Question about HP Pavilion dv4000 Notebook
I am having a problem with a hp pavilion dv4. When it is plugged in the charging light will flash when i try to power it on the other lights on the case flicker and die . and if i plug in the laptop without the battery the charge light doesn't flash but it will not boot. I have tested the: cable , cmos battery , and the internal power connector and they are all good. I have tried resetting by removing the battery the cmos battery and the charger and pressing the power button then reconnecting those parts .... still won't boot . I have tried to start it up with almost nothing besides the mother board the charger and the LCD ... still nothing. Is this the mother board ? Does any one know if this is a common problem with this model ?
    New Friend:
Same here with dv7.. FukHP
Posted on Nov 12, 2013
IVE GOT THE SAME PROBLEM
Posted on Feb 17, 2011
Hp pavillion dv4 charging indicator is blinking even if charger is plugged in. and when turned on, suddenly shut downs just a few seconds from turning it on. any solutions to this problem? i'm really...
From the batterycentury.com(http://www.batterycentury.com/hp-pavilion-dv4-battery-p-22931.html) Why your HP Pavilion dv4 Battery light flashing?this migth fix your HP battery Pavilion dv4 problem;
  • Go to your power settings by right clicking on the desktop and select Properties> click the Screen Saver tab> click Power.
  • Under Power schemes select select all of the choices to never.
  • Plug the power supply into the laptop and wait till it reaches 100% and stop charging..
  • Disconnect the power supply and let the laptop discharge completly untill it heibernates.
  • Reconect the power supply and let the laptop charge complely again, then go back into the HP dv4 Battery power settings and resume the previous settings.
...but in your case - that sounds to me like the battery is defective...
Jun 13, 2011 | Computers & Internet
I am having a problem with a hp pavilion dv4. When it is plugged in the charging light will flash when i try to power it on the other lights on the case flicker and die . and if i plug in the laptop...
had a similar problem,and I resoleved it via a bios flash..this allowed the hardware to be fully recognized and to perform the specified role.For some reason,the bios software for this version seems to corrupt after several years. I have had my machine for the last four years..until it recently started giving the issues,it had no problems.
Jun 06, 2011 | HP Pavilion dv4000 Notebook
I have a HP DV4 1114NR. When it powers on, all light come on but a black screen. THe power light and batt charge light flashes. How to resolve this and get it to boot up?
It could be forced into "Sleep Mode" by USB or other ancilliary devices. Ensure there is no CD/DVD in the drive, no Lan connection and no USB items, especially modems, plugged in and try again.
Dec 21, 2010 | HP Pavilion dv1000 Notebook
My HP dv4 1120us laptop will not power on. When I insert the power cord the led for power bolt comes on and when I press the power button the power LED flashes once and then nothing happens. The power bolt...
Sounds light a power switch short, but lets try to take the memory out of the laptop and power on the laptop. Does it boot up? if so lets try 1 memory stick at a time.
Nov 29, 2010 | HP Pavilion dv4-1120us Notebook
My hp pavillion dv4-1220us laptop, won't start up...I press the power button and it turns on for a couple seconds and then turns back off....
1) Is it the battery, power up using the power supply.
2) When the power supply is plugged in, is there a charge light/led (could by a bad power supply not charging or providing a good connection)
3) Is the CPU over heating? Check the vents underneath are they clogged with dust?
After this, you're getting into internal faulty component issues and need someone to look at it.
Apr 13, 2010 | HP NB199UA Pavilion Notebook
I have an hp pavilion dv4- 1430 us that won't turn on
I had the same problem with my hp pavilion dv4 1430 and to fix it I just took out the battery and unplugged it from the power adapter and pushed the power button and waited for a few minutes I put it all back together and started it up and the screen turns right back on.
Jan 09, 2010 | HP Pavilion dv4-1140go Laptop
Pavillion dv4 new battery only charged one time.
How long did you leave the battery for charging?
Dec 29, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion dv9700t battery dead, faint blue flash from plug
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 18, 2009 | HP Pavilion dv2700t 2.5GHz Intel Core 2...
HP Pavilion dv4000 Notebook Logo
263 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
