Question about Panasonic Palmcorder PV-DV53 Mini DV Digital Camcorder
Dew mist detection wont go off. Camera will not work
    Genius:
  • 1,812 Answers
This is usually caused by a failed component in the moisture detection circuitry within the camera and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 07, 2010
Dew detected for the PL-L750
warm it up put next to heater not to hot.. don`t leave camera in cold
May 15, 2010 | Panasonic PV-L750 Camcorder
Get "DEW DETECTED" warning on screen, powers off.
Also try this, take the bottom cabinet off, with the lcd panel facing you and the camera turned upside down and the cassette housing pointing away from you you will see 2 wide gold cables plugged into the right side of the board, realitively the same size, the gold cable that is between the main pcb and the mechanism assy is the control cable pull it our of the connector and clean it with alcohol, you can even take it one step further and evenly trim just a hair of the cable off all the way across just so that it has a new place to set. This has worked for me over 100 times in the past years. Seasoned camcorder technician 13 years experience.
chrisveal@msn.com
Aug 13, 2009 | Panasonic PV-DV103 Mini DV Digital...
Dew detected show on lcd
The camera is telling you that there is moisture inside the unit, place the camera in a warm dry space for 24 - 48 hours to dry out, it should be fine after that.
Regards
Aug 01, 2009 | Panasonic PV-GS300 Mini DV Digital...
Dew detected
Leave the camcorder turned off in a place with constant dry temperature with the door open. Take the battery off and wait a few hours like at least 3.
This should work unless it is really damp inside then it may take longer. This happens when the camera is moved from heat to cold or cold to hot temperature. Both tape and camera need to be climatized to prevent this from happening.
Oct 03, 2008 | Quasar VM-L459 Camcorder
DEW DETECTED / EJECT TAPE
I know that this sounds odd but the fix is to remove the battery and hit the camcorder on the back (where the battery was) with the palm or your hand. Put the batter back and it will work. I found this soluation a a CNET web site solution. I don't know why it works.
Jun 05, 2008 | Panasonic Palmcorder PV-DV203 Mini DV...
Fix Dew Detect for Panasonic 700X
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape.
Good Luck,
Luwangula
May 15, 2008 | Panasonic PV-GS300 Mini DV Digital...
Warning Dew Detected
Where are you keeping that camera? I would return this camera if it keeps happening (before warranty expire).
May 14, 2008 | Panasonic Proline AG-DVC7 Mini DV Digital...
Dew detected
This may sound stupid, but it worked for me.
Turn your camera on. When you get the dew detected warning, take your battery off and just hit the spot where your battery was a few times with your palm, not too hard, but not really soft. Put the battery back on and it should be fixed unless you actually do have a dew problem!
If that doesn't work, try drying it out with a hair dryer.
Dec 28, 2007 | Panasonic PV-L680 VHS-C Analog Camcorder
Dew detected eject tape
I have the same problem with my PV-DV103. Panasonic wants more to TRY and fix it than the camera cost new. MY advise can the camera and buy one without the DEW option.
Thats what I am searching for presently . If the manufacturer says the camera has a dew indicator in the circuit - buy elseware.
Nov 13, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
Dew detected on DV-203
I bought my 203 2 years ago-same problem. I FOUND THE SOLUTION! Might sound stupid, but I found it online, tried it and it works! When you get the "Dew Detected" sign on the screen, remove the battery, give it a good palm hit on the bottom where the battery sits. Hit it a couple good times, put the battery back in and voila it will work guaranteed! I thought it was dumb at first, tried it and it works, hell it works everytime. The blow dryer, plastic bag trick dont work because its an electrical error, not actual dew.
Sep 09, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
Panasonic Palmcorder PV-DV53 Mini DV Digital Camcorder Logo
41 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
