Question about Sony VAIO (PCWA-A200)
Pls i want to know why my laptop makes noise when i try to to switch it on? It fails to come on and then makes so much noise. I notice this problem two days after i cleaned the lid with a piece of cloth water and a powdery substance does my
  • 358 Answers
This is likely to be as a result of your fan not cooling the processor properly again, possibly because of the powdery substance that was used to clean the system, and it has now been drawn into the system by the fan.
Therefore my suggestion would be for you to unscrew your laptop (If you can do it by yourself), and try to clean, or better still replace your processor fan.
If you cant do it by yourself, you can easily get a technician to do it for you.
I have actually had the same case before, and after doing what I've just told you, it stopped behaving like that.
And you are also still very lucky, because after a while, if the case worsens, the system will not just be making noise, but it will start to overheat and be powering-off automatically.
Then always make sure that your laptop is in a well ventilated, cool environment and that the environment is free from dusts.
Hope this helps you out.
Posted on Sep 08, 2010
Weird beeping noises
Need to know what make and model of laptop you have. It could be the CD drive's internal hardware, or the hard drive beginning to fail, or even a failing fan. You may be able to get MSI to repair it for free if you call them (If it's a warranty issue).
You should make a back up of anything important on your laptop if it's about to fail...
Jan 14, 2014 | MSI Computers & Internet
Hard
  1. Open the cover that is over your HDD
  2. Remove the Hard Drive from it's casing
  3. Now replace the HDD ensure everything is connected properly
  4. If possible, power up and listen for the HDD to spin, if it's making no noise or a very noticeable clicking noise it's time to purchase a new HDD
  5. If not power on anyway and see if you get the same error.
  6. Try a spare HDD instead, this would indicate if the HDD you have now has failed also
Let me know how you get on
May 30, 2013 | HP Compaq 8510p Notebook
No power with adapter or battery no lights on laptop, no noise
More than likely your power supply has failed. Your computer probably ran on the remaining battery power when you noticed it. If you have another power supply to try you could determine that. Also, the plug in on the computer takes a beating on laptops and that could have failed as well.
More than likely your battery is in good shape, it just hasnt been charging due to the poor charger.
Hope this helps.
Feb 23, 2011 | Computers & Internet
A whirling sound comes on when booted. Have to lift it and thump atop desk to stop noise. Its getting worse and requires repeated thumping for noise to stop....pls help! Model no: ax1800-e1232 Also...
If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
Nov 01, 2010 | Acer Aspire One D150-1587 Netbook
My Sony PCG-FR55E/B switches off by itself after 30seconds or 2 minutes or between 10 minutes and 1 hr.Pls help me.
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
If none of this solves the problem, or is not the case, then you might have a bad motherboard
Sep 22, 2010 | Sony Computers & Internet
Scratching Noise
Spray some WD-40 on the pully where the belt rests on the pully while the engine is running and the noise will go away, also make sure the belt is tight enough around the pully, if it is loose then tighten it
Nov 27, 2009 | 2004 Chrysler Pacifica
My wireless connection has gone down - internet connection is fine, AOL say I need to turn my wireless connector on but I didn't do it initially and don't know how to do it - help pls!
try a system restore first to the date when laptop was working fine with the wireless. if fails then uninstall then reinstall the wireless driver. if fails check if the wireless device still detected in the device manager. if fails then reseat the wireless card.
if you are using a wireless device thru usb then make sure the usb ports can read other usb devices just to isolate the case. if fails then do a clean installation.
Oct 21, 2009 | Computers & Internet
Loud buzzing noise......possibly the fan?
is the battery ok? have it tested, sounds like a weak battery that is failing, the battery lasts about 2 years in most laptops.
Sep 04, 2009 | Compaq Presario Fan
My Flair Ari purifier makes much more noise
Sounds like Motor or bearing is failing.
You could order parts but you will find it less expensive to replace unit. Than trying to repair.
Please rate. Hope this helped. If i can help you further let me know. Good luck!
Mar 09, 2009 | Ecoquest Flair Air Purifier
Computer won't turn on
RAM faulty try reseating it or replace the ram an check
clarify ur problem more if not solved yet
pls rate me fixya if i solved ur problem
Mar 04, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Sony VAIO (PCWA-A200) Logo
29 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
