Question about Philips Universal PH301S Remote Control
I changed batteries in my remote and i cant figure out how to reprogram it
  • vote_4_pedro May 15, 2008
    I changed the batteries and I don't have the code for my Philips Universal Remote (PH301S). I'm trying to program it for my Sony Trinitron (KV-32FS120). PLEASE HELP!!!
    Novelist:
  • 97 Answers
Http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jun 20, 2008
My remote wont work for motorola dct6416 Ive tried all usual problems maybe need code to reprogram
1st did you check line of sight? is something between the cable box and the remote?
2nd is your remote in the right mode? when you hit "channel up" does the cable light flash? if not try figuring out how to change modes
3rd code search directions may be on the battery cover of the universal remote.
good luck
Feb 06, 2011 | Arris DCT6200 DTV Receiver
Remote control wont work
Not if the same brand as the unit. Sensor may went bad or has the remote been damaged or spilled on?
Apr 13, 2010 | Sylvania SRCD346 AM/FM CD and Cassette...
Battery is dead on the remote and cant turn alarm off if i change the battery does it have to be reprogramed?
just replace your battery you have a central control module, that stays programmed, the only way you need to get it reprogrammed is if you take it out and put it in another car
Mar 14, 2010 | Gmc Dodge Ford Reverse Back-up Sensor...
Suzuki swift 2007.changed battery in remote,and now will not work,yes battery is in right way. changed both remotes,both stoped working.
They need to be reprogrammed. You can take the car and the remotes with you to a dealership and have them reprogrammed. Make sure to take both remotes with you.
Mar 07, 2010 | 2005 Suzuki Swift
Cannot get remote for garage door to work
push the green button on the opener then push your remote button
Jan 25, 2010 | Locks & Locksmithing
Autopage XT-59 wont chirp and lock/unlock doors. plz hellp batteries are all fine, cant figure out how to reset remote
FIND THE VALET SWITCH AND PROGRAM MANUAL. REPROGRAM YOUR REMOTES. IF THAT DON'T WORK MAKE SURE YOU HAVE 12 VOLTS AND A GOOD GROUND CONNECTION AT THE XT-59.
Sep 27, 2009 | Vehicle Parts & Accessories
My remote in my keys no longer work to unlock my doors or trunk. I have changed the batteries in the keys, the light blinks when I push it. What could be wrong? I have a 2001 GS300
Most likely: You have to now "reprogram"your key fob and car to recognize each other. Look in your User's Manual for the car or, if it's an aftermarket fob/lock system, look in the user's manual for that. If there's nothing about battery replacement/reprogramming procedures, and it's a factory system, head into a dealer to reprogram it. It could run you up to $120, but that's cheaper than buying a new fob or system. If it's and aftermarket system and the manual says nothing, go to the place you had it installed (repair facility, Future Shop, etc) and have them reprogram it. If they installed it, they should know how to reprogram it.
Keep in mind, that's only the most likely option. Another possibility is that the receiver in the car, transmitter in the remote, or lock actuators/relays, etc in the car are the issue. It may not have been batteries in the first place at all. That said, it was most likely the batteries, and your best bet is trying to figure out how to reprogram the fob and car to recognize each other.
Jul 10, 2009 | 2001 Lexus Gs 300
Garage door opener will not respond to security plus remotes
Reset the Liftmaster unit. There should be a red reset button on the unit in the garage. If this does not work, reset the breaker. Good Luck!
Jul 03, 2009 | liftmaster Chamberlain Garage Door Opener...
No instructions for reprogramming keyless remote
the chamberlain company is very nice go to sears and get number of side of box... sorry I cant remember off top of my head...
Apr 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Programing help
I have a oneforall remote for my 25" Emerson TV I lost the programing instructions. Can you help me program it?
Aug 25, 2008 | RCA DIRECTV Satellite Remote Control
Televison & Video Logo
71 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
