button and if it beeps three times you have fixed it,
Posted on Jan 07, 2009
    Problem Solver:
  • 13 Answers
I understand you have a Optiplex GX150 Computer. Have you tried this link?
http://support.dell.com/support/edocs/systems/opgx150/en/ug/index.htm
Check the technical specifications, and click on "Installing Upgrades" and make sure your RAM that would added fits those specifications. It could be your motherboard is just not compatible with the type of RAM you bought.
Cheers,
Posted on May 14, 2008
  • 25 Answers
Try to get a eraser to clean the contact of you're new ram!
Dell dimension 4700- added 2gb module in memory slot one, color coded white, and added 2gb module slot 3, also color coded white. only 2 gb recognized by computer, the second module is not recognized. ...
This motherboard uses inter-leaved RAM and RAM needs to be installed in pairs.
Check the BIOS RAM settings.
Try and use the same make of RAM.
One of the RAM modules may be faulty.
Try inserting the RAM module that was in slot 3 to slot 1
Feb 19, 2011 | Dell Dimension™ B110 PC Desktop
Dell latitude wont read 256 megs of ram only 128
The c600 can handle up to 512MB of RAM, so it's likely one of your RAM sticks is bad or not seated correctly. Are you using two 128MB sticks? Remove the stick from the second slot and turn on the computer with only one stick installed, and see if the RAM is recognized. Then take that RAM out and try the computer with only the other RAM stick -- if either is not recognized, that stick is bad.
If both are recognized, try reinstalling both RAM sticks and see if the computer will recognize them. If not, make sure they are both seated properly. You may have a problem with the second RAM slot if it is still not recognized. If you have access to other RAM, try that too and see if it is recognized.
Jul 27, 2010 | Dell Latitude C600 Notebook
I need to know more about a Gateway Performance 800 motherboard. I added a second 128 meg SDRAM 100 Mhz simm in bank 1 (the board came with a simm in bank 0). The BIOS recognizes the original simm as 128...
Check the specs for your new ram. It sounds like you have double density ram installed. If your motherboard only supports single density it will only see 1/2 of the modual hence 64meg showing for 128 stick.
Please rate this solution if it has helped you.
Thanks, Gary
Jul 11, 2010 | Gateway Performance 800 PC Desktop
I have intel 845 glly desktop board with 256 mb SDR. When I added 128 mb SDR in the second slot it is not recognising it. How to add 128 mb SDR with 256 mb SDR. When I fix 128 mb ram in first slot and...
1st try to exchange the cards in the slot.
2nd try another card
3rd ur RAM slot may not be ok
4th ur RAMs may not be compatible
5th ur new RAM card may not be ok
use same type of RAMs, and same size...
if u have 256, add 256
if u ahve 128 add 128
if u have SDR then dont add DDR
getting compatibility is little difficult...
some times no combinations can work...
note...technology keeps changing...so a old RAM card that was bought years ago may not be compatible with a new RAM card....
even i got all my old RAM cards(256+128) removed and got 2 - 512mb of the same type fixed...even i had issues with my RAMs for 6 months...
Dec 27, 2009 | Intel D845GLLY Motherboard
I want to use both RAM sticks
You may not be able to. the sticks usually have to be added in matching pairs. some older machines may read them mismatched
Aug 19, 2009 | Microsoft Windows XP Professional SP2 Full...
HP deskjet requires minimun of 128 Mb ram. My computer has 128 Mb ram but the printer doesn't still works.
First uninstall the printer driver and restart the machine then again reinstall the printer driver using typicall settings , after installing the driver again restart the machine then check
May 26, 2009 | HP D1560 Deskjet Printer InkJet
Pc freezes when new memory installed
You problem is the motherboard.On your PCs mother board the 128MB that came with the motherboard might be the highest memory the chipset on your motherboard can accommodate. The chipset is built in and you cannot change or upgrade it. You can speed up the PC with how many memo sticks you added, if the chipset can handle. So it look like if you want a fast PC you need to get a new motherboard chipset with higher memory clock frequency.
Here's the pic of the chipset on the motherboard(square type)
Nov 24, 2008 | Compaq Presario 5000 PC Desktop
Ram
Check the configuration of your system, it probably supports 128 MB of RAM at max.
Jul 16, 2008 | Compaq Presario 5000 PC Desktop
New Hard Drive over 128 GB on Dell 4600 - but only recognizes 128 GB!
Check that your motherboard supports the high capacity of HDD
Install the OS having the latest service pack combination.
Let me know if your problem is solved and rate me as FIXYA!
May 10, 2008 | Dell Dimension 4600 PC Desktop
Wont recognize additional ram
It could be the wrong ram that u are using when i put extra ram in I make sure they are all the same brand. some boards take 2 different types of ram (speeds) i would go back to crucial with your good ram in and then do a check and see what ram your board needs
Dec 20, 2007 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Computers & Internet Logo
96 people viewed this question
Alun Cox
