Question about HP OfficeJet 6210 All-In-One InkJet Printer
Keep gettomg error message 388 - HP OfficeJet 6210 All-In-One InkJet Printer
  • 734 Answers
Hi There,
HP Support provides definitions and solutions for it's printers.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=uk&docname=buu02549#Error386
At this site you can simply scroll down and click on the blue underlined link "388" which states,
"There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time."
"Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve."
Since you didn't state that you were having a problem sending faxes, I fear this is limit to which I can assist you. That being the case, please reserve negative feedback for HP if the solution isn't sufficient.
If the error persistes and you are not attempting to send a fax unsuccessfully, it would indicate a false error report and that your registry in your operating is a bit out of order where the printer is concerned and the best "final" solution would be to uninstall the printer from the Control Panel COMPLETELY, then hold down the WIndows logo key and press the R key. A Run window will appear. Type in %temp% and hit ENTER. Your Temp File folder's contents will appear. Left click one in that window and then hold down the CTRL key and hit the A key. All files will be selected. Hit the Delete key. Remove every file that Windows will allow and then close the window, Disconnect the printer from your computer. Then go here:
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_query=Officejet+6210
Select the correct version of your 6210 (there are 3). At the next page Download the Full Version software by saving it to your Desktop. Then double-click the software installation file and follow the prompts. Do not connect your printer until the software prompts you to do so.
Ciao for Now
Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
Solution
Solution
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve. Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
Solution
Solution
Posted on Sep 07, 2010
Error meassage while trying to fax
please refresh fax memory and send the fax
Mar 09, 2012 | HP Officejet 5610 All-In-One InkJet...
Keep getting error code 388* when im faxing something
Pls do the following
Error Code:
388
Solution
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 28, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Gettomg Windows could not start because the
Best bet is to format the computer. I suggest saving all your files so that wen u format you dont lose everything
Apr 05, 2010 | Toshiba Satellite 5105-S501 Notebook
My hp4225 do not sent or receive fax messages, error 388*
hiii
well this error generally arises when there is too much of disturbance in the line.It may going away with time.And if it doesn't then u must retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Sep 03, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Problem faxing-error message
Error 388:
Definition
Solution
Error 403:
Definition
During a V.34 transmission, the local machine is unable to connect (handshake) with the remote machine and is consequently unable to send a T30 frame. This occurs when the line is disconnected or if line conditions degrade during the session.
Solutions
  • Remove any pass-through devices from the phone line, and then try the fax again.
  • Confirm that the fax/phone cable is no longer than required, and that it does not pass near unshielded electric motors such as fans, heaters, or household appliances.
  • Try to send the fax at a different time when telephone line conditions have improved.
May 29, 2009 | HP Office Equipment & Supplies
Error message 388
Hi! Error 388 means the local machine has originated a fax session and detected a remote fax machine but has been unable to detect any T30 frames.
If the machine is in V.17 mode, it is likely the connection has been interrupted. In V.34 mode is also possible for this error to occur due to compatibility problems with certain machines and/or line conditions.
Solution:
1. Reattempt the fax transmission at a different time when telephone line conditions have improved.
2. Disable V.34 on the local machine and attempt the transmission using the V.17 mode. ( See error 227 for changing to a slower speed or disabling V.34 .)
Use the link below-
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=1153695&prodTypeId=18972&prodSeriesId=1153695&objectID=buu02549
Jan 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
What is error 388
there is not error code for the OfficeJet 4315. however, there are similar code for other Hp printer.
error "388" is lised as unable to detect T30 frames. in other words, the machine fail to establish comparable connection. this can be the machine trying to send out fax in high speed, or the phone line problem.
consult the user manul how to set a lower transmission rate, or try to send the fax at a differnt time of the day . If that still give you problem, please call the phone company and have they look a the phone line.
Nov 10, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Error 388
Error 388 means refers to telephone line conditions, have you called you telephone service provider and have your telephone line checked.
If not please have it done.
For breif reasons on error codes check the link bellow:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&cc=us&lc=en&dlc=en&product=79477
Good Luck
Oct 17, 2008 | HP PSC 2410 All-In-One InkJet Printer
Sending faxes
Error 388 is for telephone line conditions being bad, have you called your telephone company and head you telephone line checked...?
If not please have it checked.
For more details on the error message check the link bellow with Error codes any their reasons:
Good Luck
Oct 11, 2008 | HP PSC 2410 All-In-One InkJet Printer
Fax
error code 388 says :-
Unable to complete the handshake.
*Try to send the fax at a different time when telephone line conditions have improved.
Mar 06, 2008 | HP PSC 2410 All-In-One InkJet Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
699 people viewed this question
Seeker5211
Seeker5211
