Question about Cyberhome CH-DVD 300 DVD Player
Cyberhome 320 wont load discs
My cyberhome 320 dvd player displays "No Disc" when I put any dvd in, even the laser cleaner disc show no disc after I tried to clean it. It will show "Loading" for several minutes and I can hear it spinning, then "No Disc" pops up. What is the problem and is this something that I can do myself?
  • 3 more comments
  • Anonymous May 15, 2008
  • RamaKrish Aug 26, 2008
    When i inserted a DVD into my cyberhome dvd player i am getting as Bad Disc Message.Currenty i am in Hyderabad,India.
    Can anyone let me know the service center in hyderabad to get it repaired.
    my mail id is
    Thanks in Advance,
    Rama Krishna
  • d_mm Sep 07, 2008
    When I load a disc in the dvd player it reads No Disc.
    I have thogoughly checked all connections. In addition I have 2 units - one will load the disc and play the movie however the color only reads pink. The other continues to read No Disc.
  • Anonymous Feb 21, 2009
    wont load dam disk
  • bonbeetoo May 02, 2009
    I've had this product since 2004. For the last few months it increasingly stalls while loading DVDs. After several minutes, it will display "bad disc." If I turn the player on and off or open and close the disc drawer several times, it sometimes eventually loads/plays the disc. Other times, it will load/play discs immediately.
    Don't know whether this old player just doesn't recognize newer discs or what . . .
  • Cyberhome Master
  • 1,550 Answers
This dvd's fails because a dry capacitors on the alimentation source you need to send to a repair service center.
Posted on Jun 26, 2008
DVD's played on 320 series won't play, just says bad disc,
Posted on Feb 21, 2009
Cyberhome dvr 1200 doesnt read disc
its lazer is either burned out or too dirty to read the information on the disc try putting a lazer head cleaner through it
Apr 20, 2010 | Cyberhome DVR 1600 DVD Recorder
Cyberhome 300 not stuck on main blue Cyberhome screen
It may not be able to read the DVD because the laser is dirty. First try to reset the system ( with no disc inserted, open then close the disc tray and hold the stop switch on the UNIT NOT THE REMOTE for six seconds). Then with the disc tray open using a can of "AIR DUSTER" - dry air in an aerosol can, insert the can nozzle into the disc tray cavity and spray away. That may blow off any dust on your laser eye. Try it again and if it still wont work,unplug the unit and remove the six small Philips screws that hold the cover on( it pivots up and off from under a lip in the front panel), plug it back in and open the disc tray exposing the laser and clean the lenses with Isopropyl alcohol and a q-tip. Do this GENTLY you don;t want to disturb the laser alignment. Dry with another Q-tip or the Airduster and re-assemble. Note well the unit will be POWERED with the cover off so BE CAREFUL. Just did this with mine and it now works like a charm again.
Dec 05, 2009 | Cyberhome CH-DVD 300 DVD Player
Cyberhome 1010A won't read disc
Clean the laser with a q tip and rubbing alcohol. That usually works with lasers that don't read. If this doesn't work ( be sure to let the alcohol dry and don't leave streaks) then I would either assume the laser isn't getting enough power or the laser is actually burned out.
Nov 01, 2009 | Cyberhome CH-LDV 700B Portable DVD Player
It won't read disc. After loading, it reads No Disc
Sounds like a read error fault , possibly a laser malfunction sometimes dirt on the lens will cause this try a good CD cleaner if this is no good I suggest a free engineers estimate at least you can then ask again on here how to fix it . My honnest guess is either a duff laser or software corruption . I have known seating of the tray to cause this also not returning fully back into machine , usually caused by children and alien matter ? shall we say such as choclate or M&MS kids shove stuff everywhere ? bless them lol
hope this helps Regards Vortash
May 10, 2009 | Cyberhome CH-DVD 300 DVD Player
The screen says no disc even when I put a DVD in
Dear friend,
Pls clean ur dvd palyer lense or replace ur lense
Mar 28, 2009 | Cyberhome CH-DVD 300 DVD Player
My cyberhome CH-LDV-1010A dvd player does not go pass reading.
lens is dirty ........clean the lens using the lens disk cleaner...........still problem continues the laser head is not picking up the disc...........need to replace laser assembly.......
Feb 04, 2009 | Cyberhome CH-LDV1010A Portable DVD Player
Cyberhome 1600
You might try taking the cover off and then VERY GENTLY use a q-tip swab to brush off the laser lens. Sometimes a little dust or dirt is enough to keep it from detecting the disc.
Nov 11, 2008 | Cyberhome DVR 1600 DVD Recorder
No Disc
I have the same model ... you can't use DVD-R or DVD-RW discs, only DVD+R or DVD+RW
Apr 26, 2008 | Cyberhome DVD Recorder - DVR1600
After loading every disc displayes "wrong disc'
are they bootleg dvd's? if not try getting a lense cleaner because wrong disc means it's reading your dvd's as .mov files which only play on quicktime in a computer. if it reads your cleaner as wrong disk too then get yourself a refund cuz it has a motherboard malfunction.
Dec 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
606 people viewed this question
Top Cyberhome Televison & Video Experts
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
