Question about Minolta DI-2010F Copier
Minolta Di 150f printer/scanner/fax
I inherited a Minolta Di 150f from a friend with no manuals. I can't seem to find any information on this printer on the web. It's like it doesn't exist but I have it right in front of me. Maybe it's so old that it isn't supported anymore. Any help from anyone would be greatly appreciated.
One tag says the model number is 0996MU and another tag says the model number is 42000.
I can't get it to copy anything and when I do get it to feed paper through it makes a screeching noise and then stops. The paper is halfway through the machine with no print on it and it says printer scan error.
Is this printer fixable or should it go out to the junk pile?
  • dchev May 14, 2008
    Inherited might be the wrong word. I got it because this guy owns a small business and he wanted something simpler to operate. My brother works for him and he wanted to throw it out, maybe mostly out of frustration.
    I thought that I would try to get it to work before throwing it out.
  • Minolta Expert
  • 1,326 Answers
If it is a Di modle it is most likely a curent model, but why did you inherited it??? Did your pal get a new one???? Do you have a boat???
Posted on May 14, 2008
C650
scanner home position code. Check the scanner located under the big glass. the scanner also has the exposure lamp. the bright light.
Jun 26, 2014 | Konica Minolta Minolta DI1610P Printer,...
Errore Trouble code C-C172
Refer to Konica Minolta Bizhub C451 Printer/Scanner/Finisher's User Manual or Call Service Center.
May 01, 2014 | Konica Minolta Bizhub C451...
C-0600
Scanner motor failure scanner motor is what moves the bright light under the big glass check for a cable problem or just a bad motor worse case the control for the motor is bad.
Feb 19, 2013 | Konica Minolta MINOLTA BRAND DIALTA...
I have Minolta DI 470 copier , and when i print from my computer it displays " error printer 1808" , i can't found any solution till now. Can anyone help me to solve this issue.
An 18xx code that can't be reset is caused by a problem with the image processing board. Most likely it will have to be replaced.
I'd call for service on this one.
Mar 06, 2011 | Konica Minolta Minolta DI1811P Digital...
Minolta di 151 has a problem coping properly, need to know why, replaced toner and still has problem, need either manual or what else could be wrong...
If the printing is poor and almost white copy, you need to replace the developer in the image unit, clean all the lens first to be crystal clear.
May 26, 2009 | Minolta Di151 All-In-One Laser Printer
Minolta di 151
You're going to have a tough time finding a paper manual, since Minolta was bought out by Konica. However, if you have Adobe or another PDF reader you can get the manual on the Konica-Minolta website: DI151 Fax Manual
Oct 24, 2008 | Minolta Di151 All-In-One Laser Printer
Di2010
A Print Controller can be installed.
Network print kit: NC-4 PCL Print Controller:
http://www.amatteroffax.com/ItemPage.asp?INVID=1047235&CT=1&CRY=%B4o%B8s%E7PQ%5D%60vT%B1%C8%F5%C9%87%BA%D2%B91%98%1FC
or a
Pi3505e Minolta PN:4513-612:
http://www.amatteroffax.com/itempagey_INVID_1047328_d_Minolta-Pi3505e-PostScript-3-+-PCL-Print-Controlle.htm
or you can install both if you wish.
I haven't found any data supporting the addition of a fax expansion kit. These models were before the FK-502 slide in expansions and I believe that's why the also sold the Di-2010f with the fax.
A network fax option, however, is available with the network scan kit.
Fax Kit:
Dec 22, 2007 | Minolta DI-2010F Copier
Printing confirmation page after completed fax
If you have the operators manual (it may be in the back compartment of the machine), look in the index for "fax parameters", then "fax reports".
Nov 30, 2007 | Minolta DI-2010F Copier
Minolta DI-2010F Copier Logo
324 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
