Question about Zenith R57W46 57" Rear Projection Television
POWER SUPPLY FAILURE
I have an older Zenith rear projection tv. Model no. pv5257. I was told it needs a new power supply: part no. A1719602 which is no longer available. Question is... Can I repair this power supply? I'm pretty handy and not afraid to try if I knew what to do and/or what to look for! Any help is really appreciated!
    Genius:
  • Zenith Master
  • 1,673 Answers
These power supplies are complicated to work on. There are some preprietory parts that you would not be able to genericaly puarchase from general electronic parts suppliers.
If you are very strong in knowledge about power supply design, and if you can have the service manuals, have a scope and a DVM, you should have a chance to figure out what the fault is.
Take care that switching power supplies can be dangerous to work on. They employ high current using high voltages on the drive side.
Normally, these power supplies are not designed to be servicable.
Jerry G.
Posted on May 14, 2008
We have a zenith d60wlcd. the tv will just shut off..sometimes it last for a little bit and sometimes it won't last long at all.
When you remove the back of the set. You will fined a couple of caps on the power supply board that are bulged and they need to be replaced, or you can buy a new power supply at www.partstore.com. If you want to just purchase the caps, you can get them at www.mcmelectronics.com
Oct 16, 2010 | Zenith D60WLCD 60" Rear Projection...
I have an older 200x model Mitsubishi 1080i 46" rear projection TV that no longer turns on. When first powered up the power light on the front blinks in sequence to note that I have a bad power supply or...
Parts for older Mitsubishi are difficult to find. If you give me the complete model number I can check if the part is available online.
In the meanwhile please, try the two websites below.
Encompass Parts Distribution
PartStore.com
Feb 10, 2010 | Mitsubishi WT-46807 46" Rear Projection...
Zenith tv dosen't work
Power supply Board Call UED 1-800-648-6657 or try Encompass 1-800-638-3328
Dec 07, 2009 | Zenith E44W46LCD 44" Rear Projection...
Light is blinking after power failure
If the light is blinking and the TV wont start up, chances are that the power supply got spiked when the power came back on...look for blown components on the power supply board, or buy a new power supply board.
WARNING: be careful, messing inside TV's can KILL! If your not sure what your doing, Pay some one that does!
Oct 06, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Sony rear projetion TV KP-57WS520 wont come on.
This is an all-to-common power supply failure due to bad capacitors in power supply. Very common in new tv's.
Sep 10, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Picture and sound on my old zenith bigscreen flash on and off.
Sounds like a power problem to me. Possible shorting out inside the tv. If its old I would recommend discarding this tv. The price of repair costs are really high for TV's. You can probably upgrade to a flat panel for what the repair cost would cost you to repair this older tv.
Does it turn off and on as if you were pressing the power button? Or does it happen really fast? If its happening as if you were turning the tv off and then having to wait for it to come on again I would say its the power supply which is probably going to cost you hundreds in a repair shop. However you could possibly find a power supply for it on ebay buy searching for the model number and brand in the search area of ebay. Putting a power supply in a tv isn't really that hard, unless there is something in the way to get it in or out of tv. Usually it just involves unscrewing it from the chassis and unscrewing the hot wires and ground from the supply...then putting the new one in and screwing them back down.
Sep 03, 2009 | Zenith IQC60H94W 60" Rear Projection...
1999 zienth projection tv that has no picture
I have a Zenith (10 years old) not sure if is the same style; but I had the same problem. After being told to toss it, another shop "repaired power supply deflection parts and labor, part and major technical preform". Now have perfect picture and tv is like new. Cost was $295 for parts, labor and service call. It was in shop for a week. Hope this helps. Good luck
Mar 11, 2009 | Zenith IQB55M90W 55" Rear Projection...
IQC50H94W Zenith Projection tv
check the flyback/hv-spliter sounds like it could be your problem also check horizontal ic
Jan 23, 2007 | Zenith IQC50H95W 50" Rear Projection...
Zenith R57W46 57" Rear Projection Television Logo
161 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
