Question about GE Profile 23.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - High-Gloss White
My frig is not getting cold, but the freezer still seems cold
  • 15,935 Answers
Likely the damper solenoid is failed - or the damper door itself is frozen/warped. This damper allows cool air from the freezer depending on the temperature of the fridge.
Closer inspection will be necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 07, 2010
Unplugged frig overnite once I plugged back in made a gurgeling sound whenever I opened the door what would that be?
Usually that is caused by a bad defrost heater thermostat or defrost timer. Failure to automatically defrost is the cause of freezing up.
If you don't feel up to doing the work yourself you should have an appliance repair shop look at it.
The gurgling is caused by water in the catch pan under the fridge. When you defrosted it some of the water made it into the drip pan (and maybe overflowed onto the floor). The fan inside the compressor area under and behind the freezer may be splashing in the excess water in the drip pan. This by itself is not a real problem since it is designed to automatically evaporate the water drained during automatic defrosting, but the excess water and potential overflow onto the floor can become a problem.
Mar 10, 2017 | Danby DFF8802 Top Freezer Refrigerator
Frig on top freezer below.....freezer working.... frig not...condensor seems fine and fan is on?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 20, 2011 | Amana ABB2227DE Bottom Freezer...
Whirlpool frig. Freezer warm, frig seems ok.
Since the temperature is already 40°, the cold control is satisfied and will not run. Thus the freezer will warm up to 40°.
Jan 06, 2010 | Refrigerators
Frig is not getting cold at all and the freezer is not freezing Thanks
Hi, I can help you. What brand & model# is this? Is there any frost built up on the inside rear freezer wall
Vic
May 27, 2009 | Freezers
Frig not getting cold
See if the coils are blocked with ice. Fridge gets cold air from freezer, ice would prevent this thus a warm fridge.
May 10, 2009 | Refrigerators
Estate refrigerator does not cool, but the freezer seems to work fine
open the frig door put youer hand over the vent comeing into the frig there should be cold air blowing with freezer door shut if not then opent the freezer door if you get cold air out of the vent now you have a defrost problem if you still have no cold air the damper door on that vent is not opening it will need to be replaced
Mar 27, 2009 | Estate Refrigerators
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
GE Profile 23.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - High-Gloss White Logo
137 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
