Lg tv mod ct29q26et
Has an overseas a c plug,do I need adaptor? Lable states auto voltage control,or do i justchange the plug end.
    Genius:
  • Televison & ... Master
  • 1,689 Answers
Enquire to the LG service rep in your area for the proper adabtor. Double check with them if the power supply in your model series is compatable to the AC mains voltage at your location. If not, the set will be badly damaged!
As for changing countries with these TV sets, not all of the model series will follow different broadcast standards. This is another thing for you to enquire about with the local LG service rep.
Jerry G.
Posted on May 14, 2008
Connected alesis sr16 with alesis 110v power supply.to 240v mains...........briefly powered up and then nothing. Have I "fried" the adapter or the sr16?
Look carefully at the adaptor and see if it takes any voltage besides 110 (it will say in very tiny print, you will need a magnifying glass). if it does NOT say 220V or 240V then you friend the adaptor. Get another adaptor - most are "dual" voltage meaning they run in the U.S. or overseas.
Also check for "polarity" (which part of your plug is + or - ).
Jan 24, 2013 | Alesis Sr 16 Stereo Drum Machine
HP Deskjet 1056 supposed to be dual voltage...?
What does it say on the "brick" on the cord? Look for power specs on the cord transformer.
Dec 10, 2012 | Office Equipment & Supplies
I have a LG 42"-model 42LH20r-ta TV that I bought
how can I do to obtain the afficheur of my LCD LG42 MODEL 42LH20r-ta
May 15, 2011 | LG 42LH30 42 in. LCD TV
The power adaptor model ys-1015-k12 or my snapscan touch has packed up, how can I get a new one?
Two choices
One buy one from Agfa by visiting thier website and checking out the support section.
Two check the lable on the printer or the manual which will tell you how many volts and how many Amps / milliamps it needs to run. Armed with that information go to almost any electrical store large supermarket and check out the multi voltage adaptors (ask in the store for help but results may vary from knowledgable to moron) buy one with at least the same Current or more if its 500 mA and they have one at 750 mA I would take that one. go home and plug it in checking that you have the correct end ( they come with a good selection) also check if it needs centre positive or negative (usually centre positive) and set your new adaptor to suit. It may have a small switch that does it for you or yo may have to change a the way the and connects as they are sometimes reversible just for that reason.
I know it sounds a lot to do but it means you can go out and get an adaptor without having to wait for Agfa and you will probably save money too
Aug 09, 2009 | Agfa SnapScan Touch Flatbed Scanner
I bought a Whirlpool Washing Machine, Dryer, and Refridgerator from an American base in England. They have a German plug but the lady at the time said I could use them when I return to America. It is now...
Assuming the voltage is the same, you can buy "international wall outlet plug adaptors" in most major cities as well as near most major military bases (because service members routinely return with products from overseas). Simply check your phone directory and/or the internet for "international wall outlet plug adaptors". Also, outlets such as Radio Shack and Brookstone often stock such items.
XMinusOne@gmail.com
Dec 10, 2008 | Washing Machines
My LG remote control turns two TV's on simultaneously
I had the same problem and we cut up a stick on lable and placed it over the end of the remote . It weakened the signal enough to where it would not change the other tv/tvs. We colored in the white lable with a black marker and you dont even notice it there.
It took alittle playing around with but it was much cheaper than buying a remote.
Dec 01, 2008 | LG Shine KE970 Cellular Phone
HP Pavillion dv6000 -when I plug in AC adaptor, it won't charge
Hi ja525,
If you have tested the power adaptor with a multi-meter to confirm it is OK or the other adaptor is also OK assuming that it is the correct voltage and at least the same current rating. Then the fault is most likely the power connector in the laptop.
To confirm this, power up as normal with the power adaptor connected and switched on, when the blue LED dims wriggle the power connector where it connects into the laptop and if the LED comes on or blinks, that means that you have a faulty power connector, it couls be a dry solder joint at the power connector.
It is possible that the power adaptor is shutting down (thermal overload) due to insufficient current capacity, Check the Amp rating of the laptop, it is usually on the lable on the botom of the laptop and check it against the power adaptor, the adaptor should be equal too or greater that the laptop's current rating.
To fix a faulty connector, you can dismantle the laptop and with a fine tip temperature controlled soldering iron, resolder the power connector and hopefully this will fix your prolem.
Nov 18, 2008 | HP Pavilion dv6000z Notebook
Does Nintendo Wii work abroad?
Hey Erolon,
Nintendo Wii's sold within the United States will primarily be NTSC-formatted devices. Unfortunately, because Europe utilizes the PAL format instead of NTSC, you would need to have an NTSC-compliant TV in order to use a Wii purchased within the U.S.
Please also keep in mind that video games are often region-coded to work only with the consoles sold in the same area of the world. In other words...if you were to purchase a Wii within the U.S., you would only be able to play video games purchased within the U.S. as well.
Additionally, remember that the United States and Europe use different electrical standards: 110V/60Hz for the U.S. and 220V/50Hz for Europe. In order for any electrical device purchased within the U.S. to function properly overseas, a voltage adaptor may be required.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 30, 2008 | Nintendo Wii Console
Using battery charger overseas
it's alway suggested that you simply use plug adaptors to change shape of plugs for overseas-do not reduce voltage since most all chargers including yours support 220 or 110
Jun 07, 2008 | Cameras
Can my Viewcam be used overseas?
Yes! The Viewcam ® comes supplied with a universal A/C Adaptor, which will accommodate from 110-240 volts and 50 or 60 hertz. You may need to purchase a plug adaptor for the different type of sockets.
Sep 07, 2005 | Sharp Viewcam VL-A10U Camcorder
Televison & Video Logo
Top Televison & Video Experts
