Question about GE PSS29NGNWW Side by Side Refrigerator
Where can I find step by step instructions for changing the Funnel Ice Dispenser on the freezer door of my GE Profile PSS29NGN?
  • richard_rook Sep 07, 2010
    Is this procedure done from the front of the door? If so, how is the trim removed?
    Instructions were a big help. Thank you.
  • GE Master
  • 19,396 Answers
Hi.
Here summary instructions:
Disconnect appliance from power.
Remove the trim on top of the dispenser.
Undo three electrical connectors,
Undo the four screws holding the shield to the door.
Pull out the assembly with the funnel.
You may need to lift the plastic tabs on the left and right to release the funnel.
Assemble new part performing operations in reverse order. You will need to fit in place the two plastic tabs, the spring and the tab operating the switch all in place at the same time, that part may be a little tricky.
The funnel is part 69 in diagram below, click on the picture to enlarge:
Good luck with the repair.
Ginko.
Posted on Sep 07, 2010
  • 1 more comment
  • Ginko
    Ginko Sep 07, 2010
    Hi.
    I see that my previous comment received a negative rating. I do not understand the reason. By the way on your request the question will be passed to a different expert. Sorry about your decision.
    Help yourself with a plastic padded knife. Be careful not to damage the paint.
    Goodbye and good luck.
    Ginko.
  • Ginko
    Ginko Sep 07, 2010
    Hi. Sorry about confusion.
    I see that I am see on your problem (good). I received a message regarding a different fridge, hence the confusion. Please disregard last message.
    In your case help trim out using an hard plastic padded knife or a similar object. As far as I know the trim is not held by screws. The trim is held by clips all over the perimeter.
    If you cannot do with a plastic object use a metal tool, but be careful with the fridge coat.
  • Ginko
    Ginko Sep 07, 2010
    Hi.
    You are welcome.
    All the best.
    Ginko.
GE Profile PSS26PSTA SS freezer problem
Forget the warranty - it is only for the compressor and that is usually five years. Did you check for freezer temp - wet cubes indicates too warm up there. Water dispenser lines may be clogged.
If low temps you may have low refrigerant or a defrost mechanism not working - if not working there should be ice buildup on line entering the evaporator in back of compartment.
Jun 16, 2017 | GE Profile PSS26NGS Side by Side...
Frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
Oct 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE model PSC23SGRC SS refrigerator freezer door disassembly
Access from front of freezer door. Trim is just pushed into friction holders. Selector area snaps in. Phillip screws under that removes ice shoot.
Sep 16, 2009 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Our GE Profile Side by Side Refrigerator is leaking at the ice dispenser in the door. I've turned the water valve off, what should be my next step?
easy , 1 you have to chek if the line of your water is broken , 2 you have to see if it not from your freezer ( the defrost ; it do that 3 time per day ) if it leak for the frezzer you have to low the temperature in the freezer
Jun 07, 2009 | GE Profile PSS26NGS Side by Side...
NO DRINKING WATER
common problem the water line inside the freezer door is frolzen up . to fix remove everthing from the freezer door , turn off freezer . open freezer door and put a blanket over the opening to the freezer leaveing the door to room temp for an hour or so to defrost . check if defrosted . remove blanket close door . this will happen with ge , try seyying the freezer control on the next lower number (warmer)
Jan 14, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice and Water Dispenser Funnel
This diagram may help some.. should be a molding thats goes around outside of dispenser.. should be able to pop off and get at screws u need to get at...to remove and get at what u need too
http://www.partselect.com/Schematics/GE/00116598i01.gif
Nov 01, 2007 | Refrigerators
GE PSS29NGNWW Side by Side Refrigerator Logo
85 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
