Question about Honeywell Programmable Thermostat Heater
My new Honeywell TH4210D1005 thermostat does not have a "W" terminal for the white wire. The white wire was connected to the "W" terminal on my old thermostat. My heat pump has emergency heat. My choices to land this white wire are "Aux" aux heat relay or "L" sends output to E heat. They sound the same.
  • 674 Answers
I Googled the user manual for your thermostat. It says to install a jumper between E and Aux if there is no emergency heat relay. Here is a link to the manual. Look on page 5, line 5.
http://www.forwardthinking.honeywell.com/related_links/thermostats/pro_4000/install/69_1763.pdf
Posted on Sep 07, 2010
Bought new thermostat model ct87k but old Honeywell model I have was hook up by black and white wire not red and white , so how do I hook up.
The two wire Honeywell T87 and CT87 is nothing but a switch in a control circuit. Wire color is not important at all. What is important is the TERMINAL DESIGNATION those wires are hooked to. Soooo....take the wire off of the sub base of the old stat terminal marked 'R' and attach it to the new sub base terminal marked 'R' and so on. Wire COLOR means nothing at all in your case.
Oct 04, 2014 | Honeywell CT87K1004 Round Heat Only...
I wont to replace my old robert shaw 9400 thermostat with a new honeywell rth111b thermostat but dont known the color wireing diagram
Hello, if this is a standard straghtcool/heat unit then Red- R terminal or Rh white- W terminal Yellow - Y terminal Green- G terminal Blue- Common terminal ( not always used) but ifyou do have a blue wire it will connect to this terminal.
Nov 19, 2011 | Heating & Cooling
I just bought a Honeywell 5.2 Day RTH2300B Programmable thermostat to replace my old mercury thermostat for my gas fireplace. When I took of old thermostat it only has two wires. A white wire and a black...
I just installed a Honeywell 5.2 Day RTH2310B Programmable thermostat and I had to deal with the same situation: 2 wires, one white one black. After reading the edvice in one of the blog, the solution that worked for me was: BLACK ON Rc terminal and WHITE on W terminal. My furnace is running fine now. Hope it helps.
Dec 06, 2010 | Honeywell Focus 6300B 5-2 Days...
Replacing WHITE-RODGERS manual thermostat with 3 wires ( red, white, blue and installing Honeywell electronic thermostat RTH110B, how do I connect it? The heating is not central, baseboard heating.
I have only seen one Honeywell thermostat that would work with a 3-wire heating system.
I would replace it with a White-Rodgers 1F80-0471. They are about $100, but they are a good thermostat, and they work well with the 3-wire zone valves.
Most other thermostats have the "Y" terminal that you need, but do not control the zone valve correctly.
Helping Hands Services
- Fairbanks, Alaska -
Jan 30, 2010 | Honeywell Electronic Programmable...
I am unsure of your question, but if you are just replacing your old thermostat with a new one, then connect the red wire to the Rh or R terminal and the white wire to the W terminal on the thermostat. Hope this helps
Jan 09, 2010 | Honeywell Electronic Programmable...
I tried to insatll my new honeywell programmable. the old t-stat had a white and red wire connected allread. there were 3 other wires unused, G,W,R. I hook up the original R,W wires to the new t-stat and...
The red and white wires go to the R and W terminals on the thermostat. Disconnect what you have now and hook the red wire to the R terminal and the white wire to the W terminal on the new thermostat and see what happens.
Jan 09, 2010 | Honeywell Programmable Thermostat Heater
Installing new thermostat
w--white--heat........g--green--fan..........y--yellow--cool....r--red--powerx---b----o--are for heat pumps...
Dec 20, 2009 | Honeywell TH4210D1005 Heater
Wiring new RTH2310 DIY Honeywell
sounds like you've got bear wires touching at the new tstat
Sep 18, 2009 | Honeywell Focus 6300B 5-2 Days...
Heating & Cooling Logo
536 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
