Question about Philips 32PW6006 32" TV
Power light not on, no sceen on , whistling sound coming from tv
  • Philips Master
  • 11,800 Answers
The whistling is caused by the power source that is overstressed by a short - a big part inside it has failed. The tv must be opened and the parts tested by a pro. Call one, there's nothing else you can do.
Posted on Sep 07, 2010
Whistling sound
This tv whistling sound are causes by a high voltage currents flow from it is tv power supply board it self not functions properly anymore.That the board where the power a/c cord plug into it.Those high voltages tranformers have gaps in it solders joints and now it not letting high voltages currents flow smoothly anymore,that where the whistling sound came from.Tries take the tv aparts,tries to put some kind harden or supper glues to all those high voltages tranformers,might help or soften the whistling sound alot.If that did not help all or alot.Try website like Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Jul 28, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Our Mitsubishi wd-65833 tv turns on and makes a whistling sound like it is powering up-then the red lamp light comes on and it makes the whistling sound in reverse (kind of like the sound of a bomb...
This mechanical whining sound is typical of what is know as a color wheel fault. Color wheels are mechanical color disk that spins. generally if they do not reach a certain speed the set will shut down. It is a moving part and anthing that moves will eventally not move. other possiblilites might be cooling fans if they shut down then the lamp will shut down. to determine which a technician will need to remove the back and isolate where the sound is coming from.
Apr 21, 2011 | Televison & Video
Can't get a picture on tv
high voltage issues.
needs a power supply/deflection board or maybe a flyback transformer
200-300 $
May 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Whistling when TV is switched on. LG LCD 32''
If the sound is coming from the back of the TV, then the issue is with the power supply and may get worse causing the TV not to power on.
If the sound is coming from the speakers, then the issue may be with the main board, an audio hookup to the TV, and or a bad ground loop with the TV and the connections to it.
May 17, 2010 | LG 32LG30 32 in. LCD HDTV
My sceen and sound have stopped working. just black.
If you get a LED light that comes on or an blinking error code, then most likely it will be main board. It could also be the power supply or panel depending on the error code (number of blinks).
If the TV is completely dead (no blinks or standby light) the power supply board needs to be changed.
Oct 08, 2009 | Televison & Video
When i turn on tv u hear a whistle sound and light comes on then off then whistle sound it does this 3 time and i get nothing
Your horizontal output transistor is probably bad which is causing the problem you described also you may have a bad flyback transformer.
Sep 17, 2009 | RCA HD52W59 HDTV Projection Television
When i turn on tv u hear a whistle sound and light comes on then off then whistle sound it does this 3 time and i get nothing it is a rca hd52w59
Call UED for rebuilt Deflection Board 1-800-648-6657 With all the things that go wrong on those sets its better to just replace Boards
Sep 16, 2009 | RCA R52WM24 52" HDTV Projection Television
Rca d52w26 makes a long whistle noise
how long? 3 seconds.. does it sound like chirping? is it comeing from back. smell anthing?
Nov 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV screen wont turn on but just a loud noise coming from the tv
I think maybe the G-board needs to be replaced. A TV shop will have to repair it. They normally start around $200.00
Jul 02, 2007 | Panasonic CT-32G23 32" TV
Continuous low whistling or thin buzzing noise
The high pitched sound is an indication that theres a short most likly in the Hi voltage sweep section or power supply and with out the proper training you should not even take off the back as there are no user replaceable parts inside of these sets. All the parts are soldered in and you can not look at them and see that they are bad.. its almost like when your check engine light comes on you look but what do you see without a computer to read the on board computer vto see what the problem(s) are. Take the set into or call a pro to assist you with this repair. good luck
Jul 25, 2006 | Panasonic CT-27G33 27" TV
Philips 32PW6006 32" TV Logo
130 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
