Question about Acer Aspire 3000 Notebook
Auto hibernated, will not power back up
Acer 3000, working fine, all of a sudden, went to hibernation mode and hut itself down. Only lights come on is the two on the front flash when you press power, power light does not come on, fan does not start,,,19v of power coming out of power supply as it should be,,,,any help?????
  • spikejeff May 14, 2008
    Still same results,,,,,nothing
Problem was power jack was bad, replaced power jack on motherboard and no more problems
Posted on May 25, 2008
    Scholar:
  • 72 Answers
It's possible that the laptop is stuck thinking it should be resuming from standby but cannot find the data in memory. Remove the battery, unplug the power cord, and hold down the power button for at least 10 seconds. Then plug JUST the power cord back in and try to boot the system. If you still get no response then it's possible that one of your RAM sticks is going bad. With the battery and power cord removed try removing both sticks of RAM. Then try to boot the system again with only the power cord in use and no RAM installed. See if you get some sort of response from the BIOS. Hold down the power button to turn the computer off again, remove the power cord, and then try booting the system with just one of the memory sticks installed. If you can isolate one of the sticks as causing the failed boot, then that stick is most likely faulty.
Posted on May 13, 2008
  • Rick White
    Rick White May 14, 2008
    If the machine will not power on at all (no fans, no backlight) then most likely something is either fried or disconnected on the motherboard. Before submitting your laptop for repair the only thing I can think of is to remove the battery and power cord and let the laptop sit for a day or so without power. If it won't boot after that then you will have to get it serviced.
My HP compact nc6000 laptop went to Hiberating mode and i don't know how to fix the problem. If i could please get help that would be great. i just got this laptop yesterday. it was working but all of...
Hi Jessica,
Hibernation mode usually turns the computer off but saves any work. Then you would start it back up by hitting the power button, it will boot up and you log in like normal and the computer should be as it was before it went into hibernation.
If you can't get it out of hibernation by pressing the power button, try holding the power button for 5-10 seconds. The laptop may actually still be on, and holding the power button will cut if off. Once the computer is back on you can change the battery options(hibernation/turn off settings) in Windows by going to the bottom right task bar and right clicking on the battery icon. Normally you will have an option like "power saving settings", "battery settings". In this setting window you can turn off hibernation due to inactivity.
Let me know if you have any questions.
Regards,
G33k
Jul 09, 2011 | HP Compaq nc6000 Notebook
Hibernation mode
First thing to try is to remove the battery and disconnect the AC adapter. Press the power button for a full 10 seconds to drain residual power from the capacitors on the board. Give it 5 mins then put the AC adapter and battery back in and give it a try. You might also refine your hibernation settings - I had a 5000 which is similar and finally turned hibernation off. Also check for a pin switch that the lid pushes down when it closes to see if something is holding the switch down when the lid is raised. I dont remember if that model has a mechanical push switch or a magnetic. Magnetic shouldnt do it but mechanicals are very prone to getting stuck.
Jul 02, 2010 | Acer Aspire 3000 Notebook
My Acer Aspire One went into hibernate mode by itself and am unable to turn it back on unless I remove the battery and use it solely on electricity mode. Please help.
keep press power button for 1 mins and your laptop will turn off. when you turn on your laptop. disable hibernate mode.
to return to your desktop from hibernate mode press power button quickly. windows will resume
May 04, 2010 | Acer Aspire One PC Notebook
My Acer went into hibernation in the middle of
You can try this ... you probalby already have ...
Unplug the external power. Remove the battery. Come back tomorrow. Put the battery in. Reconnect the external power. Come back the next day. Give it a try.
If you are still under warranty, Acer has a pretty good Chat Support program. Give them a try.
Thanks for your interest in FixYa.com
Feb 05, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One in permanent hibernate ''coma''
There have been times when Ctrl + Alt + Delete has brought the desktop back up. Usually, hibernation is disrupted by simply pushing the power button once, the computer will eventually come out of hibernation. Most clients I have done work for have me take hibernation off completetly, this is done in the control pnel under power options. There is a tab specific for hibernation.
Nov 30, 2009 | Acer Aspire One AOA150-1570 Notebook PC
Hibernation
Remove the battery and unplug the laptop. Hold the power button down for 10 seconds. Plug it back in, pop in the battery, turn it back on.  Let me know if that works.
Feb 02, 2009 | Acer TravelMate C110 Tablet PC
All of a sudden" going into hibernation"
try to open ur laptop cover .
on the mainboard there is usually a jumper located near the cmos battery. try to change its position for 3 seconds and return it back to its normal position.
this way u will clear the board memory .
start ur computer and load default settings.
hope this will help.
May 14, 2008 | Acer Aspire 3000 Notebook
Hibernate mode
Press the power button it might flash
Apr 02, 2008 | HP Pavilion dv6000z Notebook
Acer LCD Monitor
It is with your system. You might have hibernation enabled and many advanced video cards cannot recover from a bios or control panel timed hibernate. Start by using the Power Options from the control panel. Select "Always On" for everything and select the Hibernate tab to be sure that the Hibernate check box is not selected. Make sure you APPLY the settings. If the problem goes away, you can tweak the settings to get the power savings features you want without losing your system..
Dec 11, 2007 | Acer AL1711 17" LCD Monitor
Acer Aspire 3000 Notebook Logo
156 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
