Question about Frigidaire FEF336BC Electric Kitchen Range
Cooktop is hard to clean
Whenever I cook on the top I have a hrd time cleaning it afterwards
  • 3,037 Answers
Do you spray it with a degreaser and leave that sit on it for 10 min before wiping it clean? If not, then you should try this. It works miracles. Let me know if you have any other questions. thanks
Posted on May 13, 2008
  • Benjamin Patri
    Benjamin Patri May 14, 2008
    What more do you want? Please don't rate my solution without some feedback.
Want to clean electric cook top glass
Watch the provided video on the cleaning procedure for glass cook tops.
Jan 21, 2012 | Jenn-Air JED8430 Electric Cooktop
All the igniters are clicking after cleaning - help!
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 18, 2010 | GE 30 in. JGP336 Gas Cooktop
How do you clean white top
You can use oven cleaner. Read the label and find the part about cool cleaning or over night cleaning. I have cleaned up pyrex casserole dishes that I sort of over baked. Wipes right out the next morning.
G.
Apr 15, 2010 | Jenn-Air JED8430 Electric Cooktop
Was cooking fudge-hot sugary liquid boiled over onto glass cooktop. I tried to clean, but appears as if glass top has been ruined. It is rough. Tried scraping with razor, but does not help. Used cooktop...
Maybe try white vinegar - apparently you can clean glass hobs with it & it might help dissolve the fudge stuff if you pour it on that. I wouldn't use a razor as you might damage the hob more.
Dec 15, 2009 | Jenn-Air JED8430 Electric Cooktop
I have a Kitchenaid electric range Architect Series II. Seems every time I use the large burner on the right side there is some sort of residue left that is very hard to get off. I have already made a...
What are you using to clean the stove? Only cleaners made for ceran type tops should be used according to directions. Do not use enamel coated pans or glass pans on your cooktop.If you have a boil over, turn off the burner and change to a different burner immediately. Clean up the spill completely before cooking on that burner again. Use a flat edge razor to clean tough residue. Your cooktop will look new for years to come, even with heavy use.
As far as the scratch, don't use abrasive cleaners on the top and only use pots and pans with flat bottoms. If you do use cast iron pans, never scoot them around on the top.
Nov 30, 2009 | KitchenAid KESC307 Electric Kitchen Range
Do i caulk around my jenn air cooktop?
hello I assume you mean you are installing a new cook top, You can use caulk but its not easy to clean up after. Normally when I install a new cook top I use plumbers putty to seal it and bed it in. Hope this helps! Mike
Oct 27, 2009 | Jenn-Air JED8430 Electric Cooktop
Spot on Jenn Air smooth cook top stove with down draft.
Use Cooktop Cleaner with a soft micro cloth. Don't use water. Buff until the mark disappears. Hint: Never clean the cooktop until it is completely cool to touch as doing so makes cleaning much harder. Never use abrasives on the glass or abrasive cast iron skillets.
Mar 26, 2009 | Jenn-Air JED8430 Electric Cooktop
Hotpoint RGB745 - how to lift cooktop panel to clean underneath?
hey thats not a hard one for you.kill the power to your range [breaker ok]under neath the cook top frount where the top of oven door meets the cook top.in there are screews into the cook top .remove and lift up cook top it is hinged in the back .clean ,then put back together.you got it God bless ,tom
Jan 06, 2009 | Hotpoint RGB745 Gas Kitchen Range
White glass cooktop hard to clean
First thing I thought of was that your pots have oil or build-up of some kind on the bottom. Try cleaning them with a solvent of some kind. As an experiment, try using a pyrex pot to see if that makes a difference. As for cleaning the cook top, I use a vinegar and water solution with a soft cloth or very low abrasive scrubber as you can scratch the glass quite easily on some kinds.
Sep 17, 2017 | Jenn-Air JES9860 Electric Kitchen Range
Ingiters don't work - all burners
Unplug cook top. remove drip pan with screwdriver. Use hair dryer to completely dry area that might have gotten wet during cleaning. This may take five minutes. Put unit back together and plug in cook top.
Apr 27, 2008 | GE 30 in. JGP337 Gas Cooktop
Frigidaire FEF336BC Electric Kitchen Range Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
